变频器逆变模块损坏多半是由于驱动电路损坏致使1个桥臂上的2个开关器件同一时间导通所造成的。变频器逆变功率模块损坏是不管在矢量变频器还是节能变频器等其他变频设备上常见到的故障,解决这种问题只有查到损坏的根本原因,并首先消除再次损坏的可能,才能更换逆变模块,否则换上去的新模块会再损坏。
一、判断
逆变功率模块主要有IGBT、IPM等,检查外观是否已炸开,端子与相连印制板是否有烧蚀痕迹。用万用表查C-E、G-C、G-E是否已通,或用万用表测P对U、V、W和N对U、V、W电阻是否有不一致,以及各驱动功率器件控制极对U、V、W、P、N的电阻是否有不一致,以此判断是哪一功率器件损坏。
Amtrol 444 1-1/4" Air Purger
Hayward 1/2" PVC True union Ball Valve?
Westinghouse Series?C Industrial CircuitBreaker EHD 14K
Square D FY14030C 30?Amp Circuit Breaker
Amperite Tube 3V4?
ASCO 064982-001-D Solenoid Coil
PTI Technologies Filter Element J1148?
Square D Relay Timer?Class 9050
Super-Trex Quick-Connect 84969 T.P.C. Wire & Cable
Appleton T150-M 1.5" Form 35 Unilet
Fuji BU-ECA2005 5amp?Circuit Breaker
McDaniel Controls 316 S.S. Tube & Socket?0-15psi Gauge
Dayton Relay 3X740M? Lot of 2
Dayton 2MEU1 Motor Start Capacitor
Allen Bradley 100-DTS420 Touch Protection Main Terminal Covers LOT OF 2 -
Spirax Sarco 66190 3/4" Universal SwivelConnector -SEALED
Telemecanique GV2 K011 Push Button
Dwyer Series 1900 Pressure Switch
Brown Boveri BBC GH?R 433 Module Relay LOT OF 6
AMF Potter & Brumfield Sealed Relay KHS17D11
Allen Bradley Overload Relay w/Auto Reset X143918 for BUL.709 Size 0 & 1
Carlon Weatherproof?Toggle Switch Cover?
Brown Boveri BBC GH?R 425 Module Relay
Allen Bradley 1492-CB3 15 amp Circuit Breaker
Super-Trex Quick-Connect 84600 T.P.C. Wire & Cable IN BAG
Honeywell Tradeline?R4214 G 1347 40A 3-Pole Contactor
Tork 2004 Turn-Lock?Photocontrol
Ashcroft Pressure Gauge 20W1005PH 02L60psi
Hubbell PHE-480-L-A?15amp Econohook
Dual Lite BRP-X75 Battery Replacement Pak
RCA Electron Tube 5823
RCA Electron Tube 02A
GE Electronic Tube?6BC4
FISHER ROSEMOUNT NV MEMORY BOARD, 01984-2347-0021, REV T/AU
FISHER ROSEMOUNT COORDINATOR PROCESSOR IV 10P50870004 9803-2656L 98032656L
FISHER ROSEMOUNT COORDINATOR PROCESSOR IV 10P50870004 REV. B/F
FISHER ROSEMOUNT COORDINATOR PROCESSOR IV 10P50870004 REV. A/F
Fisher-Rosemount 01984-1540-0009 OI Processor NICE SHAPE
Fisher-Rosemount 10P57520007 MPC 5 Controller
FISHER ROSEMOUNT 880A USPP 880A
Fisher-Rosemount 10P50870004 Coordinator Processor IV
FISHER ROSEMOUNT DM6004X1-EA2 NSFP DM6004X1EA2
FISHER ROSEMOUNT 620641 USPP 620641
Fisher Rosemount 1984-1137-0001 Power Regulator Card
FISHER ROSEMOUNT ES-72-70574 NSPP ES7270574
FISHER ROSEMOUNT DH6011-X1 USPP DH6011X1
FISHER ROSEMOUNT CL6003 USPP CL6003
FISHER ROSEMOUNT CL6003X1 USPP CL6003X1
FISHER ROSEMOUNT CL6003X1-A3 USPP CL6003X1A3
FISHER ROSEMOUNT CL6011X1-BA1 USPP CL6011X1BA1
FISHER ROSEMOUNT DM6004X1-EA2 USPP DM6004X1EA2
FISHER ROSEMOUNT 400-11 USPP 40011
FISHER ROSEMOUNT CL6003X1-A3 IAC MEMORY MODULE MPU/ROM CL6011 PROVOX B202300
