特性:采用进口优质醋酸纤维为基材,具有耐高温、耐溶剂、抗老化、可印刷、性能稳定可靠的特点。
用途:广泛作为电子工业中变压器、马达、线圈电容器及线束、变频电源供应器等缠绕用之绝缘材料,
通过SGS环保检测、美国UL认证。
Feature: Material:cellulose acetate fiber, high temperature resistance, solvent resistance,
ageing resistance, Printable, stable performance.
Usage: It's used in Electrical industries, Insulation of transformer/motor/Condenser coil/power supplier, etc.
All products are with SGS, RoHS, UL certifications.
产品名称 Product Name |
产品型号Model No. |
基材厚度 Film thickness (mm) |
总厚度 Total thickness (mm) |
粘着力 Adhesion to steel (N/25mm) |
张力强度 Tensile strength (kg/25mm) |
断裂伸长率 Elongation (%) |
耐 温 性 Heat Resistance (℃) |
电气强度 Voltage resistance (KV) |
醋酸布胶带(白/黑)Acetic acid cloth tape White/Black |
HY410-1/2 |
0.17 |
0.22 |
11 |
135 |
20 |
130 |
3.6 |
