上海湘昌自动化设备有限公司(西门子代理商)
联系人:李军(先生)工程师
手机:13037425070
电话:021-60524801 传真(FAX):021-57893688
工作QQ:390380550
E-mail:390380550@QQ.COM
24小时销售技术咨询: 13037425070
地址:上海市松江区新浜工业园甪彭路18号
Area of application
SB 1222 信号板数字量输入模块允许将控制器的数字量信号与过程输出连接。
Design
信号板直接插到每个 S7-1200-CPU 前面的支架中。
- 安装:
信号板可直接插到 SIMATIC S7-1200-CPU 中,因此使用这种方法可以电气、机械地连接到 CPU。
- CPU 的安装尺寸保持不变。
- 所有信号板上的端子均可拆卸,便于更换(“永久接线”)。
Functions
SB 1222 信号板数字量输入/输出模块将 S7-1200 的内部信号电平转换成过程所要求的外部信号电平。
Technical Specifications
scriptions="b2 a_i " hsdl-percent="10 10.0 10.0" style="border: 0px none; border-spacing: 0px; margin: 20px 0px 0px; padding: 0px; color: rgb(0, 0, 0); font-size: 11px; background-color: rgb(248, 248, 248);">
6ES7 222-1AD30-0XB0
6ES7 222-1BD30-0XB0
SB 1222 4xDQ 5VDC 200kHz
SB 1222 4xDQ 24VDC 200kHz
Input current
from backplane bus 5 V DC, typ.
50 mA
50 mA
Output voltage
Power supply to the transmitters
4 mA; per channel
4 mA; per channel
Power losses
Power loss, typ.
1 W
1 W
Digital inputs
Number of digital inputs
0
0
Digital outputs
Number of digital outputs
4; MOSFET, solid-state (current-sinking/current-sourcing)
1
1
Short-circuit protection
No
No
Switching capacity of the outputs
- with resistive load, max.
0.1 A
0.1 A
Load resistance range
5 Ω
10 Ω
Output voltage
5 V
24 V
0.4 V
0.1 V; with 10 kOhm load
L+ (-0.5 V)
20 V
6 V
Output current
- for signal "1" rated value
0.1 A
0.1 A
- for signal "1" permissible range, max.
0.11 A
- for signal "0" residual current, max.
10 µA
Cable length
- Cable length, shielded, max.
50 m
50 m
Interrupts/diagnostics/status information
Alarms
Yes
Yes
Diagnostic messages
Yes
Yes
Diagnostics indication LED
- For status of the outputs
Yes
Yes
Degree and class of protection
IP20
Yes
Yes
Standards, approvals, certificates
Marine approval
Yes
Yes
Climatic and mechanical conditions for storage and transport
Climatic conditions for storage and transport
- Drop height, max. (in packaging)
0.3 m; five times, in dispatch package
- Permissible temperature range
-40 °C to +70 °C
-40 °C to +70 °C
- Air pressure acc. to IEC 60068-2-13
1080 to 660 hPa
1080 to 660 hPa
- Permissible range (without condensation) at 25 °C
95 %
95 %
Mechanics/material
Type of housing (front)
Yes
Yes
Dimensions
Width
38 mm
38 mm
Height
62 mm
62 mm
Depth
21 mm
21 mm
Weights
Weight, approx.
40 g
40 g
全部关于 SB 1222 数字量输出模块
产品与解决方案在线目录与订购系统技术信息服务与支持联系人与合作伙伴
