在全球PLC制造商中,根据美国Automation Research Corp(ARC)调查,世界PLC领导厂家的五霸分别为Siemens(西门子)公司、Allen-Bradley(A-B)公司、Schneider(施耐德)公司、Mitsubishi(三菱)公司、Omrom(欧姆龙)公司,他们的销售额约占全球总销售额的三分之二。从西门子公司的SIMATIC S7-400的性能可对PLC窥见一斑:
SIMATIC S7-400是匣式封装模块,可卡在导轨上安装,由I/O总线和通信总线建立电气连接,模块可在工作或加电时替换或插、拔,可快速安装维护,修改方便,其主要性能为:
·CPU存储器容量64K字节,可扩展到1.6M字节;
·位和字处理速度80ns至200ns;
·最高系统计算能力可以有4个CPU同时计算;
·一个中央框(CR)可扩展直到21个扩展框;
·每个CPU上多点接口(MPI)能力,如可同时连接文字显示或操作员以及编程器件;
·CPU上的SINEC-L2-DP附加有分散I/O的集成性能;
·提供与计算机和其它Siemens产品或系统的连接接口;
·高可靠性,完善的自诊断和清除故障功能。
LAM RESEARCH VAT VALVE 796-094060 R001
Lam Research Weldment 853-385431-700 Rev S2
Lam Research Pressure Transducer- Celerity*NEW*
853-012100-003 Lam Research Loadlock Arm
810-017075-013 Lam Research Gas Panel PCB Assy *NEW*
853-017505-001 Lam Research DC Power Supply
716-330121-014 Lam Research WDO, RF Shaped Ceramic
LAM RESEARCH 853-031399-002 / CMLA-11S02 - MC MANOMETER
LAM Research 715-018611-114 CAP, LWR, 8" BARE DOMED .035
Lam Research Endpoint Detector 853-540066-005-E3-3618 Priced to Move!
810-017082-004 Lam Research Heater Control PCB NEW!!
Lam Research P/N 853-085372-014
LAM RESEARCH ELECTRODE, 6" LOWER.?Part #: 715-011639-016 or 715-11639-016
LAM RESEARCH ETCHER ? PART NUMBER 853-250589-001-1-231S
LAM RESEARCH SYSTEM INTERFACE 384T/ESC 710-080049-001 810-080049-001 PCB BOARD
716-330122-003 Lam Research Top Ceramic Plate
LAM Research 4420 Etcher 853-012123-001-G-230 Harmonic Arm Drive Assembly used
LAM Research 4420 Etcher 853-012123-001-E-230S Harmonic Arm Drive Assembly used
LAM Research 853-012123-001-G-230S Harmonic Arm Drive 715-140184-008 LAM 4420
LAM Research 853-012123-001-G-230S Harmonic Arm Drive 715-130080-008 LAM 4420
Lam Research 716-011057-002 Upper Alumina Filler Ring new
LAM Research 853-012726-101-C-C222 Wafer Transport Assembly LAM 4420 Used
LAM Research 4420 Etcher Outer Gate Assembly 853-012350R002 working
LAM Research 4420 Etcher Wafer Transport Assembly 853-012726-001 Rev.G Working
Lam Research Upper Filler Ring 8" 716-011057-002
Lam Research 715-495014-001 Liner Transition Manifold Adaptor
Lam Research 715-495014-001 Chamber Liner Trans Lam 9600 DFM Kit
Lam Research Harmonic Arm Drive Assembly, 853-012123-001-E-2305, for 4420 Etcher
LAM Research 715-320032-003 Spatula, Entr, Xylan, 9600
LAM Research 715-460089-001 PLT, CHMBR BLK, OFF REV A
LAM RESEARCH 716-020905-001 RING FILLER LOWER WAFER CLAMP NEW OEM
LAM Research CPU PCB 810-017034-300
Lam Research 716-008854-001
Lam Research 839-140228-006 Assy, 6", ESC SLVD, MAJ FLT
Lam Research 715-495014-001 Liner Transition Manifold Adapter
Lam Research 853-007859-223 Alliance Vacuum Gate Valve w/Pneumatic Actuator
Lam Research E167529A080, 22-3/8" x 18-3/4", 6380 Hole CAP
716-140432-004 Lam Research Non-Polished Keyed Upper Ring, Brand NEW!
