厦门仲鑫航自动化设备有限公司
Xiamen Zhong Xinhang automation equipment Co., Ltd.
≠≠≠≠联系人:郑娟萍 电 话:0 5 9 2 -5 1 7 3 2 7 9
传 真:0 5 9 2- 5 1 6 5 5 6 1 [[[Q:2 7 7 3 7 3 4 0 8 8
邮 箱: 2773734088@qq.com
""""地 址:福建省厦门市思明区湖滨四里64号(湖光大厦)第八层A座
厦门仲鑫航自动化设备有限公司
欢迎您来询价 拨打热线
在新的一年祝您洋洋得意 三阳开泰 喜气洋洋 什么坏的都扬长而去
主要的品牌与型号:PLC 、DCS 系统备件 模块ABB Robots. FANUC Robots、KUKA Robots、Mitsubishi Robots、Panasonic Robots。
Siemens(西门子):Siemens MOORE, Siemens Simatic C1,Siemens数控系统等。
Bosch Rexroth(博世力士乐):Indramat,I/O模块,PLC控制器,驱动模块等。
Invensys Foxboro(福克斯波罗):I/A Series系统,FBM(现场输入/输出模块)顺序控制、梯形逻辑控制。 >>>>>>>>
Bosch Rexroth(力士乐):、HONEYWELL TDC系列, QCS,S9000等备件。
电子传动与控制,I/O模块,PLC控制器,驱动器GE IC647/693/697/698系列。
ircuit Breaker 3 Pole 240 V 225 Amp
Square D FA34015 I Line Circuit Breaker 15 Amp 3 Pole 480 V
Square D FA34015 15 Amp 480 V 3 Pole I Line Circuit Breaker
Square D Size 1 Fusible Combination Starter NEMA 1 120 V Coil 208-120 Cntl Trans
Square D FA36020 20 Amp 600 V 3 Pole I Line Circuit Breaker
Square D Size 2 Stainless Steel Combination With FAL34040 Circuit Breaker
Square D Size 1 Starter 8536 SCO 3 Series A 120 V Coil
Square D MEL36800LS Circuit Breaker 800 Amp 600 V 3 Pole With LSI
Square D Enclosed Circuit Breaker With FAL34090 90 Amp 3 Pole 480 V
Square D FH36020 I Line Circuit Breaker 20 Amp 600 V 3 Pole
Square D FAL22090 90 Amp 2 Pole Circuit Breaker
Square D FA 340201212 20 Amp I-Line Circuit Breaker
Square D HJA36070 70 Amp 3 Pole 600 V I Line Circuit Breaker
Square D MAP36500 Circuit Breaker 500 Amp 3 Pole 600 V
Square D Q232150 I Line Circuit Breake 150 Amp 3 Pole 240 V
Square D FA3607035 I Line Circuit Breaker 70 Amp 3 Pole 600 V
Square D FA22030BC I Line Circuit Breaker 30 Amp 2 Pole 240 V
Square D PowerPact QBL22200 200 Amp 240 V 2 Pole Circuit Breaker
Square D FH16020C I Line Circuit Breaker 20 Amp 1 Pole LOT OF 2
Square D FA34020 20 Amp 480 V 3 Pole I Line Circuit Breaker
Square D LA36350 600 V 3 Pole I Line Circuit Breaker
Square D Starter 8536 SBO NEMA Size 0 120 V Coil
Square D Size 0 Starter 8536 SBO 2 120 V Coil
Square D FA26030BC 30 Amp 600 V 2 Pole I Line Circuit Breaker
Square D Contactor 8536 SB0 1 Size 0 With 120 V Coil
Square D FH36020 I Line Circuit Breaker 20 Amp 3 Pole 600 V
Square D IF34100 I Line Circuit Breaker 100 Amp 3 Pole 480 V
Square D DTU222 60 Amp Double Throw Type 1 Enclosure
Square D ME36800 LIG1253 800 Amp I - Line Circuit Breaker
Square D Q1L3100 Circuit Breaker 100 Amp 3 Pole 240 V
Square D QO Load Center QO8-16L100RB 100 Amp 3 R Enclosure 120/240
Square D FH26020AC I Line Circuit Breaker 20 Amp 600 V 2 Pole
Square D Power Logic Circuit Monitor Class 3020 CM-2250
Square D LA36400 400 Amp 3 Pole 600 V I Line Breaker Used Great Condition
