主营DCS控制系统备件,PLC系统备件及机器人系统备件,优势品牌:Allen Bradley、BentlyNevada、ABB、Emerson Ovation、Honeywell DCS、Siemens。Rockwell ICS Triplex、FOXBORO、Schneider PLC、GE Fanuc、Motorola、HIMA、Prosoft等各种进口工业零部件,公司始终秉承“诚信、高效、共赢、创新”的经营理念,本着“质量保证,诚信服务,客户至上”的做事态度服务于每一位新老客户,依托强有竞争力的产品价格,庞大的库存,过硬的质量, 快捷的货期以及售前咨询、售后服务,持续为广大客户提供的产品,主营产品广泛服务于电子、冶金、化工、电厂、钢厂、橡胶、水泥、机械设备、筑建等行业。
公司的优势产品有:A-B、西门子、施耐德、FANUC、西屋、ABB,伊顿,力士乐、伦茨、安川 、艾默生、SEW、丹佛斯、科尔摩根、富士等等进口品牌备件 主营产品:DCS集散式控制、PLC、数控、 (CPU、板卡、模块、卡件.触摸屏、控制器、伺服驱动、工作站、驱动器、 马达、 内存卡、 电源,机器人备件等)各类工控产品
福建石屹科技有限公司
NATIonAL INSTRUMENTS N114
National Instruments NI 6584 Module full duplex differential with Serial Cable
NATIonAL INSTRUMENTS NI 9263 198856B-01L 4 Channel Analog Output
National Instruments NI 9421 with DSUB 8Ch 24 sinking Digital input
National Instruments NI AT-FBUS 183769C-01 Fieldbus Host System ISA PC interface
National Instruments NI cRIO-9022 Real-Time Controller
National Instruments NI PCI-7811R R-Series PCI-781XR Digital RIO DAQ CARD
National Instruments NI PCI-8430/2 RS-232 ASSY188825C-01L Serial Interface
National Instruments NI PCIe-6535B 32-Channel, 10 MHz 40 MB/s Digital I/O Device
National Instruments NI PCIe-GPIB Controller Card 190243F-01
National Instruments NI PCI-GPIB IEEE 488.2 Interface Adapter Card
National Instruments NI PCMCIA-GPIB Interface Card
National Instruments NI PXI-1000B 8 Slot 3U, PXI / Compact PCI, PXI Mainframe
National Instruments NI PXI-1002 745749-01 NI CompactPCI PXI 4-Slot Chassis
NATIonAL INSTRUMENTS NI PXI-1042 MAINframe CHASSIS (EHM)
National Instruments NI PXI-1042Q Mainframe Chassis
National Instruments NI PXI-1042Q/NI PXI-8106/NI PXI-1409
National Instruments NI PXI-1052 Chassis, 4-Slot PXI / 8-Slot SCXI Mainframe
National Instruments NI PXI-4110 PXI Programmable DC Power Supply Module Card
National Instruments NI PXI-4351 High-Precision Temperature and Voltage Meter
National Instruments NI PXI-4465 2-Input Dynamic Signal Analyzer 189003E-02L
National Instruments NI PXI-4472 8-Input Dynamic Signal Analyzer
National Instruments NI PXI-5421 16-BIT 100 MS/S AWG
National Instruments NI PXI-5610 2.7 GHz RF Upconverter
National Instruments NI PXI-5620 64 MS/s, 14-Bit Frequency-Domain Digitizer
National Instruments NI PXI-6220 16-Bit, 250 kS/s, 16 Analog Inputs
National Instruments NI PXI-6508 96-Channel, 5 V TTL/CMOS, 2.5 mA PXI Digital
National Instruments NI PXI-6723 13-Bit, 32-Channel, 800 kS/s PXI Analog Output
National Instruments NI PXI-8105 Dual-Core Embedded Controller for PXI
National Instruments NI PXI-8108 2.53 GHz Dual-Core Embedded Controller OS 7
National Instruments NI PXI-8155B Embedded Controller
National Instruments NI PXIe-1062Q 8-Slot PXI Express Chassis+PXIe-8105 PXI-6281
National Instruments NI PXIe-5450 PXIe, 145 MHz Bandw., 16-Bit I/Q PXI Wav. Gen.
