基材:高温美纹胶带,以美纹纸为基材,按照耐温要求涂布进口橡胶,硅胶等,已达到需求效果。
特性:此类产品具有耐温性佳,强度高,撕下后不留残胶等特点。
Carrier: Crepe paper as carrier, coating imported rubber/silicone according to heat resistance, to reach effectiveness
Usage: These kinds of products are with high heat resistance, high strength, no residue after tearing off and other features.
名称 Name |
型号 Model No |
基材 Carrier |
厚度 Thickness (mm) |
胶系 Adhesive base |
抗拉力 Tensile strength |
伸长率 Elongation at break |
耐 温 性 Heat Resistance (℃) |
特性与应用 Application |
美纹纸胶带 Crepe paper tape |
HY520-4 |
美纹纸 Crepe paper |
0.13 |
橡胶 Rubber |
100 |
8% |
60 |
HY520-5 |
0.16 |
110 |
8% |
100 |
HY520-6 |
0.16 |
110 |
8% |
160 |
