特性:此产品涂布上的亚克力胶水具有抗强酸、强碱特性。
用途:用于锂电池正极固定并保证粘贴后不受电解液的影响失去贴性
Features: This Acrylic glue is resistant to strong acid & alka
Usage: Fix lithium battery’s anode, protect adhesion away from influence of electrolyte.li.
产品名称Product Name |
产品型号Model No |
基材厚度 Film thickness (mm) |
总厚度 Total thickness (mm) |
粘着力Adhesiontosteel(N/25mm) |
张力强度Tensilestrength(kg/25mm) |
断裂伸长率 Elongation at break(%) |
耐温性 Temperatureresistance (℃) |
电气强度 Voltageresistance (KV) |
聚酰亚胺胶带 Polyimide tape |
HY220-1 |
0.025 |
0.05 |
10 |
10-13
45
180
5.0
HY220-2 |
0.06 |
6.5 |
