TRICON 8311
TRICON 8311
联系人:郑娟萍
联系电话:0592-5173279
公司传真:0592-5165561
电子邮箱:3150816822@qq.com
Q Q: 3150816822
公司网址:http://www.yuehang.cc/
联系地址:厦门市思明区湖滨东路湖光大厦18楼A单元
涂层保护模块,适用于恶劣环境;安全I/O,高可靠性;支持第三方设备
高性能热备解决方案。每个模块均有小型LCD荧幕及按键,便于本地监控
前面板有多个内置端口(USB、Ethernet TCP/IP、Modbus Plus、以及至少一个 Modbus 端口)
本地机架上可安装第三方模块以连接Profibus
-DModicon Quantum自动化控制平台拥有业界领先的性能,包含:
5种IEC编程语言(FBD 、LD、SFC 、ST 、IL)适用于各种应用需求
高性能多任务系统
高达7MB 储存空间
AMAT 0140-02991 Harness Assy, Motor Driver Assy AC Filter, Assembly
AMAT 0040-83031 Bracket, Walking Beam Cable, 200MM Desic
AMAT 0020-70284, 5200 Robot Tube for HUB, Looks NEW
AMAT 0190-18130 Microwave, Wave Guide,
NEW AMAT 0090-77112 Assy, Smoke Alarm Bypass
AMAT 0020-45908 Stop Upper 300MM, 395515
AMAT 0620-02291, Cable Assy Keyboard Extension, 395592
2 AMAT 0190-29429 Adapter Plate Assy SPL
AMAT 0021-01366 Bracket, Final Valves Holder, Nitride
AMAT 0720-91262 D Type Socket Pin, Solder
NEW AMAT 0020-32835 SPACER LOADLOCK COVER LIFTER WPS
AMAT 0021-03321 Liner Pumping Leap CVD
AMAT 0020-23828 Driver orienter NO degas
2 AMAT 0200-02085 Pin, Wafer Lift, Quartz EPI 200mm
7 AMAT 0020-05812 RING NUT SPINNING HEAD REV 5
3 AMAT 0021-14119 Spacer, PCV Controller, 200MM Radiance
AMAT 0190-02442 Hose Assembly, Lid Liner Jumper 300MM E
AMAT 0150-04600 Cable Assembly, Analog I/O Block, Wafer Loader
NEW AMAT 0150-02639 CABLE ASSY SRD LIFT MOTOR ENCODER
AMAT 0020-20937 Clamping Ring 8" AL Major Flat, Quartz, 399179
AMAT 0140-16066 Harness Assy, Gib Interface For 4 Gibs, Assembly
AMAT 0100-90163 PWB Assy, Wafer ARM Pos.
AMAT 0020-22892 Shield, Collimator Lower 6" 116
Asyst Shinko Cable 3FC120B062100
NEW AMAT 0100-90052 PWBA MB MOTOR POT
AMAT 0021-12190 Manifold, water, DGDP DIP PLATE
NEW AMAT 3700-01622 Oring ID .612 CSD .103 VITON 75DURO BLK
AMAT 0190-03295 Hose Assy CH Body Out/Heat EX RET CH B P. Assembly, Chamber
AMAT 0040-92584 SHOE, PICK-UP
AMAT 0140-37761 Harness Assy, Pneumatic, Speed Cont. Manifold, 300MM, Assembly
AMAT 0020-15278 STOP, INDEXER, 300MM MARN CHASSIS
AMAT 0090-09299, 0010-30724, ESC Chuck, 200mm, 400234
AMAT 0040-83031 BRACKET, WALKING BEAM CABLE, 200MM DESIC
2 AMAT 0020-94587 Capping, Concertina Door
AMAT 0140-78279 Cable Upper Pneumatics Panel Sensors, 397771
NEW AMAT 0140-09304 HARNESS ASSY, TEMP/LEVEL SENSOR
AMAT 0090-40032, Switch, CVR Interlock, Power Supply, E, 395612
AMAT 0020-23946, Bracket, N2 Purge LL Producer SE
100 AMAT 0950-01025 IC Flip Flop 74LS74 Dual D
AMAT 0151-90551 Cbl Assy 117 P8/14G P3
AMAT 0021-08157 Pad, Gas Panel Door Latch, 300MM TPG
5 AMAT 3160-00003 Cover Plastic For #1/4SCR White
2 AMAT 0190-77479 Cable Assy, Monitor Ext, 15 FT
AMAT 0021-08157 Pad Gas Panel Door Latch 300M
