3HNE 06777-1
3HNE 06777-1
㊣、销售ABB Robots. FANUC Robots、YASKAWA Robots、KUKA Robots、Mitsubishi Robots、
吅 请致电:0755-23210693 手机:17727975161 QQ:3004632130
微信:17727975161 邮箱:3004632130@qq.com
公司传真:0755-23210691(请注明,仇小姐收)谢谢
公司地址:深圳市宝安区西乡街道前进二路中粮锦云3栋1205
公 司 网 址:www.sz-zhongshide.com
Allen Bradley Laser Bar Code Reader/Scanner 2755-L9SX2 Series A
ALLEN BRADLEY 1746-A13/B SLC 500 13-SLOT RACK (14D0)
axyz converter USB to RS-485
ALLEN BRADLEY 1790-0B16X 17900B16X*NEW*SEALED*
CAREL PCO3010AM0 HVAC PGD0000F00 KEYPAD. ARMSTRONG (2D1)
ALLEN BRADLEY SLC500 ANALOG OUTPUT MODULE -- 1746-NO4I Qty Avail
Allen Bradley 1492-ACABLE010C Pre-wired Cable - New Surplus Sealed
SIEMENS S5 6ES5 941-7UA13 CPU Processor Module
ALLEN BRADLEY 1746-P4 1747-L551 1747-SN 1746-IB16 1746-OB16 1747-DCM
Allen Bradley 2364SPB01A DC New Surplus Open - Series A
Allen Bradley SLC 500 1746-OB32 Series "D" DC Source Output Modul
Allen Bradley 1756-IB16 ControlLogix Input Module - Used - Series
Allen Bradley 1400 1766-L32BXBA 1766L32BXBA *New Sealed 2015*
Allen-Bradley Flex I/O Terminal base 1794-TB32 Ser.A
Foxboro P0970EJ, Rev 0E, Dual Nodebus Extender
Allen Bradley Flex Logix 5433 Processor unit #1794-L33
Foxboro Industrial Power Module IPM2-P0904HA Rev A, P0904HA
Siemens 6ES7138-4CF03-0AB0, Simatic ET 200S Powermodule
PROLINX 4201-DFNT-ASCII GATEWAYBY PROSOFT TECH. SER C(1D3)P
Mitsubishi MR-CCN1CBL-3M Digital Cable 3M ! NEW !
OMRON H7BR-BWV COUNTER 11VA 100-240VAC(2D0)
ALLEN BRADLEY 1769-IQ16 INPUT MODULE 16 POINT 24 VDC SINKING/SOURC
Siemens 6SE9212-1CA40 Micromaster 6SE9 212-1CA40 Frequency converter
Allen Bradley ArmorStart 283D-FB3Z-10A-RR-3-SBW 280D-FN-10-R
Foxboro FCM10E, P0914YM 10 Mbps Coaxial Ethernet to 2Mbps Fieldbus
ALLEN BRADLEY 9300 RAPM1/B REMOTE ACCESS DIAL-IN MODULE
MINI-BRASS 30911-0020 309110020 mini brass pneumatic cylinder *USED
Marposs Rack 8FC3285 / model: 8088020022 / 8FC 3285
ALLEN BRADLEY PANELVIEW 300 -- 2711-K3A10L1 - SER B REV A - DE
Allen Bradley 20-HIM-A3 PowerFlex LCD Display - New Surplus Sealed
ALLEN BRADLEY MPL-B320P-SK74AA MPLB320PSK74AA PN-12131 Servo Mot
GE FANUC SERIES 90 30 IC694DNM200 AB
ALLEN BRADLEY 1771-0AD 17710AD Output Module *NEW IN BOX*
Spectrum Controls 1746sc-INI4i SLC 500 Analog Current Input - Used
Siemens 6ES7414-2XJ01-0AB0, 6ES7414-2XJ01-0 +Siemens 6ES7952-1AH00-0AA0
MATSUSHITA FP2-X16D2 NAIS INPUT MODULE (16B2)
GE FANUC A06B-6096-H106 SERVO AMPLIFIER
Siemens SMP-E14-A31, Siemens C8451 A10 A2 5
Allen Bradley 1746-A4 SLC 500 4 Slot Chassis - Used - Series A
Allen-Bradley 871TM-BH10N30-H2 Proximity Sensor - Used - Series A
Allen Bradley 1769-IF8 CompactLogix - New Surplus Sealed - Series
GEFRAN Model 2301 # 2301SI02R1 - 2301-SI-0-2R-1
Allen Bradley 2097-V32PR0000X1F14 Kinetix Drive - New Surplus Seal
Allen-Bradley 1492-CABLE010A Pre-wired Cable 1 m - Used - Series
ALLEN-BRADLEY 1794-PS1/A POWER SUPPLY MODULE SER A (3A2)
Controls 1746sc-IB8I Isolated Input Module - Used - Serie
Siemens 6EC1010-0A Simatic 6EC1 010-0A Module
ALLEN BRADLEY 2711-NT1 2711NT1 touchscreen replacement kit *NEW IN
Allen-Bradley 1747-L541 CPU Module 16K Memory ! NOP !
