安川变频器H1000系列HB4A0060(22KW)
㊣、销售ABB Robots. FANUC Robots、YASKAWA Robots、KUKA Robots、Mitsubishi Robots、
吅 请致电:0755-23210693 手机:17727975161 QQ:3004632130
微信:17727975161 邮箱:3004632130@qq.com
公司传真:0755-23210691(请注明,仇小姐收)谢谢
公司地址:深圳市宝安区西乡街道前进二路中粮锦云3栋1205
公 司 网 址:www.sz-zhongshide.com
Mitutoyo AT2-LN700 Linear Scale 700mm
GE FANUC IC697PWR711 N 90-70 POWER X FACTORY SEALED IC697PWR7
OMRON 3G2C7-MC22C PLC I/O MODULE
Siemens 3RK1 200-0DQ00-0AA3 Compact Module
6ES7322-1BF01-0AA0 Siemens S7 output MODULE DO 8* DC24V/2A--NEW
Allen Bradley 1746-P2 Power Supply Module 265V WOW
GE FANUC IC693BEM331-K CONTROLLER SERIES 90-30 (1D2)
Allen Bradley 1492-ACABLE025C Pre-wired Cable for 1746-NI8 - New
IFM 01D100 O1DLF3KG Optical Distance sensor
Facts Engineering F2-04THM Input Module
Allen-Bradley 1395-KP51 Communication Adapter Board, 196274, 196284
Yokogawa Johnson EJX530A-EBS7N-022DF Transmitter 0-4bar
Fanuc amplifier A06B-6124-H209
Allen Bradley 1793-IB16S 1793IB16S 24V DC Input Module *NEW SEALED
PROLINX 4201-DFNT-ASCII PROSOFT TECH. SER C(1D3)P
GE FANUC A04B-0800-C005 TURBO BLOWER NIB
ALLEN BRADLEY 1746-NI4 ANALOG INPUT MODULE
YOKOGAWA YF104 VORTEX FLOWMETER NEW IN BOX
ALLEN BRADLEY 1394-AM04 1394AM04 servo controller *USED & TESTED*
GE FANUC VELOCITY CONTROL UNIT A06B-6042-H102
Allen Bradley 1794-TB32 Flex I/O 32-Ch Terminal base - Used - Se
Allen Bradley 1336-BDB-SP46C Drive 460v 600HP - New Surplus Open converter USB to RS-485
Siemens Sinumerik 6FX1126-1AA01 / 6FX1 126-1AA01
Siemens 6GT2002-2CE00, MOBY I ASM 424
Allen-Bradley 1746-IA16 SLC500 INPUT Module 1746IA16
HONEYWELL 4DP7APXID411 CARD NEW IN BOX
SIEMENS 6ES7 131-7RF00-0AB0 INPUT CARD SIMATIC S7 (3F3)
Siemens 6ES7407-0KA01-0AA0, unused
BANNER ENGINEERING Backlight LED LEDRB100200N 65657 *USED & TESTED
ALLEN-BRADLEY 1336-MOD-N1 *NEW IN BOX* ISOLATED SIGNAL CONDITIONER
Spectrum Controls 1756sc-OF8H Allen Bradley - New Surplus Open -
OMRON E5CW-Q1KJ E5CWQ1KJ Temperature Controller * USED & TESTED* S
Yokogawa EJX530A-EBS7N-022DF Absolute Pressure Transmitter 0-4bar
Allen Bradley 1745-LP103 SLC 100 Expansion Unit
HONEWELL MEASUREX CONTROL PROCESSOR 09472000 MXOPENCONTROL MXOPEN R
FANUC A16B-3200-0190 /03B MAIN CPU WITH DAUGHTER BOARDS -- NEW!!!
Allen Bradley Flex RI/O 1794-OB16 1794OB16 16 Point DC Output NIB
Allen Bradley SLC 150, 1745-E153 ser A expansion unit ***TESTED***
NCRB50-90 NCRB5090 pneumatic rotary actuator *USED & TESTED*
Allen Bradley 1794-ADN Media AdapterModule - New Surplus Sealed - Engineering F2-04THM Input Module
Sinumerik System 8 6FX1114-5AA00 MS710 PLC INTERFACE
Allen Bradley 1794-L34 FlexLogix Processor 512KB - New Surplus Ope
Allen Bradley 1492-CAB025K69 - Used - Series
Allen Bradley 845T-DB52EDN-C Incremental Encoder - New Surplus Open
Allen Bradley 1492-ACABLE025Y - Used - Series A
ELECTRIC DS200KLDCG1AAA 6BA03 *NEW* LED KEY DISPLAY BOARD (3B6-PA)
BANNER LG10A65PUQ gage sensor *USED & TESTED*
MEMORY SYSTEMS CM1746 AUTO ID MODULE NEW IN BOX
Allen-Bradley Panelview Plus 1250 2711P-RDK12C with 2711P-RP1A inclu
REXROTH VT5040 S32 A10VSO NG28 ELECTRIC PROPORTIONAL CARD
ALLEN BRADLEY 1746-OA16 1746OA16 output module *USED & TESTED*
LOGIC RELAY OEM PLC GENIE 10 I/O AC REPLACES SIEMENS
MEASUREX 05310500 REV B CONSTANT POWER OUTPUT MODULE
Allen-Bradley 1492-IFM20D24-3 Digital IFM 20-Point 3-Wire In - Used
Allen-Bradley 1202-C03 DPI/ScanPort Cable - Used - Series A
1745-TCAT - Allen Bradley - HMI Timer Counter Access Terminal
Siemens Simatic 6GT2002-1HD00 / 6GT2 002-1HD00 / RF170C
Allen Bradley 1336-L5E Controller Interface Card 24VAC/DC ! WOW !
PANASONIC CR1/3N AFP1801 3V FP1-C24 FP1-C40 FP1-C56 PLC Battery
ALLEN BRADLEY 1746-OB16 1746OB16 output module *USED & TESTED*
ABB Terminal Block DI/DO86-32CHF, 58172855 C
