- 高端性能范围内的高性能 CPU
- 适用于对性能要求很高的工厂
- CPU 416-3 PN/DP 中集成了 PROFINET 功能
Area of application
CPU 416-2, CPU 416-3 and CPU 416-3 PN/DP are powerful SIMATIC S7-400 CPUs.
The integrated PROFIBUS DP interfaces in the CPU 416-2 and CPU 416-3 make it possible to connect directly to the PROFIBUS DP fieldbus as a master or slave.
An additional DP master system can be connected to the CPU 416-3 and CPU 416-3 PN/DP using the IF 964-DP interface module.
The integrated PROFINET interface of the CPU 416-3 PN/DP includes switch functionality when the ERTEC 400-ASIC is used. This forms the basis for providing two externally accessible PROFINET ports. In addition to hierarchical network topologies, this also enables the creation of line structures in the new S7-400 controllers.
Note:
Only the 6ES7 964-2AA04-0AB0 interface submodule may be used.
Design
Both CPUs are equipped with the following:
- Powerful processor:
The CPUs achieve instruction execution times as low as 0.03 µs per binary instruction. - CPU 416-2: 5.6 MB RAM (of which 2.8 MB each for program and data);
CPU 416-3: 11.2 MB RAM (of which 5.6 MB each for program and data);
CPU 416-3 PN/DP: 11.2 MB RAM (of which 5.6 MB each for program and data);
fast RAM for parts of the user program relevant to execution. - Flexible expansion:
Up to 262144 digital and 16384 analog inputs/outputs. - Multi-point interface MPI:
With the MPI it is possible to establish simple networking of max. 32 stations at a data transmission rate of up to 12 Mbit/s. The CPUs can establish up to 44 connections to stations of the communications bus (C bus) and the MPI. - Mode selector switch:
Designed as toggle switch. - Diagnostics buffer:
The last 120 fault and interrupt events are retained in a ring buffer for diagnostic purposes. The number of entries can be parameterized. - Real-time clock:
The date and time are appended to diagnostic messages of the CPU. - Memory card:
For expansion of the integrated load memory. RAM and FEPROM cards (FEPROM for retentive storage) are available - Combined MPI/DP interface and integrated PROFIBUS DP interface (CPU 416-2 and CPU 416-3):
The PROFIBUS DP master interface allows a distributed automation configuration offering high speed and ease of use. From the user's point of view, the distributed I/O is treated as central I/O (same configuring, addressing and programming).
Mixed configuration: SIMATIC S5 and SIMATIC S7 as PROFIBUS master according to EN 50170.
CPU 416-3 and CPU 416-3 PN/DP also include:
- A module slot:
An additional PROFIBUS DP master system can be connected via the IF 964-DP interface module.
CPU 416-3 PN/DP additionally includes:
- PROFINET interface with 2 ports (switch):
- PROFINET I/O, 256 IO devices connectable
- PROFINET CBA
Functions
- Block protection:
A password concept protects the user program from unauthorized access. - Integral HMI services:
The user only has to specify the source and destination of the data with HMI devices. The data are then transported cyclically and automatically by the system. - Integrated communications functions:
- PG/OP communication
- Shared data communication
- S7 standard communication
- S7 communication
- Firmware update using network
CPU 416-3 PN/DP additional:
- Open communication over TCP/IP, UDP and ISO-on-TCP (RFC1006)
- Distributed intelligence in Component Based Automation (CBA) on PROFINET
- Additional diagnostic options with integrated web server
Parameterizable attributes
The STEP 7 tool "Hardware Configuration" can be used to program the properties and response of the S7-400 including the CPUs, e.g.
- Definition of station addresses.
- Startup/cycle behavior
- Stipulation of the maximum cycle time and communications load
- Address assignment:
Addressing of I/O modules. - Retentive ranges:
Definition of the number of retentive bit memories, counters, timers, data blocks and clock memories. - Size of the process image, local data.
