⑹ 滤波电容因日久老化,容量减少或内部电感变大,对母线的过压吸收能力下降,造成母线上过电压太高而损坏IGBT。正常运行时母线上的过电压是逆变开关器件脉冲关断时,母线回路的电感储能转变而来的。
⑺ IGBT或IPM功率器件的前级光电隔离器件因击穿导致功率器件也击穿,或因在印制板隔离器件部位有尘埃、潮湿造成打火击穿,导致IGBT、IPM损坏。
⑻ 不适当的操作,或产品设计软件中有缺陷,在干扰和开机、关机等不稳定情况下引起上下两功率开关器件瞬间同时导通。
⑼ 雷击、房屋漏水入侵,异物进入、检查人员误碰等意外。
⑽ 经维修更换了滤波电容器,因该电容质量不好,或接到电容的线比原来长了,使电感量增加,造成母线过电压幅度明显升高。
⑾ 前级整流桥损坏,由于主电源前级进入了交流电,造成IGBT、IPM损坏。
⑿ 修理更换功率模块,因没有静电防护措施,在焊接操作时损坏了IGBT。或因修理中散热、紧固、绝缘等处理不好,导致短时使用而损坏。
Square D 9001K96 Padlock Attachment -LOT OF 4
Moore Industries LH21/2 Housing / Transmitter
Meletron Dialmatic 2221-9 Pressure Switch
Apollo 1-1/4 Bronze/Brass Ball Valves -LOT OF 2
co F510-S6-R66 3/4 Stainless Ball Valve UNUSED
Bell & Gossett SA-11 Flo Control Valve
Conbraco 1.5 600 WOG Brass Ball Valve
Westinghouse Security Electronics Alto 818SC Access Door Controller
Johnson Controls A19ABC-37C TemperatureControl
Automation Direct Rhino PSC-24-060 PowerSupply
Siemens / Furnas 50MA3HJE 3 Push ButtonControl Station
Parker 3/8 CC437B Hand OP Valve
Square D 9070EO2D2 Industrial Control Transformer
Yokogawa Panel MeterMRE0941 3130132 A-CAmp Meter LOT OF 4-
Rosemount 1151 Pressure Transmitter
Ashcroft / Dresser 7KA-28876-016 3 Bimetal Thermometer
Kunkle 3/4 537-D01-HM Brass Safety Valve
Square D 9012 Pressure Switch GNG-6
Spirax Sarco 3/4 Brass Y Strainer UNUSED
Arrow Pneumatics 3/4 L376W Arrowfog Lubricator
Hayward TB2100ST 1CPVC TB VLV Ball Valve
Appleton 3/4 LB Form 35 Conduit -LOT OF 3
Fuji BU-ECA3080 80amp Circuit Breaker
Crouse Hinds ArktitePlug for HazardousLocations CPH7733
Cutler-Hammer C25DND330A Definite Purpose Contactor 30 Amp
Jomar 2 Brass GateValve
Ingersoll-Rand AROFluid Power A239PS
Linde AWS A5.10 MigWelding Wire 4 SPOOLS!
IFM OGP500 Retro-Reflective Sensor
ICM Controls ICM450Three Phase VoltageMonitor
Eurotherm AmpStack AS-1
Marsh / Bellofram W0456 Gauge 4.5 Heat
Flex-Kleen PressureGauge E21401
Armstrong Steam Trap1/2
Numatics 153SA415E Solenoid Control Valve
Cutler Hammer E49S11Limit Switch LOT OF2 - IN BOXES!