National Instruments NI PXIe-7965R FlexRIO FPGA with NI 5733 2ch Adapter Module
National Instruments NI PXIe-8105 Controller w/XP SP3, NI-MAX, Labview 8.5.1
National Instruments NI PXIe-8106 2.16 GHz Dual-Core Emb. Contr. for PXI & PXIe
National Instruments NI PXIe-8133 Embedded Controller TESTED
National Instruments NI SCXI Application Examples Software 3.5" Floppy Disk 1995
National Instruments NI SCXI-1126 8-Channel Isolated Frequency Input Module
National Instruments NI SHC68-68-EPM 2m shielded cable 192061B-02 68-pin DAQ
National Instruments NI USB-6009 USB Data Acquisition Card Module 779026-01 DAQ
National Instruments NI-DAQ AT-MIO-16D 181965-01 ISA Bus Card *
National Instruments Oscilloscope/Digitizer PCIe-5155 Hi-Speed Averaging 5 GS/s
NATIonAL INSTRUMENTS PCI 232/485, 8CH 184677C-01 CARD
National Instruments PCI 232/485, 8CH 184677C-01 Card
National Instruments PCI 232/485, 8CH 184677D-01 Card
National Instruments PCI-1409 NI IMAQ Video frame Grabber Card
National Instruments PCI-1411 NI IMAQ Video frame Grabber Card
National Instruments PCI-232/485.2CH
National Instruments PCI-5411 183962D-02 DAQArb
National Instruments PCI-5411 Arbitrary Function / Signal Generator NI DAQ Card
National Instruments PCI-5411 ARBITRARY FUNCTION/SIGNAL NI DAQ Card
National Instruments PCI-6025E 185484C-01 Multifunction DAQ Card Analog Input
National Instruments PCI-6281 NI DAQ Card, 18-bit Analog Input, Multifunction
National Instruments PCI-6503 185183A-01 Digital I/O DAQ Card 185185A-01
National instruments PCI-6503 DIO 185183A-01 DAQ / Data acquisition pci card
NATIonAL INSTRUMENTS PCI-6527 DAQ CARD DIGITAL I/O
NATIonAL INSTRUMENTS PCI-6534 PCB CARD
National Instruments PCI-6703 183689G-02 DAQ Analog Output Card PCI6703
NATIonAL INSTRUMENTS PCI-6713 HIGH SPEED ANALOG MODULE NI 185030D-01
NATIonAL INSTRUMENTS PCI-6713 HIGH SPEED ANALOG MODULE NI 185030F-01
National Instruments PCI-8212 NI GPIB Interface Card w/ Ethernet Port
National Instruments PCIE-8433/2 Serial Interface Card 199774D-02L
NATIonAL INSTRUMENTS PCI-GPIB 188513E-01L FV CARD
National Instruments PCI-MIO-16E-1
National Instruments PCI-MIO-16E-1 Daq Card 183455C-01
National Instruments PCI-MIO-16E-4 6040E NI DAQ Card, Analog Input.5Ms/sec
NATIonAL INSTRUMENTS PCI-MIO-16E-4 Board 184002P-01 184004J-01 UL94V-0
National Instruments PC-LMP-16/PnP with PC-DIO-24/PNP ISA Card
National Instruments PXI-1000B, 8 Slot, 3U, PXI / Compact PCI, PXI Mainframe
National instruments PXI-1006 mainframe PXI-5401 , PXI-6713 , 6115 , PXI-6534
National Instruments PXI-1042Q Mainframe with 8330, 6608, 6534(5) Modules
National Instruments PXI-2503 Pxi Multiplexor Switchmodule
National Instruments PXI-2593 PXIRF MultiplexerSwitchModule
National Instruments PXI-2593 Pxirf Multiplexerswitchmodule
National Instruments PXI-4461 2-Input/2-Output Dynamic Signal Analyzer
National Instruments PXI-4461 2-Input/2-Output Dynamic Signal Analyzer NI 4461
NATIonAL INSTRUMENTS PXI-6071E 1.25 MS/S MULTIFUNCTION I/O 64 INPUTS CARD NI
National Instruments PXI-6229 Multifunctiondataacquisition
National Instruments PXI-7954R FlexRIO PXI FPGA
National Instruments PXI-8360 Remote Control Module