- Length of the diagnostics buffer
- Protection level:
Definition of access authorization for program and data - System diagnostics:
Definition of the handling and scope of diagnostic messages - Timed interrupts:
Setting of periodicity
- Parameterization of time synchronization using NTP procedure
Indication and information functions
- Status and error indicators:
LEDs indicate internal and external errors and operating states such as RUN, STOP, Restart, Test function, for example - Test functions:
The programming device can be used to display signal states in program execution, modify process tags irrespective of the user program, read out the contents of stack memories, run separate program steps and inhibit program components - Information functions:
The programming device can be used to provide the user with information on the memory capacity and operating mode of the CPU and the current utilization of the working and load memories
Technical Specifications
6ES7 416-2XN05-0AB0 |
6ES7 416-3XR05-0AB0 |
6ES7 416-3ES06-0AB0 |
CPU 416-2 |
CPU 416-3 |
CPU416-3 PN/DP |
General information |
Hardware product version |
04 |
04 |
01 |
Firmware version |
V5.3 |
V5.3 |
V6.0 |
CiR - Configuration in RUN |
CiR synchronization time, basic load |
100 ms |
100 ms |
100 ms |
CiR synchronization time, time per I/O slave |
10 µs |
10 µs |
10 µs; Time per I/O byte |
Supply voltage |
24 V DC |
No; Power supply via system power supply |
Input current |
from CPU, max. |
Not relevant for 400 series (300 series set) |
from backplane bus 5 V DC, typ. |
0.9 A |
1.1 A |
1.3 A |
from backplane bus 5 V DC, max. |
1.1 A |
1.3 A |
1.5 A |
from backplane bus 24 V DC, max. |
300 mA; 150 mA per DP interface |
450 mA; 150 mA per DP interface |
from interface 5 V DC, max. |
90 mA; At each DP interface |
Power losses |
Power loss, typ. |
4.5 W |
5.5 W |
6.5 W |
Power loss, max. |
5 W |
6 W |
7.5 W |
Memory |
Type of memory |
RAM |
RAM |
RAM |
Work memory |
5.6 Mbyte |
11.2 Mbyte |
16 Mbyte |
2.8 Mbyte |
5.6 Mbyte |
8 Mbyte |
2.8 Mbyte |
5.6 Mbyte |
8 Mbyte |
No |
No |
No |
Load memory |
Yes; with Memory Card (FLASH) |
64 Mbyte |
64 Mbyte |
64 Mbyte |
1 Mbyte |
1 Mbyte |
1 Mbyte |
Yes; with Memory Card (RAM) |
64 Mbyte |
64 Mbyte |
64 Mbyte |
Backup |
Yes |
Yes |
Yes |
Yes; all data |
Yes; all data |
Yes; all data |
No |
No |
No |
Battery |
Backup battery |
Not relevant |
Not relevant |
Not relevant |
125 µA; (up to 40 °C) |
550 µA |
550 µA |
450 µA |
See reference manual, module data, Chapter 3.3 |
Dealt with in the module data manual with the secondary conditions and the factors of influence |
5 to 15 VDC |
5 to 15 VDC |
5 to 15 VDC |
CPU processing times |
for bit operations, typ. |
30 ns |
30 ns |
30 ns |
for word operations, typ. |
30 ns |
30 ns |
30 ns |
for fixed point arithmetic, typ. |
30 ns |
30 ns |
30 ns |
for floating point arithmetic, typ. |
90 ns |
90 ns |
90 ns |
CPU-blocks |
DB |
10 000 |
10 000 |
10 000 |
64 kbyte |
64 kbyte |
64 kbyte |
FB |
5 000 |
5 000 |
5 000 |
64 kbyte |
64 kbyte |
64 kbyte |
FC |
5 000; Number range: 0 to 7999 |
64 kbyte |
64 kbyte |
64 kbyte |
OB |
64 kbyte |
64 kbyte |
64 kbyte |
1 |
1 |
1 |
8 |
8 |
8 |
4 |
4 |
4 |
9 |
9 |
9 |
