常用颜色:琥珀色(特殊可做黑色),管芯可做76mm和38mm
特性:耐高温硅胶,耐高温,高绝缘,耐酸碱,低电解等。
用途:用于PCB制程过焊锡炉时保护金手指及电子线圈的绝缘,波峰焊保护,电气绝缘,耐高温等领域。胶带撕除后不留残胶。
Color: heat resistance silicone, Amber(black is customized), Roll core can be made as 76mm and 38mm
Features: Heat resistance, High Voltage insulation, acid and alkali resistant, low voltage electrolytic
Usage: Protect golden finger when PCB board in soldering tin furnace, ,insulation of coil, wave-soldering protection, electrical insulation, high temperature resistance, etc. No residue leaving after peeling off.
产品名称 Product Name |
产品型号 Model No |
基材厚度Carrier thickness(mm) |
总厚度 Total thickness(mm) |
粘着力Adhesion to steel (N/25mm) |
张力强度Tensile strength (kg/25mm) |
断裂伸长率 Elongation at break(%) |
高温性) Temperature Resistance (℃) |
电 气 强 度 Voltage resistance(KV) |
聚酰亚胺胶带 Polyimide tape |
HY200-1A |
0.015 |
0.030 |
2.8 |
10 |
25-35 |
260 |
2.5 |
HY200-1B |
0.015 |
0.035 |
3.5 |
10 |
25-35 |
2.5 |
HY200-2A |
0.025 |
0.042 |
2.5-3.5 |
10-13 |
45 |
5.0 |
HY200-2B |
0.025 |
0.050 |
4.0 |
10-13 |
45 |
5.0 |
HY200-2C |
0.025 |
0.055 |
5.0 |
10-13 |
45 |
5.0 |
HY200-2D |
0.025 |
0.06 |
5.5 |
10-13 |
45 |
5.0 |
HY200-2E |
0.025 |
0.065 |
6.0 |
10-13 |
45 |
5.0 |
HY200-2F |
0.025 |
0.070 |
6.5 |
10-13 |
45 |
5.0 |
HY200-3A |
0.05 |
0.08 |
6.0 |
20 |
55-65 |
7.0 |
HY200-3B |
0.05 |
0.10 |
6.5 |
20 |
55-65 |
7.0 |
HY200-4 |
0.075 |
0.12 |
6 |
28 |
60-65 |
9.0 |
HY200-5 |
0. 10 |
0.15 |
6 |
36 |
70-75 |
10.5 |
HY200-6 |
0.125 |
0.18 |
6 |
40 |
80-85 |
12 |
HY200-2DA |
0.025 |
0.06 |
5.0 |
10-13 |
45 |
5.0 |
HY200-2DB |
0.025 |
0.06 |
5.0 |
10-13 |
45 |
5.0 |
