胶型:进口有机硅压敏胶 Adhesive base: imported silicone pressure sensitive adhesive
特性:具有极好的耐高温性,电绝缘性、抗化学性,及高粘着力,柔软服帖和再撕离不留残胶等特性。
用途:适用于电镀、超高温烤漆及粉末喷涂等工业。
Features: High temperature resistance, insulation, Chemical resistance, high adhesion and soft sticking
产品名称 Product Name |
产品型号 Model No |
PET 基材厚度Film thickness (mm) |
总厚度 Total thickness (mm) |
粘着力 Adhesion to steel (KG/25mm) |
张力强度 Tensile strength (kg/25mm) |
断裂伸长率 Elongation at break(%) |
耐 温 性 Temperature resistance (℃) |
电气强度 Voltage resistance (KV) |
PET高温胶带 PET high temperature tape |
HY600-1 |
0.025 |
0.04 |
0.3-0.4 |
185 |
110-120 |
200 |
5.0 |
HY600-2 |
0.028 |
0.045 |
0.3-0.4 |
189 |
120-130 |
200 |
5.5 |
HY600-3 |
0.035 |
0.06 |
0.6-0.7 |
195 |
130-135 |
200 |
6.0 |
HY600-4 |
0.005 |
0.08 |
0.5-0.6 |
180 |
135-140 |
200 |
7.0 |
HY600-5 |
0.075 |
0.1 |
0.5-0.6 |
180 |
145-150 |
200 |
9.0 |