8 |
8 |
8 |
3; OB 55-57 |
3; OB 55-57 |
3; OB 55-57 |
4; OB 61-64 |
4; OB 61-64 |
4; OB 61-64 |
1; OB 60 |
1; OB 60 |
1; OB 60 |
1; OB 90 |
1; OB 90 |
1; OB 90 |
3 |
3 |
3 |
9 |
9 |
9 |
2 |
2 |
2 |
Nesting depth |
24 |
24 |
24 |
2 |
2 |
2 |
Counters, timers and their retentivity |
S7 counter |
2 048 |
2 048 |
2 048 |
Yes |
Yes |
Yes |
0 |
0 |
0 |
2 047 |
2 047 |
2 047 |
Z 0 to Z 7 |
Z 0 to Z 7 |
Z 0 to Z 7 |
0 |
0 |
0 |
999 |
999 |
999 |
IEC counter |
Yes |
Yes |
Yes |
SFB |
SFB |
SFB |
Unlimited (limited only by RAM capacity) |
S7 times |
2 048 |
2 048 |
2 048 |
Yes |
Yes |
Yes |
0 |
0 |
0 |
2 047 |
2 047 |
2 047 |
No times retentive |
10 ms |
10 ms |
10 ms |
9 990 s |
9 990 s |
9 990 s |
IEC timer |
Yes |
Yes |
Yes |
SFB |
SFB |
SFB |
Data areas and their retentivity |
retentive data area, total |
Total working and load memory (with backup battery) |
Flag |
16 kbyte; Size of bit memory address area |
Yes |
Yes |
Yes |
MB 0 to MB 15 |
MB 0 to MB 15 |
MB 0 to MB 15 |
8; in 1 memory byte |
Data blocks |
10 000; Number range: 1 to 16000 |
64 kbyte |
64 kbyte |
64 kbyte |
Local data |
32 kbyte |
32 kbyte |
32 kbyte |
16 kbyte |
16 kbyte |
16 kbyte |
Address area |
I/O address area |
16 kbyte |
16 kbyte |
16 kbyte |
16 kbyte |
16 kbyte |
16 kbyte |
2 kbyte |
2 kbyte |
2 kbyte |
2 kbyte |
2 kbyte |
2 kbyte |
8 kbyte |
8 kbyte |
8 kbyte |
8 kbyte |
8 kbyte |
8 kbyte |
8 kbyte |
8 kbyte |
Process image |
16 kbyte |
16 kbyte |
16 kbyte |
16 kbyte |
16 kbyte |
16 kbyte |
512 byte |
512 byte |
512 byte |
512 byte |
512 byte |
512 byte |
244 byte |
244 byte |
244 byte |
Yes |
Yes |
Yes |
Subprocess images |
15 |
15 |
15 |
Digital channels |
131 072 |
131 072 |
131 072 |
131 072 |
131 072 |
131 072 |
131 072 |
131 072 |
131 072 |
131 072 |
131 072 |
131 072 |
Analog channels |
8 192 |
8 192 |
8 192 |
8 192 |
8 192 |
8 192 |
8 192 |
8 192 |
8 192 |
8 192 |
8 192 |
8 192 |
Hardware configuration |
Expansion devices, max. |
21 |
21 |
21 |
connectable OPs |
63 |
63 |
95 |
Multicomputing |
Yes; 4 CPUs max. (with UR1 or UR2) |
Interface modules |
6 |
6 |
6 |
6 |
6 |
6 |
4; IM 463-2 |
4; IM 463-2 |
4; IM 463-2 |
Number of DP masters |
2 |
2 |
1 |
4 |
4 |
4 |
10; CP 443-5 Extended |
No; IM 467 not suitable for use with CP 443-5 Ext. and CP443-1 EX4x, EX20, GX20 (in PNIO mode) |
0 |
1 |
1; IF 964-DP |
6 |
6 |
6 |
Number of IO Controllers |
0 |
0 |
1 |
4; No mixed operation of CP443-1 EX40 and CP443-1 EX 41/EX20/GX20, max. 4 in central controller |
Number of operable FMs and CPs (recommended) |
Limited by number of slots and number of connections |
Limited by number of slots or number of connections |
CP 440: Limited by number of slots; CP 441: limited by number of connections |
CP 440: Limited by number of slots; CP 441: Limited by number of slots and number of connections |
14 |
14 |
14 |
Slots |
1 |
2 |
2 |
Time of day |
Clock |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
1 ms |
1 ms |
1 ms |
1.7 s; Power off |
1.7 s; Power off |
1.7 s; Power off |
8.6 s; For power On |
Operating hours counter |
16 |
16 |
16 |
0 to 15 |
0 to 15 |
0 to 15 |
SFCs 2, 3 and 4: 0 to 32767 hours SFC 101: 0 to 2^31 - 1 hours |
1 hour |
1 hour |
1 hour |
Yes |
Yes |