853-011054-001 Lam Research Heated Manometer Refurbish
716-031453-001 Lam Research Lower Chamber Filler Ring
810-017012-001 Lam Research Rainbow Heartbeat PCB NEW
853-441839-001 Lam Research Comb Pneu/Brkout Box NEW!!
LAM RESEARCH 810-707022-001 GAS BOX EXPANSION CIRCUIT BOARD "Brand New"
853-017643-001 Lam Research 4520 Manometer NEW!!!
NEW Lam Research PN: 856-347385-001 Kit, Retro, Strpr Press Relief Retrofit Kit
LAM Research 853-051252-R001-E-ELM Wafer Lifer Assembly Refurbished
853-012726-001, Assembly, Wafer Transport, Lam Research Etch Equipment
LAM Research 4420 Outer Gate Assembly 12350-2-D-00622135 Used Working
LAM Research 853-012350-002 Etcher Outer Gate Assembly LAM 4420 Used Working
Emerson Stepping Motor; Model: XVM-402-TONS-0000
HURST SLS SP-3570 STEPPING LINEAR ACTUATOR MOTOR 5VDC 8W 1500-STEPS
AxiDyne Micro Stepping Motor Controller MSC Axiom Tol-O-Matic RSA198156
M575 Schrittmotor stepping rotary actuator Laurence Scott SRA 20 Neu
1 Schrittmotor Steppingmotor Motor Stepper
MOONS Stepping Motor 23HS2429-02 60161701?
Vexta PK569AW 5 Phase Stepping Motor
ZEBOTRONICS SE.800.06.85 STEPPING MOTOR AMP BOARD ***NNB***
COMPUMOTOR S83-93-MO STEPPING MOTOR *USED*
Servo 3VDC Stepping Motor KP8BM3-001 New
SANYO DENKI 103H8223-6340 STEPPING MOTOR NEW
NEW NEMA 17 Motorized Lead Screw 200mm Stepping Motor Linear Actuator & Nut/ QTY
Oriental Motor Stepping Motor ASM98AA 1080-01088 Lot of 4 New
VEXTA ORIENTAL SG8030J STEPPING MOTOR CONTROLLER
Superior Electric Slo-Syn Synchronous Stepping Motor M062 Never Used
1 NEW EMERSON 5462 MOTOR NNB
Oriental Motor Vexta PK596BW1 -H100 Stepping Motor with gearhead
Vexta Oriental Motor PK596AW 5-Phase 0.72°/Stepping Motor
Vexta PH266-01B PH26601B 2Ph Stepping Motor
Superior Electric SS221 Synchronous Stepping Motor C215384 A023471
0.7 kg-cm 6 Wire NEMA 14 Stepping Motor 35BYG307
Lot of 2 Vexta C7081-9012K 2-Phase 1.8°/Step Brushless DC Stepping Stepper Motor
17HS8401 42 stepper motor stepping motor Hybrid 48mm 2 4 line
Vexta Stepping Motor PH264M-31 2-Phase 0.9DEG/Step (appears unused)
Baoma 45BF003 Mini Stepping Motor 2.5A 27V 0.196Nm ! WOW !
Superior Electric Synchronous Stepping Motor M092-FD08?
2/4 phase stepping stepper motor driver 70V/6A
Emerson DXM-318/861102-5O Servo Motor 3000Rpm ! WOW !
Sanyo Denki, 103H7121-0740, 3A, 1.8 Deg Stepping Motor
Emerson DXM-318/861102-5R Servo Motor 3000Rpm ! WOW !