National Instruments Pxi-8432/4 Rs-232 4PortSerialInterface
National Instruments PXIe-1065 Backplane
National Instruments PXIe-8106 Embedded Controller
National Instruments PXIe-8880 controller 512Gb SSD, 8Gb Ram
NATIonAL INSTRUMENTS SCB-68 I/O ConNECTOR BLOCK (MM)
National Instruments SCB-68 Yo / O Bloque Conector (MM)
National Instruments SHC68-68-EPM Shielded Cable 68 Pin 2m NI DAQ
National Instruments SignalExpress Software v1.1.1 501280C-01 w/ Serial Number
National Instruments Type X2 763507-02 Rev 1 - 2 Meter Cable
National Instruments USB-6008 Data Acquisition Card NI DAQ, Multifunction in box
National Instruments USB-6009 USB Data Acquisition Card Multifunction 779026-01
National Instruments VXI-MXI-2 VXI Module Unit #2
NATIonAL INSTRUMENTS VXI-MXI-2 VXIBUS C SIZE MODULE 183345D-02 OPTION 920107-04
NATIonAL INSTRUMENTS, NI PXI-4110 Tested with Warranty
Neu Menge 5pcs NATIonAL INSTRUMENTS Mcx Stecker Auf SMA Stecker 1M 188377-01
NATIonAL INSTRUMENTS MCX Plug to SMA Plug 1M -- 188377-01
LOT of 5pcs NATIonAL INSTRUMENTS MCX Plug to SMA plug 1M 188377-01
NATIonAL INSTRUMENTS SHC68-68-EPM EXTENDED PERFORMANCE SHIELDED CABLE
! National Instruments PCIe - 8430/8 RS232 Serial Interface
NI CDAQ-9171 Single Slot CDAQ Chassis 781425-01
NI IMAQ-PCI-1424 video capture card It has been tested
NI National Instruments 183619B-01 High-Performance GPIB Interface PCI Board
NI National Instruments NI PCI-GPIB IEEE 488.2 Interface Adapter Card 188513-01
NI National Instruments PXI-4461 24-Bit 204.8 kS/s
NI National Instruments PXI-6542 100MHz Digital I/O
NI PCI-6071e Assy 184411B-01 National Instruments PcI PC interface
NI PCI-6123
NI PCI-6123
NI PCI-6123
NI PCI-6123
NI PCI-6229 MULTIFUNCTION I/O DEVICE DIGITAL TRIGGERING
NI PCI-6250 16-Bit, 1 MS/s Multifunction I/O Device DAQ PCI card
NI PCI-7314 186357B-04 4 Axis Motor Controller National Instruments PCI7314
NI PCI-8430 RS232 ASSY191880A-01 acquisition card
NI PCI-CAN/XS Series 2
NI PXI-4461 DAQ 24 Bit 204.8 kS/s sound and vibration dynamic186900L-01 PXI4461
NI PXI-5441 100 MS/ arbitrary waveform generator National Instruments 187872J-01
NI PXI-5600 & PXI-5620 185701F-02 186055F-01 NATIonAL INSTRUMENTS
NI PXI-6224 Multifunction DAQ
NI PXIE-1062Q National Instruments PXI Chassis PXIe-1062Q Without Power Module
NI SCXI-1181 Breadboard Module
Nuevo Lote De 5pcs NATIonAL INSTRUMENTS Mcx Enchufe A SMA Enchufe 1M 188377-01
PCI-6024E NI DAQ Card Analog Input Multifunction
PCI-4301 Interface GPIB data acquisition card good in condition for industry use
PCI-6024E Ni Daq Karte Analog Eingang Multifunktion
PCI-6551 NATIonAL INSTRUMENTS NI 50 HZ 20 CHANNEL DIGITAL WAVEFORM DEVICE DB62E4
PCI-6551 NATIonAL INSTRUMENTS NI 50 HZ 20 CHANNEL DIGITAL WAVEFORM DEVICE DD4577
Phoenix Contact NI FLKM 50 760405-01 Connector Terminal Block for NI DAQ
Softing CAN-AC1-PCI CANBUS PCI Card Warranty
USB-6009 Data Acquisition Card Multifunction USB DAQ 779026-01 8CH Analog Input
USB-6218 DAQ USB Data Acquisition 779678-01 32 Inputs Replaces the Original One
USB-6525 DAQ USB Data Acquisition Card 779640-01 Digital I/O 8 Digital Inputs
我们有大量库存的控制系统部件。 我们还有许多新的硬件和停产备件,以帮助支持你现有的控制系统。
您或许会在我们的资料中找到您需要的备品备件,在任何时间,我们都欢迎您对我们产品提出宝贵的建议。