Fisher Rosemount Controller M5 Plus VE3004 KJ2002X1-CA1 Rev:J Delta V Emerson
FISHER ROSEMOUNT 01984-4164-0004 USPP 0198441640004
FISHER ROSEMOUNT CL6242 USPP CL6242
FISHER ROSEMOUNT CIRCUIT BOARD DH6005X1-DA1 DH6005X1 DA1 37A8986X012 REV. F
FISHER ROSEMOUNT DH6005X1-DA1 NSPP DH6005X1DA1
FISHER ROSEMOUNT 8711TPE005R1E5 NSFP 8711TPE005R1E5
Fisher-Rosemount KJ3002X1-BC1 8CH/4-20mA Free SHip
FISHER ROSEMOUNT DPR-960 USPP DPR960
FISHER ROSEMOUNT 12P1442X042 NSPP 12P1442X042
FISHER ROSEMOUNT CIRCUIT BOARD 01984-1505-0001 01984 1505 0001 0198415050001
FISHER ROSEMOUNT DH6005X1-DA1 USPP DH6005X1DA1
Micro Motion Fisher Rosemount DS025S114SU Mass Flow Sensor
FISHER ROSEMOUNT 01984-2503-0001 USPP 0198425030001
FISHER ROSEMOUNT 12P1442X022 USPP 12P1442X022
Fisher Rosemount Delta V Wired Up 8 Wide Carrier 2 Wide Carrier Terminal Blocks
FISHER ROSEMOUNT DH6005X1-DA1-35 37A8986X012 ISOLATED I/O POWER BOARD B353766
Fisher Rosemount 12P1509X092
FISHER ROSEMOUNT DM6004X1-FA1 NSFP DM6004X1FA1
FISHER ROSEMOUNT 01984-4068-0006 USPP 0198440680006
FISHER ROSEMOUNT 3095-MA2CA0014AB10NABS5 NSFP 3095MA2CA0014AB1
FISHER ROSEMOUNT 3095-MA2CA0018AB10NABS5 NSFP 3095MA2CA0018AB1
Fisher Rosemount Micro Motion 3300P2A00B1UEZZZ
FISHER ROSEMOUNT 3491-L1P6I1 NSFP 3491L1P6I1
FISHER ROSEMOUNT 9233900-108 USPP 9233900108
FISHER ROSEMOUNT 6853454-094 USPP 6853454094
FISHER ROSEMOUNT EMERSON PROCESS MANAGEMENT 1M03205G01 CPU CONTROL BOARD W/EPROM
FISHER ROSEMOUNT 3051-CG4A02A1AH2M5 USPP 3051CG4A02A1AH21
FISHER ROSEMOUNT 01984-2347-0011 USPP 0198423470011
FISHER ROSEMOUNT CL7011X1-A2 USPP CL7011X1A2
FISHER ROSEMOUNT DM6004X1-FA1 USPP DM6004X1FA1
Fisher Rosemount 1984-1045-0003 Interface Card Assy Peerway by Emerson
FISHER ROSEMOUNT 3095-FH23BAA12AA1100A NSPP 3095FH23BAA12AA1
Fisher-Rosemount Systems - RS3 - OI Processor V - NEU - OVP
FISHER ROSEMOUNT 3095MA2CJBA11AA011BBP2 USPP 3095MA2CJBA11AA0
FISHER ROSEMOUNT 9150023-563 USPP 9150023563
Fisher Rosemount Delta-V KJ3004X1-BA1 KJ3004X1BA1 Fieldus Card SAR
FISHER ROSEMOUNT 620643 USPP 620643
FISHER ROSEMOUNT CL7001X1-A10 USPP CL7001X1A10
FISHER ROSEMOUNT 480-15-60 USPP 4801560
FISHER ROSEMOUNT 1M03205G01 NSPP 1M03205G01
FISHER ROSEMOUNT 3095-FH23ABB13AB100AA NSPP 3095FH23ABB13AB1
FISHER ROSEMOUNT 3095MA3CA0013AA00NABS5 NSPP 3095MA3CA0013AA0
FISHER ROSEMOUNT 470 NSPP 470
Fisher Rosemount Analog Input 8CH 4-20mA Module Industrial KJ3002X-BA1
Fisher Rosemount Analog Input 8CH 24VDC Module Industrial KJ3001X1-BG1
(N3-3) 1 FISHER ROSEMOUNT 41B5215X13R DISCRETE I/O CARD
FISHER ROSEMOUNT 1175-8006 USPP 11758006
FISHER ROSEMOUNT CL7001-A10 USPP CL7001A10
