上海湘昌自动化设备有限公司(西门子代理商)
联系人:李军(先生)工程师
手机:13037425070
电话:021-60524801 传真(FAX):021-57893688
工作QQ:390380550
E-mail:390380550@QQ.COM
24小时销售技术咨询: 13037425070
地址:上海市松江区新浜工业园甪彭路18号
CPU 417H
跳转到
Overview
Area of application
Design
Functions
Technical Specifications
Overview
- CPU 用于 SIMATIC S7-400H 和 S7-400F/FH
- 可在高可用性 S7-400H 系统中使用
- 可结合故障安全 S7-400F/FH 系统中的 F-Runtime 授权和 F 兼容 CPU 使用
- 带有集成 PROFIBUS DP 主站接口
- 带有 2 个用于同步模块的插槽
Area of application
CPU 417–4H 是用于 SIMATIC S7-400H 和 S7-400 F/FH 的功能强大的 CPU。它允许配置为一个容错的 S7-400H 系统。它可与 F 运行授权一起用于故障安全 S7-400®F/FH 自动化系统。
内置的PROFIBUS-DP接口使它能够作为主站或从站直接连接到PROFIBUS-DP现场总线。
Design
The CPU 417-4H features:
- A powerful processor:
The CPU achieves command runtimes as little as 18 ns per binary command.
- 30 MB main memory (15 MB for programs, 15 MB for data):
Load memory for user programs and configuration data for the S7-400H automation system; Fast main memory for subroutines of the user program that are relevant to the process.
- A memory card:
For expanding the integrated load memory. In addition to the program itself, the information contained in the load memory also includes configuration data for the S7-400H, which is why it takes up twice as much space in the memory. The result is that:
- The integrated load memory is not sufficient for large programs, which is why the memory card is often required.
RAM and FEPROM cards are available (FEPROM for saving at zero voltage too).
- Easy expandability:
Max. 128K digital and 8K analog inputs/outputs.
- Multipoint-capable MPI interface:
The MPI enables the creation of a simple network with max. 32 nodes and a data transfer rate of 187.5 Kbit/s. The CPU can establish up to 64 connections to users of the communication bus (C bus) and the MPI.
Note:
If PROFIBUS DP and MPI interfaces are being used simultaneously, only the following bus connectors can be connected to the MPI interface:
- With socket: 6ES7 972-0BB41-0XA0
- Without socket: 6ES7 972-0BA41-0XA0
- Mode selector:
Designed as a toggle switch.
- Diagnostics buffer:
The last 120 alarm and interrupt events are stored in a ring buffer for the purpose of diagnosis.
- Real-time clock:
Diagnostics reports from the CPU are provided with the date and time.
- PROFIBUS DP interface:
The CPU 417-4H with PROFIBUS DP master interface enables distributed automation to be established at high speed and with easy operation. From the user's point of view, the distributed I/Os are treated like centralized I/Os (same configuration, addressing and programming).