Square D QO120AFI Circuit Breaker 20 Amp 1 Pole LOT OF 5
Square D LAL36400 Circuit Breaker 400 Amp 600 V 3 Pole
Square D LH34400 400 Amp 3 Pole 480 V I-Line Circuit Breaker
Square D QO220 20 Amp 2 Pole Circuit Breaker
Square D KCP34125MT Circuit Breaker 125 Amp 480 V 3 Pole
Square D KA36225 I Line Circuit Breaker 225 Amp 3 Pole 600 V
Square D FI360901021 I Limiter Circuit Breaker 90 Amp 600 V 3 Pole With Shunt
Square D FHB36030 I Line Circuit Breaker 30 Amp 600 V 3 Pole
Square D Q432400 I Line Circuit Breaker 400 Amp 3 Pole 240 V
Square D Lighting Contactor 8903 V011 Series C 200 amp 480/277 In Enclosure
Square D Lighting Contactor 100 Amp 8903 SGO2 208 V Coil Series A
Square D Overload Relay Type DD250 LOT OF 5
Square D Q232175 175 Amp 3 Pole 240 V I Line Circuit Breaker
Square D EGB34100 3 Pole 100 Amp Circuit Breaker Used
Square D Starter 8536 SCO NEMA Size 1 120 V Coil
Square D FAL24070 480 V 2 Pole Circuit Breaker
Square D Starter 8536 SCG 3 Size 1 With 120 V Coil
Square D MHL3640025DC1679 400 Amp 600 V 3 Pole W/Auxiliary W/Undervoltage Trip
Square D QOB120 Amp 1 Pole HACR Type Circuit Breakers LOT OF 5
Square D Q232125H 125 Amp 3 Pole 240 V I Line Circuit Breaker
Square D Size 3 Starter 8536 SEO1S (2) and SEO1 (2)
Square D EDB14020 Circuit Breaker 20 Amp 1 Pole LOT OF 4
Square D LA36400 I Line Circuit Breaker 400 Amp 3 Pole 600 V (Black)
Square D MAL36800 800 Amp 600 V 3 Pole Circuit Breaker
Square D HGA36050 3 Pole 50 Amp 600 V I Line Circuit Breaker
Square D General Purpose Relay 8501 KPD12V63 Series D
Square D LH36350 I Line Circuit Breaker 350 Amp 3 Pole 600 V
Square D 30 Amp Heavy Duty Safety Switch HU361RB 3R Enclosure 600 V Non Fused
Square D HCN 3039500-BO 400 Amp I Line Panelboard W/LAP36400MB 3 Ph 3 W 240 V
Square D NC36800 I Line Circuit Breaker 800 Amp 600 V 3 Pole
Square D KI36225 I Line Circuit Breaker 225 Amp 600 V 3 Pole
Square D Overload Relay Thermal Unit CC 42.7
Square D MAL36600 Circuit Breaker
Square D FA36050 50 Amp 600 V 3 Pole I Line Circuit Breaker
Square D IF36100 I Line Circuit Breaker 100 Amp 3 Pole 600 V
Square D FC34050 I Line Circuit Breaker 50 Amp 480 V 3 Pole
Square D IF34100 100 Amp 3 Pole 480 V I Line Circuit Breaker
Square D FA36050 I Line Circuit Breaker 50 Amp 3 Pole 600 V
Square D FA34090 I Line Circuit Breaker 3 Pole 480 V 90 Amp
Square D I Line 300 Amp Main Breaker Panelboard HCN 44-92090-11 120/208 3 Ph 4W
Square D I Line 400 Amp Main Breaker Panelboard HCN 44-92090-11 120/208 3 Ph 4W
Square D EDB24060 Circuit Breaker 2 Pole 480 V 60 Amp
Square D Size 1 Starter 8536 SCO With 120 V Coil
Square D 60 Amp D322N Heavy Duty Safety Switch Fusible NEMA 1 240V