Coilhose Pneumatics8803GL 3/8 Regulator w/ Gauge
Bussmann Fusetron FRS-R-6amp Fuses -LOT OF 10
Milwaukee 1 Brass Gate Valve
Dwyer Magnehelic W21X Pressure Gauge
Cutler Hammer Powereed D40RB Type R Powered Relay
Allen Bradley Precision Limit Switch PASJ218
Acromag Series 1800Cage 1892-CG-DC
Honeywell BZF2-2RN25Micro Switch
Jenco 6308CT Control
Sencorp 2000-B Process Control
Spirax Sarco 66180 3/4 NPT Pipeline Connector
Eurotherm EMO/OPR//Keyboard
Bay Networks Model 810M Ethernet Hub LOT OF 3
SOLA Regulated PowerSupply SLT-12-31010-12
Fast OEM 1585981 Valve L HSI Snap W R
ABB S203-C16 CircuitBreakers LOT OF 2
Bentron S-5/6 PowerSupply
RiS PSC-300I 24VDC Signal Converter
Reliance Cardpak 0-49017-1 Summing Circuit
Square D 30amp General Duty Safety Switch
Allen Bradley 1492-GH100 Circuit Breaker
Allen Bradley 700-HA32Z24-4 Relay LOT OF 4
Square D 8501C0-7 Heavy Duty Power Relay-LOT OF 2
Square D 8501C06V20Power Relay LOT OF2-
Allen Bradley Bulletin 802 PASJ218 Precision Limit Switch
Tempco NB0300 3 Band Heater
GE 5412 5KSP51ECL553115 Volt Shaded Pole Motor
Westinghouse AN11P Thermal Overload Relay
Johnson Controls P74FA-5C Differential Pressure Control
Armstrong 21 LD 1/2Steam Trap
Advance REL-2S110 Rapid-Start ElectronicBallast
DEB SBS C3 White Soap Dispenser Lot of 3
Turck RK4.4T-4-RS4.4T Eurofast Cordset
Square D 9065T0-1 Thermal Overload Relay
ACME T-1-81048 120 Volt / 12 Volt General Purpose Transformer
GE Security KTC-815CSurveillance CameraREFURBISHED
FNW 2 Brass Shut Off Ball Valve
Landis & Gyr PowersDuct Averaging Sensor 533-380
Greener Corp. SC 1071 3.5 Crimper KnifeSet
Omron ZE-N-2S LimitSwitch
Asco 8353C33 2-Way Direct-Acting Solenoid Valve
Johnson - Penn BasoP67AA-1 1/8 Male NPT Pressure Control
Allen Bradley Flex I/O 1794-ASB 24 VDC Power Supply Rio Adapter
Peter Paul E26X00600CH Solenoid Valve
Hastings Air FilterAF-133K Lotof 2
Watts 30L 1/2 Pressure Relief Valve w/Test Lever
Acromag 161T-J Transmitter
Weco Techniek B.V. 902073 Transformer
Thrush 70S 1 BrassRegulating Valve
Starflex SF-100(X) 10 Band
ASCO HV170-562-1 Solenoid Valve 1/4
Johnson Controls Penn-Baso TemperatureControl A70CA-15
Siemens 533-380 DuctAveraging Sensor
Elcon Instruments MB-320/IS Multiple DCIsolator
Red Lion LIBC1E Control - REPAIRED
Hubbell 7977 50A 3wire Insulgrip Angle Plug
GE 204B6165AAG001 Bypass Switch Card
Allen Bradley 85A01Coil -LOT OF 6
UE J402-453 9838 Pressure Control
Square D 9001KM1 Illuminated Mushroom Button Operators -LOT OF 2
Square D 9999S2 FuseClip Kit Class H -LOT OF 2
ATC 3358 120 Volt Second Timer UNUSED
Durametallic 1.653Single Outside RO-TTDura Seal LOT OF 2
ITT Pneumotive Vacuum Pump BLVGH
ASCO 8262A262 Solenoid Valve 1/4
ASCO 8314C30 Solenoid Valve 1/4
ASCO 8320A85 Solenoid Valve 1/4
ASCO 830081RF Solenoid Valve 1/4
ASCO 830081 RG Solenoid Valve 1/4
Square D Circuit Breaker FAL34015 15 AMP
Nexen 807300 MW Bushing 1.5 Bore
ASCO 8320A189 Solenoid Valve 1/4
Hubbell Twist-Lock Plug 2711-CA
Schrader Bellows FW2B 2 Stroke Econo-Ram II Pneumatic AirCylinder
Danfoss TKEX8-7 1/2MOP 100 Thermo. Expansion Valve
Allen Bradley 1771-1XC Thermocouple Input Module
Rosemount Uniloc Division 1700004 General Purpose Electrode
Allen Bradley 700-HA32Z24 Relay LOT OF 2
