⑶ 机器拆开时,要对被拆件、线头、零件做好笔记。再装配时处理好原装配上的各类技术措施,不得简化、省略。例如,输入的双绞线、各电极连接的电阻阻值、绝缘件、吸收板或吸收电容都要维持原样;要对作了修焊的驱动印制板进行清洁和防止爬电的涂漆处理,以及保证绝缘可靠,更不要少装和错装零部件。
⑷ 并联模块要求型号、编号一致,在编号无法一致时,要确保被并联的全部模块性能相同。
⑸ 对因炸机造成铜件的缺损,要把毛刺修圆砂光,避免因过电压发生尖端放电而再次损坏。
四、更换模块后的通电
经常会更换模块后,一通电又烧毁了。为防止此类事故,一般在变频器的直流主回路里串入一电阻,电阻阻值为1耀2k赘,功率50W以上,由于电阻的限流作用,即使故障开机也不会损坏模块。空载时流过电阻的电流小,压降也小,可做空载检查。
一般只要空载运行正常,去掉电阻大都会正常。
Fisher Scientific Digital Tachometer NICE SHAPE!
Honeywell Micro Switch OP-N Splash Proof?Limit Switch
BK Precision 1630A DC Power Supply
Hoffman Specialty B1125S 3/4" Steam Bucket Trap UNUSED
Norgren Nugget 200 Directional Control Spool Valve
EGS E150 .150 KVA 1PH Industrial ControlTransformer
Reliance Electric AutoMate 45C1A Programmable Controller
NEC VL-LP6 Projector?Lamp Unit MT830/1030
Warner EM-50-10 Frame : 48Y-56C Motor Clutch
Square D 8501XD040V62 DC Control Relay
Hammond IB629 2.5" Bronze Gate Valve
Crouse Hinds Arktite?AR337 30 amp Receptacle
Kaeser REG-050-195 Series "A" Regulator?
Carlon Thomas & Betts NC884 8"X8"X4" Circuit Safe Enclosure?
Rockwell Automation?AK-R2-091P500 Dynamic Brake Resistor
Kunkle 6182DC01-KM 1/2" Safety Valve
Dayton 4C869 1/20 HP?230 Volt Blower
Fanuc AID16D Input Module
Watlow DIN-a-mite DB20-60F0-0000 Solid State Relay
Westinghouse HMCP030H1C 30amp Circuit Breaker
North American Signal MIP-ACR 120 Volt Visual Signaling Appliance
Turck Bi3U-M12-AP6X?Proximity Switch LOT?OF 2-
Psion Model XP Organiser II Personal Organizer
Robertshaw 780-715U?Ignition Control Unit
Allen Bradley 800H-NP31 Explosion Proof?Stop/Start Station
Valtek 22/06 BETA I/P Positioner Valve LOT OF 2
Allen Bradley 1305-AA02A .5HP VFD Drive
Bellofram 960-069-000 Pressure Regulator?
Sonic Torque Sharpe?Model SPN050 Valve Actuator
Levelite GLL110020 Probe Remote Optical?25' LOT OF 2-
Thames Side 350-TS 500 Kg Load Cell
Pulsafeeder Pulsatrol Series 100 Controller
Banner SM2A912LVQD Valu Beam Sensor
Rees 04945-000 Rope?Operated Sequence Switch
Fireye 60-2206-1 Wiring Base
Fireye 1020 Ultraviolet Scanner 45 UV2
Clark 933606 Forklift Starter
MCC Powers Low Differential Pressure Transmitter PT 141-1?
Mead Single Acting Air Clamp H42-6
Burkert Actuated Valve w/Mechanical Switch
RCA Constant Voltage?DC Power Supply WP-703A
Leeson 110056.00 1/2HP 1PH Motor
Asco 8344B60 3/8" 4-Way Dual Solenoid Valve
Devar 18-232 Sensor?w/Hubbell Killark HKGL 0496 HKB 0796 Enclosure
Honeywell Micro Switch 51ML72 Precision?Limit Switch
Levelite GLL110020 Electro Optic Remote?Probe
Square D GG2 9036 Open Tank Float Switch-SEALED!
