特性:耐溶剂性特佳,服贴性好,表面防静电处理。
用途:用于PCB制程过焊锡炉时保护金手指及电子线圈的绝缘,波峰焊保护,电气绝缘,耐高温等领域。胶带撕除后不留残胶。
Features: High solvent resistance, Anti-static treatment on surface
Usage: Protect golden finger when PCB board in soldering tin furnace, insulation of coil, wave-soldering protection, electrical insulation, high temperature resistance, etc. No residue leaving after tape removed.
产品名称 Product Name |
产品型号Model No |
基材厚度 Carrier thickness (mm) |
总厚 Total thickness (mm) |
粘着力Adhesion to steel (N/25mm) |
张力强度 Tensile strength (kg/25mm) |
断裂伸长率 Elongation at break (%) |
耐温性 Temperature resistance(℃) |
表面电阻范围 surface Resistance (Ω) |
防静电聚酰亚胺胶带Anti-static polyimide tape |
HY210-1 |
0.025 |
0.06 |
5.5 |
10-13 |
45 |
260 |
106-1011 |
HY210-2 |
0.050 |
0.08 |
5.5 |
20 |
55 |
260 |
106-1011 |
