达文科技MBC-2600系列嵌入式工控机搭载Intel Core i3/i5/i7 CPU,采用模块化设计结果方案,功能拓展性更强,接口全部采用PCBA来实现,内部没有线缆,信号传输稳定可靠,提供丰富接口功能,如Rs232、Rs485、USB、网口、GPIO等等。
| Model Number(产品型号) |
MBC-2600-3865U |
| Processor(处理器) |
Intel® Celeron® 3865Uup to 1.8 GHz |
| Memory(内存) |
2 x DDR4 2133 MHz SO-DIMM up to 32GB |
| Graphic(显示芯片) |
By CPU |
| Operating System(操作系统) |
Windows 7/8/10, WS7E, Ubuntu |
| Storage(存储) |
| Hard Disk(硬盘) |
1 x 2.5寸 SATA HDD / SSD |
| SSD |
1 x Msata |
| I/O Connectors(I/O 接口) |
| COM(串口) |
6 x RS-232(2 x RS-232/485) |
| USB |
4 x USB 2.0, 4 x USB3.0 |
| LAN(网口) |
2 x Intel i211 for GbE |
| Video(显示接口) |
1 x VGA, 1 x HDMI |
| Audio(音频) |
Line Out,Mic |
| GPIO |
NA |
| PS/2 |
NA |
| Remote Switch(远程开关) |
NA |
| Expansion(扩展接口) |
| Mini PCIe |
1 x full-size mini PCIe |
| M.2 |
1 x M.2 2230/2242/2252 5G Module Support |
| SIM |
1 x SIM |
| USB KEY |
NA |
| Antenna hole (天线接口) |
6 x SMA-type |
| Power Management(电源规格) |
| Power Input(输入电压) |
DC 9~36V |
| Qualification(质量鉴定) |
| Certifications(认证) |
CE, FCC Class A |
| Environmental(环境规格) |
| Operating Temp.(工作温度) |
-10 ~ 60℃(SSD) |
| Storage Temp.(存储温度) |
-40 ~ 85℃ |
| Relative Humidity(相对湿度) |
10 ~ 95% (无冷凝) |
| Mechanical(物理规格) |
| Housing(外壳) |
Aluminum alloy(铝合金) |
| Mounting(安装方式) |
Wall-mount(壁挂式) |
| Dimension (W x D x H)(尺寸 (宽 x 深 x 高)) |
280x162x60mm |
| Weight(重量) |
3kg |
| 供货能力 |
2000PCS/month |
| 发货期限 |
3~4 weeks |
| 包装尺寸 |
370x280x140mm |