Crouse Hinds EDS2713/4 Single Gang Device Body
Square D 8501C015V20General Purpose Power Relay
Armstrong 1/4 Temperature Regulator
Power-One HC24-2.4-APower Supply UNUSED
Kuri Tec K010 3/4 X1 100ft Klearon Clear PVC Food GradeTubing Plastic Hose
Square D QOB110 10 Amp 120/240V Bolt OnCircuit Breakers LOTOF 5-
MagneTek 1/50HP Cooling Fans LOT OF 6
Weco Techniek B.V. 902075 Transformer
ASCO 821101 SolenoidValve 3/8
Yarway Series 710/720 Uody Steam Traps LOT OF 5
Comptrol BB2OUIOK Tensioncell
Norgren L08-200-OPCALubricator
ITC Industrial TimerTDAF 6S
Ashcroft D424B Pressure Control
ASCO 8320A98 Solenoid Valve
Universal Lighting Technologies 443-L-SLH-TC-P 2 Lamps RapidStart Lot of 2
ITT Conoflow GH20XTKEXXF Mini Regulator
Alcotec ER4043 .030Dia Aluminum Mig Welding Wire LOT OF 2-
Square D 9999SX8 Size 00-7 Electrical Interlock
Watts Injection Lubricator L50-06 M7 3/4
ATC Elapsed Time Indicator 5700A
Notifier Company Plug in Relay A22R-12
ABB S203-C10 CircuitBreaker
Watts Regulator 909AGF
Herion 9130 1/4 Solenoid Valve
NTron Passive SwitchDevice
Banner Maxi-Beam Sensor RSBF 25576
Mettler Toledo 004063000 Puncture Knifefor Electrode
Cutler-Hammer Type RPowereed RelayD40RB
IFM IGT200 Efector Inductive Proximity Switch
Gleason-Avery PBU-33amp Push Button Station
Square D FY14020B 20Amp Circuit Breaker
Cajon Stainless Steel Braided Hose SS-4BHT-36
IFM IG5937 InductiveProximity Switch
Siemens 3RU1116 Overload Relay
I-T-E Siemens ED43B020 20amp Circuit Breaker
Dayton 4HA33A Drum Pump
Allen Bradley 1492-CB3 10 amp Circuit Breaker LOT OF 2
ICM Time Delay Plugin Relay MDR115A2X30
Wika Liquid Filled Pressure Gauge 213.53 2.5
Warner/Bernstein 601-6169-026 Safety Interlock Switch
Allen Bradley 1771-E1C Analog Input Expander (12 BIT)
Exide Light Guard S256 Lamphead
Allen Bradley 1771-1FC Analog Input Module (12 BIT) SeriesB
Allen Bradley 700-N800A1 Control Relay Lot of 3
Fuji BU-ECA2005 5ampCircuit Breaker
Square D 8501KP12V20General Purpose Relay LOT OF 2-
Square D Mag-Gard FAP3600311M 3 Amp Circuit Breaker UNUSED
ASCO 8320A1 Solenoid Valve 1/8
Siemens Simatic Busconnector Profibus DP6ES7-972-0BA50-0XA0 Sealed
Siemens Simatic Connector 6ES7-392-1AJ00-0AA0 - Sealed
Analog Devices QMX04
Honeywell Q7100C 1073 Microelectronic Heat Pump Subbase
Parker MSP3-2-30 PPFilter Element
Teledyne SSP 613-1 High Current Solid State DC Relay
Winters 6 X 1/4 NPT 0-30 PSI 300 Series Pressure Gauge
ASCO 8262C43 Solenoid Valve 1/8
Action Pak AP1021 Dual-Trip Limit AlarmModule
Hewlett Packard 04329-7028 Conventor Assembly
Armstrong C964C F&TSteamtrap 1/2 125- A1Z Rebuilt
Mean Well DR-4505 Power Supply
Pass & Seymour Llegrand 7411-SS TurnlokPlug 20A, 3PH, Y 120/280V
Spirax Sarco 66188 1/2 Universal SwivelConnector -LOT OF 2
Tru-Flo 50-4411310 Solenoid Valve
Agastat SSAXXO Timing Relay
Sharp FO-48ND Toner/Developer Kit
Square D GSG-2 Pressure Switch
Analog Devices QMX03
Amtrol American 1 Air Purger 443-1
Watts L50-06 M7 3/4 Lubricator
Brad Harrison 103001A01F120 3P Female 90 degree 12' 16/3 AWG PVC Cord
Littelfuse LLSRK 10600volt Current Limiting Fuses -LOTOF 4
Raychem PolyMatrix Junction Box PMJ-1
North BS03R Ball Valve Lockout
Square D B2.10 Overload Relay Thermal Units LOT OF 6-
