特性:以软质聚氯乙烯(PVC)薄膜为基材,涂UL专用橡胶型压敏胶制造而成,具有良好的绝缘性、耐燃、耐电压、耐寒等特性。
用途:适用于集成线束、电线缠绕、绝缘保护、消磁线圈、通信配线等。
Features: PVC film as carrier, coating rubber pressure-sensitive adhesive special for UL, good insulation, Flame-resistant, voltage-resistance, cold-resistance and other properties
Usage: For integration wiring harness/electric wire winding/insulation protection/eliminate magnetic coil/Communications wiring, etc.
产品名称 Product Name |
型号 Model No |
基材 Carrier |
厚度Thickness (mm) |
抗拉力 Tensile strength (kg/25mm) |
接着力 Adhesion to steel (N/25mm) |
伸长率 Elongation at break(%) |
击穿电压VOltage resistance (KV) |
颜色 Color |
23℃、65%RH条件下有效库存期(月)validity date Months |
电气胶带electrical tape |
HY650-1 |
PVC film 乙烯膜 |
0.11 |
1.5 |
0.15 |
150 |
4.5 |
colorful |
6 |
HY650-2 |
0.13 |
2.0 |
0.15 |
160 |
5 |
6 |
HY650-3 |
0.19 |
3.5 |
0.18 |
200 |
8 |
6 |
