特性:产品易折型,耐温260℃,耐溶剂性好,剥离力佳。
用途:适用于笔记本电脑等高档产品特殊绝缘,可折型成不同形状粘贴。
Features: Easily bending products, heat resistance 260degrees, high solvent resistance, good release force
Usage: Special insulation for laptop/computer, etc. It can be bended to any shapes
产品名称 Product Name |
产品型号 Model No |
基材厚度 Film thickness (mm) |
总厚度 Total thickness (mm) |
粘着力Adhesiontosteel (N/25mm) |
张力强度 Tensilestrength (kg/25mm) |
断裂伸长率 Elongationatbreak(%) |
耐温性性Temperatureresistance (℃) |
电气强度 Voltage resistance (KV) |
双面聚酰亚胺胶带 Polyimide tape |
HY240-1 |
0.025 |
0.1 |
5.0 |
10-13 |
45 |
260 |
5.0 |
HY240-2 |
0.05 |
0.15 |
5.5 |
19-22 |
50 |
260 |
7.0 |
HY240-3 |
0.075 |
0.2 |
5.5 |
20-23 |
55 |
260 |
9.0 |
