6AG1 647-0AH11-2AX0
6AG1 647-0AA11-2AX0
6AG1 647-0AD11-2AX0
SIMATIC HMI KP300 Basic mono PN
KTP400 Basic mono PN
SIMATIC HMI KTP600 Basic color PN
Display
Design of display
FSTN
STN
TFT
Screen diagonal
3.6 in
3.8 in
5.7 in
Display width
87 mm
76.8 mm
115.2 mm
Display height
31 mm
57.6 mm
86.4 mm
Number of colors
4; Backlit display only (white, red, green, yellow)
256
Resolution (pixels)
- Horizontal image resolution
240
320
320
- Vertical image resolution
80
240
240
Backlighting
- MTBF backlighting (at 25 °C)
50 000 h
30 000 h
50 000 h
No
No
Control elements
Keyboard fonts
6
No
No
No
Yes
No
- Numeric/alphabetical input
Yes (on-screen keyboard) / Yes (on-screen keyboard)
Yes; Keyboard
Yes; Onscreen keyboard
Yes; Keyboard
Touch operation
No
Yes
Yes
Installation type/mounting
Mounting in portrait format possible
No
Yes
Mounting in landscape format possible
Yes
Yes
Supply voltage
Type of supply voltage
DC
DC
DC
Rated value (DC)
24 V
24 V
permissible range, lower limit (DC)
19.2 V
19.2 V
permissible range, upper limit (DC)
28.8 V
28.8 V
Input current
Current consumption (rated value)
0.1 A
0.35 A
Inrush current A²s
0.5 A²·s
0.5 A²·s
0.5 A²·s
Power
Power consumption, typ.
3 W
9 W
Processor
Processor type
RISC 32-bit
No
No
No
Yes; RISC 32-bit
Yes
Yes; RISC 32-bit
Memory
Flash
Yes
Yes
Yes
RAM
Yes
Yes
Yes
Usable memory for user data
512 kbyte
512 kbyte
1 Mbyte
Type of output
Acoustics
Sound signal
No
Yes
No
No
Time of day
Clock
- Hardware clock (real-time clock)
No
No
Yes
Yes
Yes
No
No
Yes
Yes
Interfaces
Number of RS 485 interfaces
0
0
0
Number of USB interfaces
0
0
0
Number of SD card slots
0
0
Number of parallel interfaces
0
0
0
Number of 20 mA interfaces (TTY)
0
0
0
Number of RS 232 interfaces
0
0
0
Number of RS 422 interfaces
0
0
0
Number of other interfaces
0
0
0
With software interfaces
No
No
Industrial Ethernet
- Number of industrial Ethernet interfaces
1
1
1
- Industrial Ethernet status LED
2
2
2
Protocols
PROFINET
Yes
Yes
Yes
Supports protocol for PROFINET IO
No
No
IRT supported
No
No
PROFIBUS
No
No
No
MPI
No
No
No
Protocols (Ethernet)
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
WEB characteristics
No
No
No
No
Further protocols
No
No
Yes; Modicon (MODBUS TCP/IP)
No
- Supports protocol for EtherNet/IP
Yes
Yes
Interrupts/diagnostics/status information
Diagnostic messages
- Diagnostic information readable
No
No
Degree and class of protection
IP (at the front)
IP65
IP65
IP65
Enclosure Type 4 at the front
Yes
Yes
Enclosure type 4x at the front
Yes
Yes
IP (rear)
IP20
IP20
IP20
Standards, approvals, certificates
CE mark
Yes
Yes
Yes
KC approval
Yes
cULus
Yes
RCM (former C-TICK)
Yes
Marine approval
No
Yes
- American Bureau of Shipping (ABS)
No
Yes
No
Yes
No
Yes
- Lloyds Register of Shipping (LRS)
No
Yes
- Nippon Kaiji Kyokai (Class NK)
No
Yes
- Polski Rejestr Statkow (PRS)
No
Yes
Use in hazardous areas
No
No
No
- cULus Class I Zone 2, Division 2
No
No
Ambient conditions
Mounting position
vertical
vertical
vertical
maximum permissible angle of inclination without external ventilation
35°
35°
35°
Operating temperature
- Operation (vertical installation)
-10 °C to +60 °C
-25 °C to +60 °C
- in vertical mounting position, minimum
-25 °C; = Tmin
-10 °C
-25 °C
- in vertical mounting position, maximum
60 °C; = Tmax
60 °C
60 °C
- Operation (max. tilt angle)
0 °C to +40 °C
- at maximum tilt angle, minimum
-25 °C; = Tmin
0 °C
- at maximum tilt angle, maximum
40 °C; = Tmax
40 °C
- Operation (vertical installation, portrait format)
Not applicable
Not applicable
- Operation (max. tilt angle, portrait format)
Not applicable
Not applicable
Storage/transport temperature
-25 °C
-30 °C
60 °C
60 °C
Relative humidity
100 %; Relative humidity, incl. condensation / frost permitted (no commissioning under condensation conditions)
Extended ambient conditions
- Relative to ambient temperature-atmospheric pressure-installation altitude
Tmin ... Tmax at 1080 hPa ... 795 hPa (-1000 m ... +2000 m) // Tmin ... (Tmax - 10K) at 795 hPa ... 658 hPa (+2000 m ... +3500 m) // Tmin ... (Tmax - 20K) at 658 hPa ... 540 hPa (+3500 m ... +5000 m)
- With condensation, tested in accordance with IEC 60068-2-38, maximum
100 %; RH incl. condensation/frost (no commissioning under condensation conditions)
- to biologically active substances/conformity with EN 60721-3-3
Yes; Class 3B2 mold, fungus and dry rot spores (with the exception of fauna). The supplied connector covers must remain on the unused interfaces during operation!