Yes |
Clock synchronization |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No; via CP |
No; via CP |
Yes; as client |
No |
Yes |
Yes |
Time difference in system when synchronizing via |
10 ms |
200 ms |
200 ms |
200 ms |
Digital outputs |
integrated channels (DO) |
0 |
0 |
0 |
Interfaces |
Interfaces |
1 x MPI/PROFIBUS DP, 1 x PROFIBUS DP |
1 x MPI/PROFIBUS DP, 1 x PROFIBUS DP, 1 x PROFIBUS DP (optionally pluggable) |
1 x MPI/PROFIBUS DP, 1 x PROFINET (2 ports), 1 x PROFIBUS DP (optionally pluggable) |
Number of USB interfaces |
0 |
0 |
0 |
Number of parallel interfaces |
0 |
0 |
0 |
Number of 20 mA interfaces (TTY) |
0 |
0 |
0 |
Number of RS 232 interfaces |
0 |
0 |
0 |
Number of RS 422 interfaces |
0 |
0 |
0 |
Number of other interfaces |
0 |
0 |
0 |
1st interface |
Interface type |
integrated |
integrated |
integrated |
Physics |
RS 485 / PROFIBUS + MPI |
Isolated |
Yes |
Yes |
Yes |
Power supply to interface (15 to 30 V DC), max. |
150 mA |
150 mA |
150 mA |
Number of connection resources |
MPI: 44, DP: 32 |
MPI: 44, DP: 32 |
MPI: 44, DP: 32 |
Functionality |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MPI |
44; If a diagnostics repeater is used on the line, the number of connection resources on the line is reduced by 1 |
12 Mbit/s |
12 Mbit/s |
12 Mbit/s |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
DP master |
32; If a diagnostics repeater is used on the line, the number of connection resources on the line is reduced by 1 |
12 Mbit/s |
12 Mbit/s |
12 Mbit/s |
32 |
32 |
32 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
2 kbyte |
2 kbyte |
2 kbyte |
2 kbyte |
2 kbyte |
2 kbyte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 |
244 |
244 |
128 byte |
128 byte |
128 byte |
DP slave |
32 |
32 |
32 |
http://support.automation.siemens.com/WW/view/de/113652 |
12 Mbit/s |
12 Mbit/s |
12 Mbit/s |
No |
No |
No |
32; Virtual slots |
32; Virtual slots |
32; Virtual slots |
32 byte |
32 byte |
32 byte |
32 byte |
32 byte |
32 byte |
Yes; with interface active |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
No |
No |
No |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
2nd interface |
Interface type |
integrated |
integrated |
PROFINET |
Physics |
RS 485 / PROFIBUS |
RS 485 / PROFIBUS |
Ethernet RJ45 |
Isolated |
Yes |
Yes |
Yes |
Integrated switch |
Yes |
Number of ports |
2 |
150 mA |
150 mA |
Automatic detection of transmission speed |
Yes; Autosensing |
Autonegotiation |
Yes |
Autocrossing |
Yes |
Change of IP address at runtime, supported |
Yes; Assignment by higher-level IO-Controller or by the user program with SFB104 "IP_CONF" |
32 |
32 |
96 |
Media redundancy |
Yes |
200 ms |
50 |
Functionality |
Yes |
Yes |
No |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
5 |
No |
DP master |
32 |
32 |
12 Mbit/s |
12 Mbit/s |
125 |
125 |
Yes |
Yes |
Yes |
Yes |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
8 kbyte |
8 kbyte |
8 kbyte |
8 kbyte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 |
244 |
128 byte |
128 byte |
DP slave |
32 |
32 |
12 Mbit/s |
12 Mbit/s |
32 |
32 |
32 byte |
32 byte |
32 byte |
32 byte |
Yes |
Yes |
244 byte |
244 byte |
244 byte |
244 byte |
PROFINET IO Controller |
