特性:电镀蓝胶带是采用PVC薄膜涂特殊亚克力胶水组成,具有耐酸碱、抗腐蚀、清除时不残胶.
用途:PCB电镀时必要的保护.
Features:PVC film coating special Acrylic glue, Acid&alkali resistance, corrosion resistance, no residue after peeling off
Usage: Necessary protection of PCB electroplating.
产品名称 Product |
型号 Model No. |
厚度Thick Ness (mm) |
粘着力Adhesion to steel (N/25mm) |
抗拉力 Tensile strength (kg/25mm) |
断裂伸长率 Elongation at break (%) |
耐温性 Heat resistance (℃) |
PVC电镀蓝膜 |
HY640 |
0.11 |
0.05 |
2.1 |
150% |
80℃/0.5H |