NEW AMAT 0020-83799 BLANKING PLATE TOP BOX, S.PIPE, 398687
Agilent Technologies, HP, 10707A Optical Splitter 50% Beam Splitter
AMAT 0140-70176 PNEUMATIC HARNESS, GATE V
AMAT 3620-01188 PUMP FTG union CRYO HELIUM LINE FEM/FEM
AMAT 0140-11788 Harness Assembly SRD Exhaust I/O Breakout
Two new AMAT 3700-02303, one new AMAT 3700-02046
AMAT 0040-40111 Assy, 2 Slot Tray, 200mm, Non-Enp
AMAT 3030-06445, UNIT 8160, N2, 100 SCCM, MFC 8160
AMAT 0190-37162 SMC SS5J2-60X171
AMAT 0020-10771, PERF PLATE 150MM OX, BOC EDWARDS FACE PLATE
AMAT 0020-31614, Pedestal, 6", Flat Ceramic AL, 395773
AMAT 0100-20031 PCB Assembly, 24V Monitor
AMAT 0020-20852, Heat Sink Top Cover, 395593
AMAT 0200-09661 Insert, Quartz, 200mm, Ext Cathode xtal, continuous
NEW AMAT 0190-20050 Cable assy, Nude Tube, 30 inch, 397654
AMAT 0030-09029, 0100-09084, Monitor Lightpen Interconnect, Front Bezel
AMAT 0150-02835 Cable Assembly, Transfer CH Wafer Sense, 300
6 AMAT 0021-04756 Clamp, Bolt Plate, Dual Cell, ECP
AMAT 0150-40159 Cable Assembly Remote Chamber Interface 75FT
AMAT 0020-30586 Collimator 200mm, outer shadow ring BWCVD
AMAT 0200-09085 Shield 100mm sputter Etch, looks new
2 AMAT 0040-02591 Plate, Mtg, Motorlift, Rot Head ECDP
4 AMAT 0020-06590 PIN, Base Ring, Radiance Chamber RTP
Source magnet assy, looks like AMAT 0010-03485, 300 mm PVD
AMAT 0100-20100 AI/O ANALOG I/O ASSY BOARD, REV P4
NEW AMAT 0021-08157 PAD, GAS PANEL DOOR LATCH, 300 MM TPG, 300MM
AMAT 0150-35259 C/A XFR CHMBR vent MFC pigtail
AMAT 0150-09461 Cable Assy Sacvd Chamber Lid Interlock
10 new high voltage stickers, AMAT 0060-09199
3 New AMAT 0150-40191 EMO jumper P1, EMO interlock
2 AMAT 0020-28929 Shield, 6" Low Knee, AL Arc Sparay, .25"
13 New AMAT 0680-01321 Bolt-on Circuit breaker 10A
10 New Greene Tweed Chemraz 9904-SS513, AMAT 3700-01709
NEW AMAT 0240-27870 kit gasline clamps, 0190-20130, 0250-76491
AMAT 0021-38980 AMAT PVD endura outer shield 233-2702-79,
2 New, AMAT 0050-00004 tube weldment remote final line
AMAT 0040-01114 bracket chamber rot PCB mod 1 toxic MD
3 new AMAT 0020-36221 bushing fluorozoy k 312 wafer lift
3 new AMAT 0021-38900 SPRING interlock switch BAIS RF match
3 new AMAT 0021-23119 BRKT HOME SENSOR PPR IECP
new AMAT 0150-20478 Cable assy, PVD chamber water shutoff
AMAT 1300-90011 sensor open on rise 70 C Thermal interrupt
AMAT 50304765000 Elbow F/BY - Pass EDX300MM Option
NEW AMAT 3870-04085 Parker Ball Valve XV502SS-16
NEW AMAT 0150-35394 C/A Neslab Control Centura 20 feet
2 NEW AMAT 0630-90302, 0.47UF 1KVDC Capacitor
NEW AMAT 0040-47730 Mount, UV, Application RPS on RTP TANOX
NEW AMAT 0021-36699 CLAMP SIDE FEED 1/4 LINE RTP