Sepco ML2254 6MM Packing
Thermo Ramsey Pro-Line 20-42-25 Mini Tilt Switch
Square D 9012AEW-1 Pressure DifferentialControl
Allen Bradley 1606-XLP30E Power Supply?NICE SHAPE
Sola SDN2.5-24-100P?Power Supply NICE SHAPE
Omega BD-821 Digital?Control
Parker Skinner A3LB2127 Valve
Honeywell Meredian 31117481 Gel Filled Diffusion Reference Electrode LOT OF 3
Global CS-35 Industrial Vibrator
Flowserve Automax NXCLU2PE-18-00200 Ultraswitch
MicroSwitch BAF1-2RN4-LH Limit Switches?UNUSED- LOT OF 2
Honeywell MicroSwitch LSP6B Heavy Duty Limit Switch
Rosemount Uniloc 1181 PH 2 Wire Transmtter UNUSED
Asco 8317G308 1/4" Solenoid Valve
Allen Bradley 1203-GD1 Remote I/O Communications Module
Square D FAL36030 30?Amp Molded Case Circuit Breaker
Siemens ITE ED43B030L 30 Amp Circuit Breaker
Siemens ITE ED43B020L 20 Amp Circuit Breaker
Emerson IE-105 Islatrol IE AC Power Filter
Automatic Valve L2003AAWR-AAY Solenoid Valves LOT OF 2
TI / Siemens 505-4916 Relay Output
Turck FDNP-CSG88-TT?Input/Output StationLOT OF 2-
Ingersoll Rand XPM-G1 Power Supply
ProMinent 7744097 1/2" FNPT Pulsation Dampener
Baldor Dodge 50 X 1-3/8" Torque Tamer
UE 10-D10 Spectra 10?Series Pressure Switch
AWS Model: PSI-8031?Motor Rotation Tester
H-W Fairway 1686-B Pull Cord Switch
Square D QO3100 100?Amp Circuit Breaker
Warren Electric XBF?4500 Watt Electric Immersion Heater
Numatics A14SS4158047E30 120 Volt Directional Control Valve?
Acopian A24H1200 Regulated Power Supply?
Viking F456 .5" Gear?Pump
Toshiba VF-S11 2HP Transistor Inverter Drive
Gould Pressure Transmitter PG3000-200-42
QMS Autospect QMSBP?1068
Bussmann FRS-R-150 Amp Fusetron Fuse LOTOF 4-
Dresser/Ashcroft B720B X06 Pressure Switch
Envirotech Sensall 108BD Control
Jayco Fisher 3/8" In-Line Air Filter & Water Trap W-181
Dwyer 603A-3 0-2in.W.C. Pressure Transmitter -NO BOX
Jupiter Pneumatics 720 1/2" Drain Valve?
Bussmann Low-Peak LPS-RK-200SP 200amp Fuses -LOT OF 2
Eurotherm EMD/DM/4-20MA Dual Module
Eurotherm 145/HNL/HNL/J/0-500C/115V/BB/X11 Temperature Controller
Square D 8501 HO-40?AC Control Relay
DigiTec Counter 2810A-10DX
Yuken DSG-03-2D2-A120-5090 Directional Valve
Fisher 98H-38 Relief?Valve
Taylor Transaire Transmitter Model 2
Acrison 121-0434 230volt Control Board NICE SHAPE
Allen Bradley SLC500?Input Module 1746-IV8
Allen Bradley 800H-1HVX7 3/4" Mulit-Gang Modular Enclosure?
Fisher Type 98HH 1/4" Relief Valve
Emerson XB-1019 HCA-1B Power Assembly
Allen Bradley 871C-A5N18-R3 Inductive Proximity Sensor IN SEALED BAG
MEKontrol MEK-5520-AG5 Light Beam Limit?Switch
ITT Conoflow GB51XN1974 Pneumatic PistonActuator
Honeywell C437 Gas Pressure Switch
Crouse Hinds D2CB11?20amp Explosion Proof Circuit Breakers LOT OF 2
Omega DP24-E Digital?Panel Meter
Yokogawa UT35 Digital Indicating Controller
Barksdale D3H-AA2SS?Pressure or Vacuum Actuated Switch
Barksdale Pressure /?Vacuum Actuated Switch D2T-A150SS
Foxboro Model 697 Conductivity Converter
Yokogawa Juxta FHOV*A Signal Conditioner?
Legacy Grease Gun L1320
Allen Bradley 1334-MOD-T7 30HP Mod Kit?Motor Overload Relay?
Agastat 7012AFL Timing Relay
Nicholson CS 1.5"-2"?Stainless Steel Steam Trap Repair Kits?-LOT OF 4
Bussmann Low-Peak LPS-RK-150SP 150amp Fuses -LOT OF 2
ITT Neo-Dyn Adjustable Pressure Switch?