Square D FY14020B I Line Circuit Breaker 20 Amp 1 Pole 480 V
Square D LAP36400MB Circuit Breaker 400 Amp 600 V 3 Pole
Square D Size 3 Fusible Combination Motor Starter 8538SEG 600 V
Square D LAL364001021 400 Amp Circuit Breaker 600 V 3 Pole
Square D 9001KP1R31 Pilot Light
Square D HJA36100 I Line Circuit Breaker 100 Amp 3 Pole 600 V
Square D FA24100AC I Line Circuit Breaker 100 Amp 2 Pole 480 V
Square D Circuit Breaker KHP36110 1027 3 Pole 600 V 110 Amp
Square D FAL22080 80 Amp 2 Pole Circuit Breaker
Square D FA22040 AC 2 Pole 40 Amp I-Line Breaker
Square D FA26040AB 40 Amp 2 Pole 600 V I Line Circuit Breaker
Square D EHB14020AS Power
Square D 8536 SB02 A NEMA Size 0 120 V Coil Starter
Square D FCB34100 I Line Circuit Breaker 100 Amp 3 Pole 480 V
Square D PowerPact MJA36450 I Line Circuit Breaker 450 Amp 600 V W/Instantaneous
Square D HU363RB Heavy Duty Safety Switch 100 Amp 600 V NEMA 3 R Non Fusible
Square D HU364RB Disconnect 200 Amp 600 V Non Fuse 3R Enclosure
Square D Q232225 225 Amp 3 Pole 240 Volt I-Line Breaker
Square D Starter NEMA Size 0 8536 SBO 2S 120 V Coil
Square D Starter 8536 SB02 Size 0 With 277 V Coil
Square D FH36015 15 Amp 600 V 3 Pole I Line Circuit Breaker Gray
Square D FH26100AC I Line Circuit Breaker 100 Amp 2 Pole 600 V
Square D FAL22030 30 Amp 2 Pole Circuit Breaker
Square D MAL36600 600 Amp 600 V 3 Pole Circuit Breaker
Square D Q232175H 175 Amp 3 Pole 240 V I Line Circuit Breaker
Square D MHL36300 300 Amp 3 Pole 600 V Circuit Breaker
Square D MH36800 I Line Circuit Breaker 800 Amp 600 V 3 Pole
Square D KAL36150 Circuit Breaker 150 Amp Used
Square D FY14020B And FY14020C I Line Circuit Breakers 20 Amp MIX LOT OF 4
Square D MHL36600 600 Amp 3 Pole 600 V Circuit Breaker
Square D HACR Type QO215 Amp 2 Pole Circuit Breaker
Square D HACR Type QO260 Amp 2 Pole Circuit Breaker
Square D FA22060AB 60 Amp 2 Pole 240 V I Line Circuit Breaker
Square D FA26030AC I Line Circuit Breaker 30 Amp 2 Pole 600 V
Square D 8536 SC0 3 NEMA Size 1 120 V Coil Starter
Square D Q232225H I Line Circuit Breaker 225 Amp 3 Pole 240 V
Square D Current Transformer Ratio 1000:5 76R-102 BIL 10 KV 600 V
Square D FH36060 I Line Circuit Breaker 60 Amp 3 Pole 600 V
Square D FH36040 I Line Circuit Breaker 40 Amp 3 Pole 600 V
Square D LAP36300 MB 300 Amp Gray Label Main Breaker
Square D MHP36800 Circuit Breaker 800 Amp 600 V 3 Pole
Square D HU364N Disconnect 200 Amp 600 V Non Fuse Type 1
Square D FH26030BC 30 Amp 2 Pole 600 V I Line Circuit Breaker
Square D Q232125 I Line Circuit Breaker 125 Amp 3 Pole 240 Volt Q
Square D FA36030 I Line Circuit Breaker 30 Amp 600 V 3 Pole (Black)