Note:
Functions
- 块保护:
用户程序使用密码保护,可防止非法访问。(也可通过钥匙开关设置)。
- 集成的 HMI 服务:
用户只能规定HMI设备的源数据地址和目标数据地址。这些数据通过系统周期地以及自动地进行传输。
- 集成的通讯功能:
可组态的属性
STEP 7“硬件配置”工具和安装的 S7-400H 选件包用来组态包括CPU在内的S7-400H的特性和响应,例如:
- 多点接口MPI:
- 定义节点地址
- 启动/循环响应特性
- 定义最大的扫描时间和通讯负载。
- 地址分配:
I/O模板编址
- 保持区域:
定义具有保持特性的位存储器、计数器、定时器、数据块和时钟存储器的数量
- 保护级:
设置程序和数据的访问权限。
- 系统诊断:
定义诊断报文的范围,以及处理的范围
- 监视器中断:
定义周期时间
- H站的配置
安全相关功能
F-运行授权用来编译故障安全F用户程序,并在CPU上运行程序。每个 S7-400F/FH 系统需要 1 个授权。 包括 2 张 TÜV 贴纸。
报告功能
- 状态和故障指示灯:
用LED指示指示内部和外部故障,以及运行状态,如 RUN(运行)、STOP(停止)、“主站”模式、冗余故障和测试功能等
- 测试功能:
PG可用来显示程序执行过程中的信号状态,可以单独修改过程变量,读取栈存储器的内容,单步执行程序以及禁止部分程序的运行。
- 信息功能:
编程器可向用户提供:有关存贮器容量,CPU 运行模式,以及工作存储器和装载存储器的信息。
scriptions="b2 a_i" hsdl-percent="10 10.0" style="border: 0px none; border-spacing: 0px; margin: 20px 0px 0px; padding: 0px; color: rgb(0, 0, 0); font-size: 11px; background-color: rgb(248, 248, 248);">
6ES7 417-5HT06-0AB0
CPU 417-5H PN/DP
一般信息
硬件产品型号
1
固件型号
V6.0
工程组态
从带有 HF1 的 STEP 7 V5.5 SP2 起
CiR - 在 RUN 模式下组态
CiR 同步时间,基本负载
60 ms
CiR 同步时间,每个 I/O 从站的时间
0 µs
电源电压
24 V DC
×;电源通过系统电源提供
输入电流
从背板总线 5 V DC,最大
1.9 A
从接口 5 V DC,最大
90 mA;在每个 DP 接口处
功耗
功耗,典型值
7.5 W
存储器
存储器类型
其它
工作存储器
32 Mbyte
16 Mbyte
16 Mbyte
X
装载存储器
√;带存储卡(FLASH)
64 Mbyte
1 兆
64 Mbyte
后备
√;所有数据
X
CPU 处理时间
位操作,典型
7.5 ns
字操作,典型
7.5 ns
定点数运算,典型
7.5 ns
浮点数运算,典型
15 ns
CPU 块
DB
16,000;编号范围: 1 - 16.000
64 KB
FB
8,000;编号范围:0 到 7999
64 KB
FC
8,000;编号范围:0 到 7999
64 KB
OB
64 KB
嵌套深度
24
2
计数器、定时器及其保持性
S7 计数器
2 048
0
2 047
Z0 ~ Z7
0
999
IEC 计数器
SFB
不限(只取决于 RAM 容量)
S7 定时器
2 048
0
2 047
无保持定时器
10 ms
9 990 s
IEC 定时器
SFB
不限(只取决于 RAM 容量)
数据区及其保持性
保持数据区域,总共
总工作存储器和装入存储器(带有备用电池)
标志
16,384 字节
MB 0 - MB 15
8; (1个存储字节)
局部数据
64 KB
32 kbyte
地址区
I/O 地址区
16 kbyte
16 kbyte
2 kbyte
2 kbyte
8 kbyte
8 kbyte
8 kbyte
8 kbyte
过程映像
16 kbyte
16 kbyte
1 024 字节
1 024 字节
244 byte
子过程映像
15
数字量通道
131 072
131 072
131 072
131 072
模拟量通道
8 192
8 192
8 192
8 192
硬件配置
扩展设备,最多
21
多CPU运行
X
接口模块
6
6
4;仅限单一模式
DP 主站的数量
2
10;CP 443-5 扩展
X
0
IO 控制器的数量
1
0
可运行的 FM 和 CP 数量(推荐)
请参见手册“自动化系统 S7-400H 容错系统”。受插槽数和接口数的限制
