Slim Borders Inotouch helps integrators to meet the growing demand matching f outer dimension
Silver Nanowire Film Inotouch advanced silver nanowire film offers excellent optical transparency,
high product quality, enabling unlimited versatility in sensor design
The Inotouch Purpose –built Sensors
A purpose-built sensor for applications that demand high-class services at realizing true slimness with high -performance
multi-touch functionality, enabling array of choices to innovative design.
Slim Borders
Inotouch advanced silver nanowire film offers excellent optical transparency, high product quality,enabling unlimited versatility in sensor design.
产品展示
基本参数
系统性能
透光率 : 86%(±2%)
输入方式 : Finger input
精确度 : >99% of true position
自动校准 : Yes
抗噪声能力 : Yes
防水 : Yes
防指纹 : Unlimited design
通用性设计 : No
机械
尺寸 : 496.6mm x 295.6mm
玻璃厚度 : 2mm
Pencil hardness rating : More than 7H(Typical)
电子
连接方式 : USB
Report Rate : max.240Hz
触摸点 : 10 points multi touch
功率消耗 : Idle mode : 240mW (240Hz)
Sleep mode : 2.5mW (20Hz)
电源连接 : USB BUS(5V
响应时间 : 20 ms
控制器
输入电源 : 3.5V~5.5V, typical 5V
工作温度 : -25° C to 80° C
存储温度 : -25° C to 80° C
相对温度 : 95% at 60° C, RH non-condensing
接口 : USB, I²C
分辨率 : 2048x2048 or more
功率消耗 : Active mode: max. 60mA
Idle mode : 8~12mA
可靠性
表面障碍物 : Withstand most surface contaminants
化学阻力 : ASTMD-F-1598-95
冲击阻力 : Steel ball test UL 60950
液体电阻 : Normal operating when remove water
Normal operating wher unwatered area
工作温度 : -10° C to 60° C
存储温度 : -20° C to 70° C
湿度 : Up to 90%RH from 0° C to 85° C
non-condensing
- 官方主页:http://inotouch.cn/
通过中国触摸屏网金牌会员认证
