硅胶保护膜
SILICA-GEL PROTECTIVE FILM
产品描述Product De
此款保护膜是以PET为基材,单面涂布硅胶水并贴合底膜而成
This film is formed by coating the PET substrate with silicone adhesive and bonded with base film on the side.
产品特点Features
1、高温环境下不易残胶(不易与被贴物产生化学反应);
Stable property under high temperature(not easy to have chemical reaction with the item)
2、可重复粘贴,不影响使用效果;
It can be re-used repeatedly with good performance.
3、高温环境下有良好的保持力。
It has good retentivity in high-temperature environment.
产品用途Uses
1、热熔胶转贴;
Transfer bonding with hot-melt adhesive
2、哑光塑胶件外壳;
Enclosure of plastic parts of matt surface
3、表面含硅基材等。
Substrate with silicone on the surface, etc.