Allen-Bradley 1794-TB3 FlexBus Terminal Block - Used
SIEMENS SIMATIC 505-6660 Power Supply Module
Siemens Bridge A+B E52930-A3090-L1-C
SIEMENS 6EP1333-3BA00 SITOP MODULAR 5A 1/2 PH POWER SUPPLY
Allen Bradley, SLC 500, 1492-CABLE010H, For 32-Point I/O Modules
Beijers SC-05N Programming Cable
OMRON PLC CS1W-OD292 OUTPUT UNIT
WABCO TRAINlink 17149 MODULE PULSE ELECTRONICS GE 41A296352BCP2
PILZ PNOZ S4 PNOZS4 safety relay *USED & TESTED*
OMRON H8PS-8 BFP H8PS8BFP CAM POSITIONER 24 VDC *USED & TESTED*
OMRON CPM1-CIF11 RS422 Interface Unit Module - Used
Allen Bradley 2364-SPG03A - New Surplus Sealed - Series A
Allen Bradley 1492-CABLE050TBCH Digital I/O Ready Cable - Used - INDUSTRIAL ICOP VSX-6150E-V2,CPU BOARDS Vortex86SX
Lambda JWS150-24/A AC-DC Conv, Enclosed, 1 O/P, 156W 6.5A 24V !
MITSUBISHI FX2N-1HC HIGH SPEED COUNTER MODULE (1C6)
Allen Bradley 1794-IF4I Flex I/O Analog Input - New Surplus Seale
FANUC A06B-6042-H123 VELOCITY CONTROL - incomplete
Allen Bradley ControlLogix 1756-OB16E DC Output Module *NEW*
ALLEN-BRADLEY 1756-OB16E DC EFUSED OUTPUT MODULE SER A (1B5)
Allen Bradley 1756-PA72 Power Supply - New Surplus Sealed - Serie
Allen Bradley 1756-M16SE A Sercos Interface Module
MEASUREX UNIGAGE BACKPLANE 05401100 Rev D NEW (3C6)
Allen Bradley 1761-NET-AIC Interface Converter - New Surplus Open
ALLEN-BRADLEY 1784-KT/B COMMUNICATION INTERFACE MODULE (3B6)
ALLEN BRADLEY 1756-M02AE/A 2 AXIS SERVO MODULE F/W REV 3.10
SIEMENS 6ES7 315-1AF03-0AB0 SIMATIC S7-300 CPU 315 (1D2)P
Automation Direct D2-250-1 DirectLOGIC 205 Series PLC CPU Module
SIEMENS 6ES5 451-8MR12 *NEW* SIMATIC S5 RELAY OUTPUT MODULE
SIMATIC S7-300 PLC, WinCC, and
Allen Bradley 1783-MS10T Stratix 8000 - Used - Series A
ALLEN-BRADLEY 1756-M16SE SER A 16 AXIS SERCOS INTERFACE MODULE FW.
Spectrum Controls 1746sc-IB8I Isolated Input Module - Used - Serie
