特性:本产品具有耐温性好(-50℃-260℃)、粘性力强,强韧耐撕等特性、应用于H级耐热绝缘绑扎、
各种高温喷沙保护和锂锰电池绝缘包扎等高强度绝缘保护。胶带性价比特别高,
胶带使用在性能上完全可以替代3M-69#/P212/TESA4618等,进口玻璃布胶带。
用途:适用于变压器、高温设备、空调接触器,线圈包扎及马达等其它高温特殊环境应用
Features: Good heat-resistance(-50℃-260℃)/ high adhesion, strong tear resistance and other properties, for Class H heat resistance&insulation bonding/insulation bonding of sandblasting protection and lithium manganese batteries under high temperature. Tape with high cost performance, Perfectly replac 3M-69#/P212/TESA4618,etc
Usage: For insulation & heat resistance of air-condition electric appliance, cartronics, digital electronics. Also for electroplating, ultra high temperature painting and powder coating industries
产品名称 Product Name |
产品型号 Model No |
基材厚度 Film thickness (mm) |
总厚度 Total thickness (mm) |
粘着力 Adhesion to steel (N/25mm) |
张力强度 Tensile strength (kg/25mm) |
断裂伸长率 Elongation at break(%) |
耐 温 性 Heat Resistance (℃) |
电气强度 Voltage resistance (KV) |
玻璃布胶带glass fabric tape |
HY420-1 |
0.1 |
0.19 |
8 |
380 |
5 |
260 |
2.5 |
双面玻璃布胶带double-sided glass fabric tape |
HY420-2 |
0.1 |
0.22 |
6 |
380 |
5 |
260 |
2.5 |
