| Features |
| 规格 | |||
| Model | 1215L | ||
| Display | 12.1" diagonal, Active matrix TFT LCD | ||
| Aspect Ratio | 4:3 | ||
| Useful Screen Area | Horizontal: 9.7" (246 mm) Vertical: 7.3" (185 mm) |
| Native (Optimal) Resolution | 800 x 600 at 60 Hz | ||
| Other Supported Resolutions | 800 x 600 at 56, 60, 72 or 75 Hz 640 x 480 at 60, 66 Hz, 72 or 75 Hz |
| Viewing Angle (Typical) |
Horizontal: ±70° or 140° total Vertical: ±50° or 100° total |
| Colors | 262,000 | ||
| Brightness(Typical) | LCD panel: 200 nits AccuTouch: 164 nits IntelliTouch: 184 nits Surface capacitive: 170 nits |
| Response Time (Typical) | 35 msec | ||
| Contrast Ratio (Typical) | 500:1 | ||
| On-Screen Display (OSD) | Controls (side): menu, up, down, select, power Settings: contrast, brightness, H/V position, recall default, RGB (color temp), OSD exit, clock, phase, sharpness, OSD H/V position, OSD time, auto adjust, input select Languages: English, German, Spanish, Japanese, French Lockouts: power, user controls |
| Input Video Format | Analog VGA | ||
| Input Video Signal Connector | Mini D-Sub 15-Pin VGA type | ||
| Power Supply | Internal AC, Optional external DC (power brick) | ||
| Input Voltage | AC: 85-265 VAC, 47–63 Hz DC: 12.0 V ± 0.75V |
| Input Connector | AC: IEC 60320 C6 DC: Coaxial power jack (2 mm pin diameter, 6.4 mm barrel diameter, 8.8 mm barrel length) |
| Input Frequency | Horizontal: 31.5-48 kHz Vertical: 56.3-75 Hz |
| Power Consumption (Typical) | 16W | ||
| Monitor Dimensions (with Stand) (W x D x H) |
11.9" (301 mm) x 6.6" (168 mm) x 11.3" (286 mm) | ||
| Shipping Box Dimensions (W x D x H) |
14.77" (375 mm) x 10.24" (260 mm) x 14.38" (365 mm) | ||
| Weight | Actual: 8.2lb (3.7 kg) Shipping: 13.6 lb (6.2 kg) |
| Warranty | 3 years | ||
| Optional Product Coverage | Advance Unit Replacement program (North America only) Extended Warranty (North America and EMEA only) |
| MTBF | 50,000 hours demonstrated | ||
| Agency Approvals | UL/cUL, TÜV-GS, CE, FCC/IC/VCCI/C-Tick Class B | ||