100 Mbit/s |
256 |
256 |
256 |
256 |
61 |
64 |
64 |
Yes |
Yes |
32 |
Yes |
8 |
Yes |
8; 8 parallel calls of the SFC 12 "D_ACT_DP" possible per line. Max. 32 IO Devices changing during operation (partner ports) are supported. |
Yes |
250 μs, 500 μs, 1 ms, 2 ms, 4 ms additionally with IRT with high performance: 250 µs to 4 ms in 125 µs |
250 µs to 512 ms; minimum value depends on preset communication share for PROFINET IO, on the number of IO Devices and on the amount of configured user data, see PROFINET system de |
Yes |
Yes |
Yes |
Yes; Only with IRT and the High Performance option |
Yes |
8 kbyte |
8 kbyte |
1 024 byte |
PROFINET IO Device |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
2 |
1 440 byte; Per IO Controller with shared device |
64 |
1 024 byte |
PROFINET CBA |
Yes |
Yes |
Open IE communication |
Yes |
94 |
0, 20, 21, 25, 80, 102, 135, 161, 34962, 34963, 34964, 65532, 65533, 65534, 65535 |
Yes |
3rd interface |
Interface type |
Pluggable interface module (IF), technical data as for 2nd interface |
Pluggable interface module (IF) |
Plug-in interface modules |
IF 964-DP (MLFB: 6ES7964-2AA04-0AB0) |
Physics |
RS 485 / PROFIBUS |
RS 485 / PROFIBUS |
Isolated |
Yes |
Yes |
150 mA |
150 mA |
No |
No |
32 |
32 |
Functionality |
No |
No |
Yes |
Yes |
Yes |
Yes |
DP master |
32 |
32 |
9.6 kbit/s |
9.6 kbit/s |
12 Mbit/s |
12 Mbit/s |
125 |
125 |
Yes |
Yes |
Yes; S7 routing |
Yes; S7 routing |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
8 kbyte |
8 kbyte |
8 kbyte |
8 kbyte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 byte |
244 |
244 |
128 byte |
128 byte |
DP slave |
32 |
32 |
12 Mbit/s |
12 Mbit/s |
No |
No |
32 |
32; Virtual slots |
32 byte |
32 byte |
32 byte |
32 byte |
Yes |
Yes |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
No |
244 byte |
244 byte |
244 byte |
244 byte |
Isochronous mode |
Isochronous operation (application synchronized up to terminal) |
Yes; For PROFIBUS only |
Yes; Via PROFIBUS DP or PROFINET interface |
Number of DP masters with isochronous mode |
2 |
3 |
2 |
User data per isochronous slave, max. |
244 byte |
244 byte |
244 byte |
equidistance |
Yes |
Yes |
Yes |
shortest clock pulse |
1 ms; 0.5 ms without use of SFC 126, 127 |
max. cycle |
32 ms |
32 ms |
32 ms |
Communication functions |
PG/OP communication |
Yes |
Yes |
Yes |
63 |
63 |
95 |
63; When using alarm_S and alarm_D |
95; When using Alarm_S/SQ and Alarm_D/DQ |
Data record routing |
Yes |
Yes |
Yes |
Global data communication |
Yes |
Yes |
Yes |
16 |
16 |
16 |
16 |
16 |
16 |
32 |
32 |
32 |
54 byte |
54 byte |
54 byte |
1 variable |
1 variable |
1 variable |
S7 basic communication |
Yes |
Yes |
Yes |
76 byte |
76 byte |
76 byte |
1 variable |
1 variable |
1 variable |
S7 communication |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
64 kbyte |
64 kbyte |
64 kbyte |
462 byte; 1 variable |
S5-compatible communication |
Yes; Via FC AG_SEND and AG_RECV, max. via 10 CP 443-1 or 443-5 |
8 kbyte |
8 kbyte |
8 kbyte |
240 byte |
240 byte |
240 byte |
64/64 |
64/64 |
64/64 |
Standard communication (FMS) |
Yes; Via CP and loadable FB |
Yes; via integrated PROFINET interface and loadable FBs |
94 |
32 kbyte |