- to chemically active substances/conformity with EN 60721-3-3
Yes; Class 3C4 (RH < 75%) incl. salt spray according to EN 60068-2-52 (degree of severity 3). The supplied connector covers must remain on the unused interfaces during operation!
Yes; Class 3C4 incl. salt spray. The supplied connector covers must remain on the unused interfaces during operation!
- to mechanically active substances/conformity with EN 60721-3-3
Yes; Class 3S4 incl. sand, dust. The supplied connector covers must remain on the unused interfaces during operation!
Operating systems
Windows CE
No
No
proprietary
Yes
Yes
Executable with configuration operating system
No
No
Configuration
Message indicator
Yes
Yes
Yes
With alarm logging system (incl. buffer and acknowledgment)
Yes
Yes
Yes
Process value display (output)
Yes
Yes
Yes
Process value default (input) possible
Yes
Yes
Yes
Recipe administration
Yes
Yes
Yes
Configuration software
- STEP 7 Basic (TIA Portal)
Yes; via integrated WinCC Basic (TIA Portal)
- STEP 7 Professional (TIA Portal)
No
Yes
No
Yes
No
Yes
Yes
Yes
- WinCC Comfort (TIA Portal)
Yes
Yes
- WinCC Advanced (TIA Portal)
Yes
Yes
- WinCC Professional (TIA Portal)
Yes
Yes
Languages
Online languages
- Number of online/runtime languages
5
5
5
Languages
32
32
32
D, GB, F, I, E, CHN "traditional", CHN "simplified", DK, FIN, GR, J, KP / ROK, NL, N, PL, P, RUS, S, CZ / SK, TR, H
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Functionality under WinCC (TIA Portal)
Libraries
Yes
Yes
Yes
Task planner
Yes
No
No
Yes
Yes
Help system
Yes
- Number of characters per info text
320
320
320
Message system
32
32
32
200
200
200
- Number of analog messages
15
15
15
Yes
Yes
Yes
- System messages, other (SIMATIC S7, Sinumerik, Simotion, etc.)
No
- Number of characters per message
80
80
80
- Number of process values per message
8
8
8
Yes
Yes
Yes
Ring buffer (n x 256 entries), non-retentive
256
256
256
Yes
Yes
Yes
Yes
Yes
Yes
Yes
5
5
5
20
20
20
20
20
20
- Size of internal recipe memory
40 kbyte
40 kbyte
40 kbyte
No
No
No
Variables
- Number of variables per device
250
128
500
- Number of variables per screen
30
30
30
Yes
Yes
Yes
Yes
Yes
Yes
No
No
No
Yes
Yes
Images
- Number of configurable images
50
50
50
Yes
Yes; No permanent window can be configured
Yes
Yes
Yes
- Start screen configurable
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Image objects
- Number of objects per image
30
30
Yes
Yes
Yes
Yes
- Graphic I/O fields (graphics list)
Yes
Yes
- Symbolic I/O fields (text list)
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Complex image objects
- Number of complex objects per screen
5
5
Yes
Yes
Yes
Yes
Yes
Yes
No
No
No
No
No
Yes
Yes
No
No
No
No
No
No
Yes
Yes
No
No
No
No
Lists
- Number of text lists per project
150
150
150
- Number of entries per text list
30
30
- Number of graphics lists per project
100
100
100
- Number of entries per graphics list
30
30
Archiving
- Number of archives per device
0
0
Security
50
50
50
32
32
32
50
50
No
No
No
No
No
Character sets
US American (English)
Yes
Yes
Yes
Tahoma, WinCC flexible Standard, symbol languages
Yes
Yes
Yes
No
No
No
No
No
No
Yes
Yes
Yes
Yes
Yes
Yes
- Font size freely scalable
No
No
No
- Additional character sets can be loaded
No
No
Transfer (upload/download)
No
No
No
No
No
No
Yes
Yes
Yes
- using external storage medium
No
No
No
Process coupling
Yes
Yes
Yes
Yes
Yes; Via CP
Yes
Yes
Yes
Yes
Yes; With restrictions with regard to address area and data types http://support.automation.siemens.com/WW/view/en/56348902
Yes
Yes
No
No
No
No
No
No
- Allen Bradley (EtherNet/IP)
Yes
Yes
No
No
No
Yes
Yes
No
No
No
No
No
No
No
No
Yes
Yes
No
No
No
Service tools/configuration aids
No
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
- Backup/Restore automatically
No
No
Yes
Yes
Yes
Yes
Yes
Yes
No
No
No
I/O/Options
I/O devices
none
No
No
No
No
No
No
No
No
No
No
No
No
Mechanics/material
Type of housing (front)
plastic
Yes
Yes
Yes
No
No
No
No
No
Dimensions
Width of the housing front
165 mm
140 mm
214 mm
Height of housing front
97 mm
116 mm
158 mm
Mounting cutout/device depth (W x H x D)
123 mm x 99 mm/40 mm device depth
149 mm
197 mm
82 mm
141 mm
Device depth
30 mm
40 mm
44 mm
Weights
Weight without packaging
0.25 kg
1.07 kg
Weight incl. packaging
0.38 kg
1.32 kg
