特性: 表面光滑,有着良好的抗粘性,耐化学腐蚀和耐高温性以及优良的绝缘性。
用途:适用于包装、热塑、复合、封口热合、电子电器等热封包装机械发热部位及各种高温情况的防粘防腐部位的粘帖使用
Features: Smooth surface, good adhesive, chemical corrosion resistance,
high temperature resistance and good insulation. (Brown /White /Black)
Usage: For packing/thermoplastic/composite/heat-sealing, electronics electric and sticking for other heat-sealing packing machinery’s heat parts & Anti-sticking anticorrosive parts under high temperature.
产品名称 Product Name |
产品型号Model No |
厚度 Thickness(mm) |
最大宽幅 Max width (mm) |
粘附强度(对钢) Adhesion to steel (N/100mm) |
抗拉强度Tensile strength (N/100mm) |
耐 温 性Heat Resistance(℃) |
铁氟龙胶带 Teflon tape |
HY660-1 |
0.08 |
1250 mm |
22 N/100mm |
900 |
-70~260℃
HY660-2 |
0.13 |
28 N/100mm |
1700 |
HY660-3 |
0.18 |
48 N/100mm |
2750 |
HY660-4 |
0.25 |
62 N/100mm |
3650 |
