6ES7 416-5HS06-0AB0
CPU 416-5H PN/DP
General information
Hardware product version
1
Firmware version
V6.0
CiR - Configuration in RUN
CiR synchronization time, basic load
100 ms
CiR synchronization time, time per I/O slave
0 µs
Supply voltage
24 V DC
No; Power supply via system power supply
Input current
from backplane bus 5 V DC, typ.
1.6 A
from backplane bus 5 V DC, max.
1.9 A
from backplane bus 24 V DC, max.
150 mA; 150 mA per DP interface
from interface 5 V DC, max.
90 mA; At each DP interface
Power losses
Power loss, typ.
7.5 W
Memory
Type of memory
other
Work memory
16 Mbyte
6 Mbyte
10 Mbyte
No
Load memory
Yes; with Memory Card (FLASH)
64 Mbyte
1 Mbyte
Yes
64 Mbyte
Backup
Yes
Yes; all data
No
Battery
Backup battery
180 µA; Valid up to 40°C
1 000 µA
Dealt with in the module data manual with the secondary conditions and the factors of influence
- Feeding of external backup voltage to CPU
5 to 15 VDC
CPU processing times
for bit operations, typ.
12.5 ns
for word operations, typ.
12.5 ns
for fixed point arithmetic, typ.
12.5 ns
for floating point arithmetic, typ.
25 ns
CPU-blocks
DB
16 000
64 kbyte
FB
8 000
64 kbyte
FC
8 000; Number range: 0 to 7999
64 kbyte
OB
64 kbyte
1
8
- Number of delay alarm OBs
4
- Number of time interrupt OBs
9
- Number of process alarm OBs
8
3; OB 55-57
2
- Number of asynchronous error OBs
9
- Number of synchronous error OBs
2
Nesting depth
24
- additional within an error OB
2
Counters, timers and their retentivity
S7 counter
2 048
Yes
0
2 047
Z 0 to Z 7
0
999
IEC counter
Yes
SFB
Unlimited (limited only by RAM capacity)
S7 times
2 048
Yes
0
2 047
No times retentive
10 ms
9 990 s
IEC timer
Yes
SFB
Data areas and their retentivity
retentive data area, total
Total working and load memory (with backup battery)
Flag
16 384 byte
Yes
MB 0 to MB 15
8; in 1 memory byte
Data blocks
16 000; Number range: 1 to 16000
64 kbyte
Local data
64 kbyte
32 kbyte
Address area
I/O address area
16 kbyte
16 kbyte
2 kbyte
- MPI/DP interface, outputs
2 kbyte
8 kbyte
8 kbyte
8 kbyte
8 kbyte
Process image
16 kbyte
16 kbyte
1 024 byte
1 024 byte
244 byte
- Access to consistent data in process image
Yes
Subprocess images
- Number of subprocess images, max.
15
Digital channels
131 072
131 072
131 072
- Outputs, of which central
131 072
Analog channels
8 192
8 192
8 192
8 192
Hardware configuration
Expansion devices, max.
21
connectable OPs
95
Multicomputing
No
Interface modules
- Number of connectable IMs (total), max.
6
- Number of connectable IM 460s, max.
6
- Number of connectable IM 463s, max.
4; Single mode only
Number of DP masters
2
10; CP 443-5 Extended
- Mixed mode IM + CP permitted
No
0
Number of IO Controllers
1
0
Number of operable FMs and CPs (recommended)
See manual Automation System S7-400H fault-tolerant systems. Limited by number of slots and number of connections
- PROFIBUS and Ethernet CPs
14; Of which max. 10 CP as DP master
Slots
2
Time of day
Clock
- Hardware clock (real-time clock)
Yes
- battery-backed and synchronizable
Yes
1 ms
- Deviation per day (buffered), max.
1.7 s; Power off
- Deviation per day (unbuffered) max.
8.6 s; Power on
Operating hours counter
16
0 to 15
SFCs 2, 3 and 4: 0 to 32767 hours SFC 101: 0 to 2^31 - 1 hours
1 hour
Yes
Clock synchronization
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes; as client
Time difference in system when synchronizing via
10 ms; Via NTP
200 ms
Interfaces
Number of USB interfaces
0
Number of parallel interfaces
0
Number of 20 mA interfaces (TTY)
0
Number of RS 232 interfaces
0
Number of RS 422 interfaces
0
Number of other interfaces
2; Fiber-optic interface
1st interface
Interface type
integrated
Physics
RS 485 / PROFIBUS + MPI
Isolated
Yes
Power supply to interface (15 to 30 V DC), max.
150 mA
Number of connection resources
MPI: 44, DP: 32
Functionality
Yes
Yes
No
MPI
44; If a diagnostics repeater is used on the line, the number of connection resources on the line is reduced by 1
12 Mbit/s
Yes
Yes
- Global data communication
No
No
Yes
- S7 communication, as client
Yes
- S7 communication, as server
Yes
DP master
- Number of connections, max.
32; If a diagnostics repeater is used on the line, the number of connection resources on the line is reduced by 1
12 Mbit/s
- Number of DP slaves, max.
32
Yes
Yes
No
No
Yes
Yes
Yes
- Equidistance mode support
No
No
No
- Activation/deactivation of DP slaves
No
- Direct data exchange (slave-to-slave communication)
No
Yes
2 kbyte
2 kbyte
- User data per DP slave, max.