14;其中,最多 10 个 CP 作为 DP 主站
时间
时钟
1 ms
1.7s;掉电
8.6 s;加电
运行小时计数器
16
0 到 15
SFC 2, 3 和 4:0 至 32767 小时 SFC 101:0 - 2^31 - 1 小时
1 小时
时钟同步
√;作为客户端
接口
USB 接口数量
0
第 1 个接口
接口类型
集成
物理
RS 485 / PROFIBUS + MPI
隔离
接口电源 (15-30 VDC),最大
150 mA
连接源数量
MPI:44, DP: 32
功能性
X
MPI
44;如线路使用诊断中继器,则线路的连接资源数减 1
12 Mbit/s
X
X
DP 主站
32;如线路使用诊断中继器,则线路的连接资源数减 1
12 Mbit/s
32
X
X
X
X
X
X
X
2 kbyte
2 kbyte
244 byte
244 byte
244 byte
244
128 byte
DP 从站
没有将 CPU 配置为 DP 从站
第 2 个接口
接口类型
PROFINET
物理
以太网 RJ45
隔离
集成交换机
端口数
2
自动检测传输速率
√;自动检测
自动协商
自动交叉
运行时更改 IP 地址,支持
X
连接源数量
120
介质冗余
200 ms
50
功能性
X
X
X
X
X
PROFINET IO 控制器
100 Mbit/s
256;在冗余模式,通过两个接口
256
256
√;仅限单一模式
X
X
X
250 µs - 512 ms,最小值取决于已组态用户数据的数量和已组态的单一或冗余模式
X
8 kbyte
8 kbyte
1 024 字节
开放式 IE 通信
118
0, 20, 21, 25, 102, 135, 161, 34962, 34963, 34964, 65532, 65533, 65534, 65535
第 3 接口
接口类型
集成
物理
RS 485 / PROFIBUS
接口电源 (15-30 VDC),最大
150 mA
连接源数量
32
功能性
X
DP 主站
32
12 Mbit/s
125
X
X
X
X
X
X
X
8 kbyte
8 kbyte
244 byte
244 byte
244 byte
244
128 byte
第 4 接口
接口类型
可拔插同步子模块(FO)
插入式接口模块
同步模块 6ES7960-1AA06-0XA0 或 6ES7960-1AB06-0XA0
5. 接口
接口类型
可拔插同步子模块(FO)
插入式接口模块
等时同步模式
同步操作(一直同步至端子)
X
等距离
X
通信功能
编程器/OP 通信
119
119;使用 Alarm_S/SQ 和 Alarm_D/DQ 时
数据记录路由
S7 路由
全局数据通信
X
S7 基本通信
X
S7 通信
64 KB
462 字节;1 个变量
S5 可兼容通信
√;(通过最多 10 个 CP 以及 FC AG_SEND 和 FC AG_RECV)
8 kbyte
240 字节
- 每个 CPU 的同时 AG-SEND/AG-RECV 订单数,最多
64/64
标准通信 (FMS)
√;通过 CP 和可加载的功能块
开放式 IE 通信
√;通过内置的 PROFINET 接口以及可加载的功能块
118
32 kbyte
√;通过集成 PROFINET 接口或 CP 443-1 和可调用的 FB
118
32 KB;1452 字节,通过 CP 443-1 Adv.
118
1472 字节
Web 服务器
X
连接数量
120
S7 报文功能
报文功能可以登录站的数量,最多
119;最多 119 个,带 Alarm_S/SQ 和 Alarm_D/DQ (OPs);最多 16 个,带 Alarm_8、Alarm_8P、通知和 Notify_8(如 WinCC)
与符号相关的报文
X
SCAN 程序
X
与块相关的报文
过程诊断报文
可同时激活的 Alarm-S 块,最多
1 000;同时激活 alarm_S/SQ 块或 alarm_D/DQ 块
8 个报警功能块
10 000
1 200
过程控制报文
调试功能
状态块
单步运行
断点数量
16
状态/控制
√;多达 16 个变量表
I/O、存储位、数据库、分布式 I/O、定时器、计数器
70
强制
输入/输出、位存储器、分布式 I/O
512
诊断缓冲区
3 200
120
组态
编程
见“指令表”
7
专门知识保护
√;带有 S7 块加密功能
外形尺寸
宽度
50 mm
高度
290 mm
深度
219 mm
所需插槽
2
重量
重量,约
995 g
全部关于 CPU 417H
产品与解决方案在线目录与订购系统技术信息服务与支持联系人与合作伙伴