Yes |
Via CP 443-1 and loadable FB |
Yes; Via integrated PROFINET interface or CP 443-1 and loadable FBs |
94 |
1452 bytes via CP 443-1 Adv. |
32 kbyte; 1452 bytes via CP 443-1 Adv. |
94 |
1 472 byte |
Web server |
No |
No |
Yes |
5 |
Yes |
PROFINET CBA (at set setpoint communication load) |
20 % |
32 |
150 |
6 000 |
65 000 byte |
65 000 byte |
1 000 |
16 000 byte |
2 000 byte |
200 ms; Depending on preset communication load, number of interconnections and data length used |
500 |
500 |
16 000 byte |
16 000 byte |
2 000 byte |
1 ms; Depending on preset communication load, number of interconnections and data length used |
300 |
300 |
4 800 byte |
4 800 byte |
450 byte |
2x PN OPC/1x iMap |
500 ms |
1 500 |
48 000 byte |
Yes; 32 PROFIBUS slaves max. connectable |
240 byte; Slave-dependent |
Number of connections |
64 |
64 |
96 |
1 |
1 |
1 |
0 |
0 |
0 |
1 |
1 |
1 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
S7 message functions |
Number of login stations for message functions, max. |
63; Max. 63 with ALARM_S and ALARM_D (OPs); max. 12 with ALARM_8 and ALARM_P (e.g. WinCC) |
95; Max. 95 with Alarm_S/SQ and Alarm_D/DQ (OPs); max. 8 with Alarm, Alarm_8, Alarm_8P, Notify and Notify_8 (e.g. WinCC) |
Symbol-related messages |
Yes |
Yes |
Yes |
SCAN procedure |
Yes |
Yes |
Yes |
Block related messages |
Yes |
Yes |
Yes |
Process diagnostic messages |
Yes |
Yes |
Yes |
simultaneously active Alarm-S blocks, max. |
1 000; Simultaneously active alarm_S/SQ blocks or alarm_D/DQ blocks |
Alarm 8-blocks |
Yes |
Yes |
Yes |
4 000 |
4 000 |
4 000 |
600 |
600 |
600 |
Process control messages |
Yes |
Yes |
Yes |
Number of archives that can log on simultaneously (SFB 37 AR_SEND) |
32 |
32 |
32 |
Number of messages |
1 024 |
1 024 |
1 024 |
128 |
128 |
128 |
512 |
512 |
512 |
1 024 |
1 024 |
1 024 |
Number of additional values |
1 |
1 |
1 |
10 |
10 |
10 |
Test commissioning functions |
Status block |
Yes; Up to 2 simultaneously |
Yes; Up to 16 simultaneously |
Single step |
Yes |
Yes |
Yes |
Number of breakpoints |
4 |
4 |
16 |
Status/control |
Yes; Up to 16 variable tables |
Inputs/outputs, memory bits, DBs, distributed I/Os, timers, counters |
70; Status/control |
Forcing |
Yes |
Yes |
Yes |
Inputs, outputs, bit memories, peripheral inputs, peripheral outputs |
Inputs/outputs, bit memories, distributed I/Os |
512 |
512 |
512 |
Diagnostic buffer |
Yes |
Yes |
Yes |
3 200 |
3 200 |
3 200 |
Yes |
Yes |
Yes |
120 |
120 |
120 |
Service data |
Yes |
EMC |
Emission of radio interference acc. to EN 55 011 |
Yes |
Yes |
Yes |
No |
No |
No |
Configuration |
Configuration software |
Yes |
Yes |
Yes |
programming |
see instruction list |
7 |
7 |
7 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
2 |
2 |
2 |
8 |
8 |
8 |
8 |
8 |
8 |
8 |
8 |
8 |
8 |
8 |
8 |
1 |
1 |
1 |
2 |
2 |
2 |
8 |
8 |
8 |
8 |
8 |
8 |
1 |
1 |
1 |
8 |
8 |
8 |
8 |
8 |
8 |
Know-how protection |
Yes |
Yes |
Yes |
Yes; With S7 block Privacy |
Dimensions |
Width |
25 mm |
50 mm |
50 mm |
Height |
290 mm |
290 mm |
290 mm |
Depth |
219 mm |
219 mm |
219 mm |
Weights |
Weight, approx. |
0.7 kg |
0.9 kg |
900 g |
More information
手册
要下载相关的信息资料,请访问网站:
http://www.automation.siemens.com/infocenter