244 byte
244 byte
244 byte
244
128 byte
DP slave
No configuration of CPU as DP slave
2nd interface
Interface type
PROFINET
Physics
Ethernet RJ45
Isolated
Yes
Integrated switch
Yes
Number of ports
2
Automatic detection of transmission speed
Yes; Autosensing
Autonegotiation
Yes
Autocrossing
Yes
Change of IP address at runtime, supported
No
96
Media redundancy
Yes
- Switchover time on line break, typically
200 ms
- Number of stations in the ring, max.
50
Functionality
No
No
Yes
No
No
Yes
No
- Point-to-point connection
No
PROFINET IO Controller
100 Mbit/s
- Number of connectable IO devices, max.
256; In redundant mode via both interfaces
- Max. number of connectable IO devices for RT
256
256
Yes; Single mode only
- Prioritized startup supported
No
- Activation/deactivation of IO Devices
No
- IO Devices changing during operation (partner ports), supported
No
- Device replacement without swap medium
Yes
250 µs, 500 µs, 1 ms, 2 ms, 4 ms
250 µs to 512 ms, minimum value depends on the number of configured user data and the configured single or redundant mode
Yes
Yes
Yes
No
Yes
8 kbyte
8 kbyte
- User data consistency, max.
1 024 byte
Open IE communication
- Open IE communication, supported
Yes
94
- Local port numbers used at the system end
0, 20, 21, 25, 102, 135, 161, 34962, 34963, 34964, 65532, 65533, 65534, 65535
- Keep-alive function, supported
Yes
3rd interface
Interface type
integrated
Physics
RS 485 / PROFIBUS
150 mA
32
Functionality
Yes
No
DP master
32
9.6 kbit/s
12 Mbit/s
125
Yes
Yes
No
No
Yes
Yes
Yes
No
No
No
No
No
Yes
Yes
8 kbyte
8 kbyte
244 byte
244 byte
244 byte
244
128 byte
4th interface
Interface type
Pluggable synchronization submodule (FO)
Plug-in interface modules
Synchronization modules 6ES7960-1AA06-0XA0 or 6ES7960-1AB06-0XA0
5. Interface
Interface type
Isochronous mode
Isochronous operation (application synchronized up to terminal)
No
equidistance
No
Communication functions
PG/OP communication
Yes
- Number of connectable OPs without message processing
95
- Number of connectable OPs with message processing
95; When using Alarm_S/SQ and Alarm_D/DQ
Data record routing
Yes
S7 routing
Yes
No
S7 basic communication
No
S7 communication
Yes
Yes
Yes
64 kbyte
- User data per job (of which consistent), max.
462 byte; 1 variable
S5-compatible communication
Yes; (via CP max. 10 and FC AG_SEND and FC AG_RECV)
8 kbyte
240 byte
- Number of simultaneous AG-SEND/AG-RECV orders per CPU, max.
64/64
Standard communication (FMS)
Yes; Via CP and loadable FB
Yes; via integrated PROFINET interface and loadable FBs
94
32 kbyte
- Several passive connections per port, supported
Yes
Yes; Via integrated PROFINET interface or CP 443-1 and loadable FBs
94
32 kbyte; 1452 bytes via CP 443-1 Adv.
94
1 472 byte
Web server
No
96
- usable for PG communication
- reserved for PG communication
1
- Adjustable for PG communication, max.
0
- usable for OP communication
- reserved for OP communication
1
- adjustable for OP communication, max.
0
- usable for S7 basic communication
- Reserved for S7 basic communication
0
- adjustable for S7 basic communication, max.
0
- usable for S7 communication
- reserved for S7 communication
0
- Adjustable for S7 communication, max.
0
0
- adjustable for routing, max.
0
S7 message functions
Number of login stations for message functions, max.
95; Max. 95 with Alarm_S/SQ and Alarm_D/DQ (OPs); max. 8 with Alarm, Alarm_8, Alarm_8P, Notify and Notify_8 (e.g. WinCC)
Symbol-related messages
No
SCAN procedure
No
Block related messages
Yes
Process diagnostic messages
Yes
simultaneously active Alarm-S blocks, max.
1 000; Simultaneously active alarm_S/SQ blocks or alarm_D/DQ blocks
Alarm 8-blocks
Yes
- Number of instances for alarm 8 and S7 communication blocks, max.
10 000
1 200
Process control messages
Yes
Number of archives that can log on simultaneously (SFB 37 AR_SEND)
64
Test commissioning functions
Status block
Yes
Single step
Yes
Number of breakpoints
16
Status/control
Yes; Up to 16 variable tables
Inputs/outputs, memory bits, DBs, distributed I/Os, timers, counters
- Number of variables, max.
70
Forcing
Yes
Inputs/outputs, bit memories, distributed I/Os
512
Diagnostic buffer
Yes
3 200
Yes
120
Service data
Yes
EMC
Emission of radio interference acc. to EN 55 011
- Limit class A, for use in industrial areas
Yes
- Limit class B, for use in residential areas
No
Configuration
Configuration software
Yes
programming
see instruction list
7
Yes
- System function blocks (SFB)
Yes
Yes
Yes
Yes
Yes
Yes
Yes
- Number of simultaneously active SFCs
8
8
8
1
2
8
8
1
- Number of simultaneously active SFBs
8
8
Know-how protection
- User program protection/password protection
Yes
Yes; With S7 block Privacy
Dimensions
Width
50 mm
Height
290 mm
Depth
219 mm
Weights
Weight, approx.
995 g