Oriental Motor PK564-NA-A33 Vexta 5 Phase 0.72"/Step Stepping Motor, OM,Japan
1 PC NEMA 17 CNC Step Stepping Stepper Motor, 40mm, 1.7A, 56.6oz-in, Bipolar
Mycom PS466-01A PS46601A 4-Phase Stepping Motor 6.0V 1.2A
Emerson K55HXEDS-3852 Carrier HC680026 1/3hp 825rpm 230VAC Electric Motor
5 PCS NEMA 17 CNC Step Stepping Stepper Motor, 40mm, 1.7A, 56.6oz-in, Bipolar
Applied Motion Products Stepping Motor 4017-915
SUPERIOR ELECTRIC SLOW SYN M092-FC08E STEPPING MOTOR
SIGMA PACIFIC SCIENTIFIC 802D4280-B03K STEPPING MOTOR 802D4280B03K
Dornier Step Stepping Motor 389090 ECS NEW
Mini SMCC V2 Stepping Motor Board
Fuji FVR0.4E9S-2 Inverter 0.4kW
Yaskawa SGMPS-15ACA21 AC Servo Motor 1.5kW 1500W
Sanyo Denki MC256-M030XC Servo Motor
3 Drivers// Yaskawa SGDM-A5ADA AC Servo Drive 50W
Mitsubishi MR-E-20A & HC-KFE23 -AC Servo Drive& Servo Motor 200W (free shipping)
Samsung CPL6210A & Power unit & IN16X & OUT16Y & CPL7407(2ea) & Wire link unit
Samsung CPL6210A & Power unit & IN32X & OUT32Y & CPL7407(2ea) & Wire link unit
Fuji Inverter FRN1.5C1S-2J (free shipping)
Oriental Vexta 150W AC Servo Motor & Gearhead KBLM5120GD-C & 5GD50K (free ship)
IAI Robo Cylinder RCP-C-SA61 & E-CON RCA-E (free shipping)
IAI RCP2-C-RSGD-I-PM-0 ROBO Cylinder Controller
Yaskawa AC Servo Motor 200W SGME-02AFJ26 &CP-20C-10-J602A Harmonic Drive Reducer
Fuji Inverter FRN2.2C1S-2J (free shipping)
Mitsubishi MR-J2S-350B AC Servo Drive 3.5kW
Mitsubishi HA-FF63 AC Servo Motor 600W (free shipping)
Pack Driver Stepping Motor Driver AK-BX501V (free shipping)
3 Drives// YASKAWA SGDS-02A05A AC Servo Drive 200W (free shipping)
Mitsubishi Touch Screen A951GOT-TBD (free shipping)
Nissei GTR H2LM-40R-80-0.75WX Induction Motor 750W ratio 80:1 0.75kW
Yaskawa 30W AC Servo Motor SGM-A3A314 (free shipping)
Omron R88D-SR25 AC Servo Driver (free shipping)
Yaskawa SGDS-04A01A & SGMAS-04ACA21 - AC Servo Drive & Servo Motor 400W
Mitsubishi PLC CPU A3NCPU (free shipping)
Mitsubishi PLC CPU A3UCPU (free shipping)
Panasonic MADDT1207 & MSMD022P1S - AC Servo Drive & Servo Motor 200W (free ship)
Rockwell Samsung CSD3-10BX2 AC Servo Drive 1kW (free shipping)
Yaskawa SGD-04AP & SGM-04A314 - AC Servo Drive & Servo Motor 400W (free ship)
FUJI V812iSD Touch Screen HMI LCD Display (New without Box)
Omron Sysmac CPM2A-60CDT-D PLC (free shipping)
Panasonic MSMZ082B1E AC Servo Motor 750W (free shipping)
Mitsubishi MR-J2-03A5 & HC-AQ0335BD - AC Servo Drive & Servo Motor
Rockwell Samsung CSDJ-04BX2 & CSMT-04BB1ANT3 - AC Servo Drive & Motor 400W
Fuji RYB401S3-VBC & GYS401DC1-CA-B - Servo Drive & Servo Motor 400W
Yaskawa SGMAV-10ADA21 AC Servo Motor 1kW 1000W (free shipping)
SHIMPO-Nidec 1:9 ABLE REDUCER GEAR REDUCER VRSF-S9B-50
Rockwell Samsung CSD3-02BX1P AC Servo Driver 200W
Samsung CSM-A5BB1ABT3 DC Brushless Motor 50W
Samsung RC1-02BB1 & CSM-02BB1ANT3 -Servo Drive & DC Brushless Motor 200W
SMC ZL112P-K15LZ Multistage Ejector (free shipping)
Yaskawa SGDM-08ADA & SGMPH-08AAA2C - AC Servo Drive 800W & Servo Motor 750W
Weber Ultrasonics Generator HS1500TD40
Mitsubishi FCUA-MP200 Machine Controller (free shipping)
Yaskawa SGDV-3R8A11A Servo Drive 500W (free shipping)
