6ES7 231-5PD32-0XB0
6ES7 231-5PF32-0XB0
SM 1231 RTD 4x16bit
SM 1231 RTD 8x16bit
Supply voltage
24 V DC
Yes
Yes
Input current
Current consumption, typ.
40 mA
40 mA
from backplane bus 5 V DC, typ.
80 mA
80 mA
Power losses
Power loss, typ.
1.5 W
1.5 W
Analog inputs
Number of analog inputs
4; Resistance thermometer
8; Resistance thermometer
Technical unit for temperature measurement adjustable
Degrees Celsius/degrees Fahrenheit
Input ranges
Yes; Resistance-type transmitter: Pt10, Pt50, Pt100, Pt200, Pt500, Pt1000, Ni100, Ni120, Ni200, Ni500, Ni1000, Cu10, Cu50, Cu100, LG-Ni1000
Yes; 150 Ω, 300 Ω, 600 Ω
Input ranges (rated values), resistance thermometers
Yes
Yes
10 Ω
10 Ω
Yes
Yes
- Input resistance (Ni 100)
100 Ω
100 Ω
Yes
Yes
- Input resistance (Ni 1000)
1 000 Ω
1 000 Ω
Yes
Yes
- Input resistance (LG-Ni 1000)
1 000 Ω
1 000 Ω
Yes
Yes
- Input resistance (Ni 120)
120 Ω
120 Ω
Yes
Yes
- Input resistance (Ni 200)
200 Ω
200 Ω
Yes
Yes
- Input resistance (Ni 500)
500 Ω
500 Ω
Yes
Yes
- Input resistance (Pt 100)
100 Ω
100 Ω
Yes
Yes
- Input resistance (Pt 1000)
1 000 Ω
1 000 Ω
Yes
Yes
- Input resistance (Pt 200)
200 Ω
200 Ω
Yes
Yes
- Input resistance (Pt 500)
500 Ω
500 Ω
Input ranges (rated values), resistors
Yes
Yes
Yes
Yes
Yes
Yes
Thermocouple (TC)
No
No
Analog outputs
Number of analog outputs
0
0
Analog value creation
Measurement principle
integrating
integrating
Integrations and conversion time/resolution per channel
- Resolution with overrange (bit including sign), max.
15 bit; + sign
15 bit; + sign
- Integration time, parameterizable
No
No
- Interference voltage suppression for interference frequency f1 in Hz
85 dB at 50 / 60 / 400 Hz
Errors/accuracies
Repeat accuracy in steady state at 25 °C (relative to output area), (+/-)
0.05 %
0.05 %
Interference voltage suppression for f = n x (f1 +/- 1 %), f1 = interference frequency
- Common mode interference, min.
120 dB
120 dB
Interrupts/diagnostics/status information
Alarms
Yes
Yes
Yes
Yes
Diagnostic messages
Yes; Can be read out
- Monitoring the supply voltage
Yes
Yes
Yes
Yes
Diagnostics indication LED
Yes
Yes
Yes
Yes
Degree and class of protection
IP20
Yes
Yes
Standards, approvals, certificates
CE mark
Yes
Yes
RCM (former C-TICK)
Yes
Yes
FM approval
Yes
Yes
Highest safety class achievable in safety mode
none
none
Climatic and mechanical conditions for storage and transport
Climatic conditions for storage and transport
- Drop height, max. (in packaging)
0.3 m; five times, in dispatch package
- Permissible temperature range
-40 °C to +70 °C
-40 °C to +70 °C
- Air pressure acc. to IEC 60068-2-13
1080 to 660 hPa
1080 to 660 hPa
- Permissible range (without condensation) at 25 °C
95 %
95 %
Mechanical and climatic conditions during operation
Climatic conditions in operation
1080 to 795 hPa
1080 to 795 hPa
- SO2 at RH < 60% without condensation
S02: < 0.5 ppm; H2S: < 0.1 ppm; RH < 60% condensation-free
Connection method
required front connector
Yes
Yes
Mechanics/material
Type of housing (front)
Yes
Yes
Dimensions
Width
45 mm
70 mm
Height
100 mm
100 mm
Depth
75 mm
75 mm
Weights
Weight, approx.
220 g
220 g