Delaval Barksdale D2X-A80-UL Pressure Switch
Acromag 319-BX-U Transmitter & DC Supply
Pfaudler 1 1/2" Glass Lined Elbow
Armstrong OB-2000 Thermal Bulb
Honeywell Microswitch LSXC4L Explosion Proof Limit Switch
Danaher Dynapar H561500 Encoder
Ashcroft General Service Gauge 45 1017A 60 PSI
MICRO SWITCH 2LN1-2-RH Snap Switch
Rees 00294-004 Mushroom Plunger Switch UNUSED
Parker Sinclair Collins Model: K10-1 Pneumatic Positioner
TRW 4 1/4" 10 TPI Die (UNUSED)
Siemens Simatic Measuring Range Module 6ES5498-1AA31
Gould I-T-E JL3T090?400amp Circuit Breaker Trip Unit
Concoa Airco Single?Stage Regulator 08069932 Acetylene CGA?025
Arrow Pneumatics 3/4?Lubricator L386W?
Asco JS P8340A001 1/4" Solenoid Valve w/?Slice Box
Square D 8501XO20V02?AC Control Relay
Badger Meter 1002GCN36SV0P0000 Research?Control Valve Actuator
Marsh W0410 0-300psi?Gauges LOT OF 6-
Giacomini A56 Brass?1.5"X1.5" Fire Hose?Angle Valve
Honeywell S427D 1007?Plug-In Purge Timer?
Honeywell C437G 1002?Gas/Air Pressure Switch
Asco VR7C2Y Valve Position Indicator
Allen Bradley 194R-NJ030P3 Disconnect Switch
Piab LC30 Level Compensator
Ranco P30 Lube Oil Pressure Control
Honeywell STT3000 Temperature Transmitter
Parker K022090 Sub Base Double Solenoid?
Allen Bradley 700-PT?Pneumatic Time Delay Unit
Powers 134-1511 Low?Temperature Cutout Control
Acromag Signal Isolator 1702-LL-TV-1
Leeson Motor 3PH 1/2 HP C6T34NC1C?
Bussmann LPS-RK-400SP Dual-Element Time?Delay Fuses -LOT?OF 3
Kuri Tec K010 3/4"X1" 100ft Klearon Clear PVC Food GradeTubing
Square D EA1AF-400 AC Ammeter
Cash-Acme Type B 3/4" Pressure Regulating Valve
Ametek PSCL-S1 Clear?Water Filter
Siemens / Furnas 50MA3HJE Control Station w/ 3 Push Buttons?
Cosel K150AU-12-N Power Supply
Velan 3/4" Stainless?Steel Ball Valve UNUSED
Watts R364-02CK Miniature Regulator 1/4"?LOT OF 4-
KTM Type EB11 Stainless Steel 1/2" Ball?Valve
IFM Efector IF5188 Inductive Proximity Switch LOT OF 2-
Penn Johnson Controls P45NCA Oil FailureCutout Control
Fisher Type 289H-41?1" Relief Valve
Eaton / Cutler Hammer C10CG20A Size 1 Magnetic Contactor
Powerstat Variable 3PN116B Autotransformer
Allen Bradley 700-HA33A1 10 Amp Relays LOT OF 8-
Asco 8262G022 1/4" 24DC Solenoid Valve
Watlow DC20-60K2-0000 Solid State Power?Control
Micromotion RFT97121PNU Remote Flow Transmitter
Grinnell 3000SJ 3"?200WOG Brass Gate Valve
Asco 8344B60 3/8" Four-Way Solenoid Valve
Atkomatic 15448-G-XWP 1" Solenoid Valve?
Rosemount Series 68?Temperature Assembly
Banner / Videojet Mini Beam Sensor
Endress Hauser Liquiline M Sensor Readout FOR PARTS
Ametek / Dixson BE051 Bargraph
Watts 3/4" 316 Stainless Swing Check Valve
Sporlan MB19S2 7/8"ODF X 1-1/8"ODM Solenoid Valve
Arrow Pneumatics L376W 3/4" ArrowFog Lubricator
Pepperl + Fuchs KFD2-SR2-EX1,W Isolated?Switch Amplifier
SMC EX500-IB1 Input?Block LOT OF 3-
Eaton Cutler Hammer?FH22 Type A Heater LOT OF 6-
Lithonia Lighting ELM2 Adjustable OpticsEmergency Units -LOT OF 2
Fenner M-Trim 2 Controller Speed Control
Hubbell HBL360P7W Watertight 60 Amp Plug
Machine Products 3/8" 202MPC Visual FlowIndicator
Cutler Hammer C25DND330 30 Amp Definite?Purpose Contactors - LOT OF 2
Enlin 2" 304SS Stainless Steel Flange Blanks 4 Bolt lot of 3?unused
Enlin 1.5" 304SS Stainless Steel Flange?Blanks 4 Bolt lot of?5 unused
Viking Pump Part 2-294-555-100-00