Square D EGB24020 20 Amp 2 Pole Circuit Breaker
Square D PowerPact MJA36800 I Line Circuit Breaker 800 Amp 600 V W/Instantaneous
Square D QOB340 amp 3 Pole 240 V Circuit Breaker
Square D 400 V Coil 50 Cycle 31104-400-50
Square D 200 Amp Disconnect H324NRB 240 V 3R Enclosure
Square D 125 Amp I Line Panelboard HCN 1511722-820 With 125 Amp Main 277/480
Square D 8536 SAG12 Size 00 120 V Coil Starter
Square D HGL36125 Circuit Breaker 125 Amp 600 V 3 Pole
Square D FA32020 20 Amp I-Line Circuit Breaker Black
Square D NF 400 Amp Main Breaker 30 Circuit Panelboard with additional 200 Amp
Square D Power Relay 8501CO21V20 Series C
Square D FA 34020 20 Amp I-Line Circuit Breaker Gray
Square D HCW 37231-1A1 800 Amp Panelboard With 800 Amp Main 3 Ph 4 Wire 120/208
Square D Size 0 Starter 8536 SB02S With 120 V Coil
Square D QDA221102 PowerPact I Line Circuit Breaker 110 Amp 2 Pole 240 V
Square D KH362251021 225 Amp 3 Pole 600 V With Shunt
Square D Q32150H I Line Circuit Breaker 150 Amp 3 Pole 240 V
Square D FAB34020 20 Amp 480 V I Line Circuit Breaker
Square D Q2L3200 200 Amp 3 Pole 240 V Circuit Breaker
Square D FA34030 1212 30 Amp 3 Pole 480 V I Line Circuit Breaker With Shunt
Square D LH36400 400 Amp Circuit Breaker Used
Square D KAL361256139 Circuit Breaker 125 Amp 600 V 3 Pole With Shunt 120-240 V
Square D MAL36800 800 Amp 3 Pole 600 V Circuit Breaker
Square D PAF2036 Circuit Breaker 2000 Amp With 1400 Amp Trip PAF
Square D 30 Amp Disconnect DU321 Type 1 240 V
Square D FA36020 I Line Circuit Breaker 20 Amp 3 Pole 600 V
Square D IKL36225 I-Line I-Limiter 225 Amp 3 Pole 600 V Breaker
Square D QDL32200 Circuit Breaker 200 Amp 3 Pole 240 V
Square D Size 1 Starter 8536 SCG 3 Ser. A With 120 V Coil
Square D 1600 Amp I Line Panelboard HCWM 44-91441-1 3 Phase 4 Wire 208Y/120
Square D KA36110 110 Amp 3 Pole 600 V I Line Circuit Breaker
Square D KAP36225 225 Amp 600 V Circuit Breaker Gray
Square D HJA260702 2 Pole 70 Amp I Line Circuit Breaker
Square D IF34050 50 Amp 480 V I Line Circuit Breaker
Square D Starter 8536 SB0 2 Size 0 With 240 V Coil
Square D Lighting Contactor 8903SMG2 30 Amp 120 V Coil Enclosure
Square D FA26040AB I Line Circuit Breaker 40 Amp 2 Pole 600 V
Square D Q08-16L100DS Load Center Indoor 120/240V 100 Amp 1 Phase 3 Wire
Square D 400 Amp Panelboard NF12119198010630001 600 Y 3 Ph 4 W W/200 Amp 42 Slot
Square D Size 3 Reversing 2 Speed 50 HP Class 8810 Type SE02 460 V Type 12/3R
Square D FAP3603015M 30 Amp 3 Pole 600 V Circuit Breaker
Square D FH36070 I Line Circuit Breaker 70 Amp 3 Pole 600 V
Square D Size 1 Starter 8536 SC0 3BS Series B 120 V Coil (B)
Square D KIL36225 Circuit Breaker 225 Amp 600 V 3 Pole