Mitsubishi 400W Inverter FR-A024-0.4KP (free shipping)
Mitsubishi PLC M61P & A2UCPU-S1 & AD71(3ea) & M68ADN(4ea) & MX41 (free shipping)
YASKAWA SGDH-15AEY199 AC Servo Drive Servopack (free shipping)
Fuji GYS401DC1-SA Servo Motor 400W
Fanuc A16B-2201-0472 I/O Processor PCB
NSK SSB014FN508 DD Driver Motor (free shipping)
NSK SSB014FN515 DD Driver Motor (free shipping)
Lam Research 4420 L.L. Gauge Vacuum Weldmount 839-011237-001-A Lot of 2 Used
LAM RESEARCH 666-390164-001 CA, CHAMBER, TC ENCAP -8"
Lam Research 810-17004 Solenoid Interlock Board 17004-1-4-285-989
LAM Research 017-018-0390 Etcher 490 590 PCB 055258
LAM RESEARCH 710-17001-1 BACK PLANE
853-017936-002 Lam Research RF Match Cable-NEW-
LAM RESEARCH 853-491159-001 CABLE RF 4420 A6
MKS Instruments 839-13521-1 Angle Valve LAM Research 100997144 no valve
LAM RESEARCH PN97780-005 PCB ADAPTOR BOARD 2000 LAM 44xx/45xx ETCHER
LAM RESEARCH 853-017818-100 CABLE EMO PUMP CART 100 FEET
Lam Research 766-000215-001 Valve Clippard
LAM RESEARCH 734-061280-395 O-RING CHAMBER LID QTY-2
LOT of 4: Lam Research, O-Ring, Fluoritz WR, 9.737IDX.103W, 734-048464-178, NEW
Lam Research CAP GND RING AXIS, 715-050751-001, W0149
853-240716-001 Lam Research Temperature Sensor NEW!!
Watlow Columbia / Lam Research 680-095163-001 Heater Blanket, ISO 200-F
Lam Research (LAM) 13-8800-193 Block, Ref. Set Point, Front
853-017633-004 Lam Research Optical Sensor Assy NEW!!
LAM RESEARCH FAST POINT PEN LIGHT TIP SWITCH 707-441-00-01
LAM Research 839-032106-002 WELDMENT, 90 DEG ELBOW
LAM RESEARCH 31-0010-001 C-5-X ROLLER CYLINDER # 1, C-5-X
LAM RESEARCH 715-15143-1 GUIDE CONDUCTOR
Lam Research (LAM) 853-034153-002 Cable Assembly, RF From Upper Housing to TCP
LAM RESEARCH 551096017 Hand Pump Assembly for H2O Container
LAM Research 515-9849-1 2 TOOL INSTALATION SEAL
LAM RESEARCH 839-33103-001 ASSY HEATER GATE VALVE 8
LAM RESEARCH 853-801879-004 CABLE, DC PWR ESC ASSY
670-091765-080 Lam Research 250 Volt AC Circuit Breaker
LAM Research (LAM) 715-008914-001 Shaft Wafer Arm Drive
LAM Research 855-034502-002 RF DIGITAL CONTROLER SOFTWARE, MALAYSIA AM27C010-12
Lam Research 750-001126-001 Roller Chain #25 43.00" Steel
LAM RESEARCH 835-007173-001 GASFEED LINE 2
715-011628-001 Lam Research RF Divider Flow 715-011628-001
New Lam Research 718-014121-001 MOD, GA, FELR .005 THK
Lam Research CA, High Voltage Power Cord, 684-022063-700
LAM RESEARCH CORP BM17756L01 PB17756 REV C PCB, SERVO AMP LOW POWER
LAM RESEARCH 206429-1 CABLE EMO
LAM RESEARCH 660-900240-002 PC POWER SUPPLY ENVISION, AC INPUT 115V/5A, 50/60Hz
LAM RESEARCH 713 31777 001 E1 Cover Screw
LAM Research (LAM) 713-331216-003 Nut, Retaining
Lam Research (LAM) 714-021308-001 Shield RF/UV PS Module DSQ 9600
LAM Research 13-8800-297 BUSHING,OUTSIDE 1 SHAFT
LAM RESEARCH 853-023610-001 ASSY CA THERMOCOUPLE J- USD
LAM RESEARCH 853-021623-001 CABLE AC2 INPUT INTERFACE, ASSY, CA, AC2 PRESS.INPU
LAM RESEARCH 853-11076-001 STRAP CHANGED RF
853-001845-001 Lam Research brake shoe assembly
853-017654-002 Lam Research FAN Lower Match Box
Lam Research 748-006315-001 Spur Gear Anti-Back
LAM RESEARCH 955-091372-001 TUBE CORRUGATED TFLN BLACK (QTY 3)
720-098325-004 Lam Research