NEW AMAT 0150-21514 Cable Assy, Pump CVD/N2 SW
NEW AMAT 0150-76401 Cable 300mm motion control interconnect
2 NEW AMAT 3300-90963 Centering ring, ISO 160 seal
AMAT 0050-36488 Gas manifold, looks new, sell as used
AMAT 0190-89031 O-ring ID 20.30 CSD .275 VITON 75
2 new AMAT 3700-90156 O-RING ID 368 CSD 6.99
AMAT 3700-01020 ORING ID 3.484 CSD VITON 75DURO BLK
AMAT 3700-01415 ORING ID 9.225 CSD .210 SILICONE 70DURO
AMAT 0240-92689 ZA kit, retro volt dropout AE STK
AMAT 0090-77015 assy SENSOR Z-limit ZS-600 PM1
AMAT 3700-01381 ORING ID 4.484 CSD .139 VITON 75 DURO
NEW AMAT 0150-00241 Cablem Heat exchanger interface, Ktec electronics
NEW AMAT 0040-91967 FILTER FINE MESH EXTR N VALVE
AMAT 0021-07148 Bracket, Unclamp Sensor 300MM SWLL DOOR
AMAT 0040-44502 Servo Drive and PNUE Block, SWLL-A
AMAT 0140-09042 Harness, Slit, I/O and Stor Elevator, 395577
AMAT 0140-09038 Harness, Chamber C+D, Slit Open/Closed, 395580
AMAT 3300-04258 Ftg Adapter Flange ISO40 BoltedxNW50 SST
NEW AMAT 3300-90963 Centering ring with seal, ISO 160
AMAT 3700-90183 ORING BS126 34-591DX2.62VITON
AMAT 0190-89031 O-RING ID 20.30, CSD .275, VITON 75
NEW AMAT 0140-03769 Harness Assy AC Power, input, DCPS unit
AMAT 0140-04492 Pneumatic harness lead lock chamber slit valve hose
NEW AMAT 0040-90952 Resistor chain, 150 TXX 5 long, 327547
AMAT 0150-20690 Cable Assembly Printer 5500
AMAT 3300-05407 Ftg Conn 1/4" X 1/4" (SPARE FOR 0
AMAT 0150-01560 Cable External Servo Encoder control, 399312
Schroff QR06A-2EM.38.AB, AMAT 0020-91236 Fan, Tangential (MOD) Old Control Modu
13 AMAT 0021-00093 Screw, Heater Shield, 8" AXZ Plus
NEW AMAT 0140-00132 HARNESS ASSY ANEAL MOTOR BREAKERS 403647
AMAT 0040-60461 Bracket Support Ampoule Lift 300MM Tan A
AMAT 0150-00846 Cable Assy., Cell Digitl Interc., Assembly, Interconnect
2 AMAT 0190-13038 25MM x 37MM x 7MM BRG W/Braycote 1613
AMAT Robot End effector 0020-84290 REV 003
AMAT 0040-14113 ASSY COLLAR BAYONET QUARTZ HANGER
AMAT 0140-21591 HARN. ASSY.,REAR LAMP,300MM CHM
AMAT 0021-07700 COVER RH SIDE ATMOSPH ELEV
Advanced Energy 3155031-037 RF Match AMAT 1110-00056, HDP CVD Bias
NEW AMAT 0150-13142 Cable assy, FE parallel port, VDI control
new Fujikin diaphragm valve FPR-NSDB-21-6.35-APY AMAT
AMAT 0010-10013 Assembly 18" Counterbalance Arm System, AMAT 0015-09310, 400048
2 AMAT 0190-35791 MUXADIO-001 Seriplex multiplexed ADIO boards
AMAT 0090-00745, Tower Light Assy, Assembly
5 AMAT 0020-79567 Latch Keeper
2 new AMAT 0020-35084 screen roughing line transfer chamber
NEW AMAT 0021-12861 PANEL RIGHT SIDE BOTTOM CVD GASBOX
AMAT 0021-06171 Cover, Anode Connector, ECP Cell
AMAT 0020-31709, 150mm pedestal chuck oxide with flat