FISHER ROSEMOUNT Generator I/O Graphics Video card 01984-2503-0001
FISHER ROSEMOUNT DLC3010 NSFP DLC3010
FISHER ROSEMOUNT 3095-FH24ABA11AA1100A NSPP 3095FH24ABA11AA1
FISHER ROSEMOUNT 2081-A-FF USPP 2081AFF
FISHER ROSEMOUNT DH6011X1-DA1 NSPP DH6011X1DA1
FISHER ROSEMOUNT 8711TPE15FU1N0 USPP 8711TPE15FU1N0
FISHER ROSEMOUNT 12P0680X042 NSFP 12P0680X042
6103X1-AA1 , FISHER-ROSEMOUNT SYS, RACK, 6103X1AA1
FISHER ROSEMOUNT 8712CR12 USPP 8712CR12
FISHER ROSEMOUNT 37A0401X032 USPP 37A0401X032
FISHER ROSEMOUNT CL6011X1-B1 CL6011X1B1 IAC MPU BOARD 30B4113X01R Rev. E
FISHER ROSEMOUNT CL6011X1-B1 IAC MPU BOARD 30B4113X012 30B4113X01R REV G
FISHER ROSEMOUNT 46A3008-L54 NSPP 46A3008L54
(0162) Fisher Rosemount Hart Communicator Model 275
Fisher-Rosemount Systems - MPU/MEM PWB ASSY - OVP
FISHER ROSEMOUNT 5081-C-HT NSFP 5081CHT
FISHER ROSEMOUNT CL7652X1-A2 USPP CL7652X1A2
FISHER ROSEMOUNT 01984-1011-0003 USPP 0198410110003
FISHER ROSEMOUNT CL7675X1-BA5 USPP CL7675X1BA5
FISHER ROSEMOUNT DH6011X1-DA1 USPP DH6011X1DA1
FISHER ROSEMOUNT CP7202X1 USPP CP7202X1
FISHER ROSEMOUNT MVCU-II USPP MVCUII
FISHER ROSEMOUNT 1151AP5E23 NSFP 1151AP5E23
Fisher Rosemount Controller M5 Plus VE3004 KJ2002X1-CA1 Delta V Emerson
FISHER ROSEMOUNT INTERFACE BOARD RS422 PWA 01984-1011-0003 miniconsole interface
FISHER ROSEMOUNT INT DEV INTERFACE CL6922X1-KA4
FISHER ROSEMOUNT PROCESS CONTROLLER PLC DPR 950 DPR950 492880201
Fisher-Rosemount 16 Point 4-20 01984-4418-0001 MPAO.FIM
FISHER ROSEMOUNT 46A3008-L5D USPP 46A3008L5D
FISHER ROSEMOUNT 3051-L3AAOAD11AAM5 USPP 3051L3AAOAD11AAM
FISHER ROSEMOUNT DH7001X1-A4 DATA CONTROL INTERFACE PCB CIRCUIT BOARD E B286479
FISHER ROSEMOUNT APEXBC1D1SC4N04A101C1E5R0001 USPP APEXBC1D1SC4N04A
FISHER ROSEMOUNT 8712HR12N0B6 USPP 8712HR12N0B6
Fisher-Rosemount, 09210-0431-1000R, 09210-0006-0001, MVCU CPU OCCB/BRAM Emerson
FISHER ROSEMOUNT 8712DR12N0M4 USPP 8712DR12N0M4
FISHER ROSEMOUNT CL6011X1-B1 NSPP CL6011X1B1
FISHER ROSEMOUNT 9235401-105 USPP 9235401105
FISHER ROSEMOUNT 8705-TSA015S1W0N0L1H2 NSPP 8705TSA015S1W0N0
FISHER ROSEMOUNT 1U05600G01 USPP 1U05600G01
FISHER ROSEMOUNT 1151-DP3S-22B1 NSPP 1151DP3S22B1
FISHER ROSEMOUNT 3051S2CD2A2E12A2A NSFP 3051S2CD2A2E12A2
FISHER ROSEMOUNT C1-2311-51579 NSFP C1231151579
FISHER ROSEMOUNT 3051-L2AC0FD22AAM5 USPP 3051L2AC0FD22AAM
FISHER ROSEMOUNT DH7001 USPP DH7001
FISHER ROSEMOUNT 01984-1137-0001 USPP 0198411370001
FISHER ROSEMOUNT 667-34-3/4 NSPP 6673434
FISHER ROSEMOUNT 4002 USPP 4002
FISHER ROSEMOUNT 8711-TTE005R1 USPP 8711TTE005R1
FISHER ROSEMOUNT 667-40-ET USPP 66740ET
41B4148 , FISHER-ROSEMOUNT SYS, MPU MULTILAYER, 41B4148
FISHER ROSEMOUNT DH7001X1-A4 NSPP DH7001X1A4
FISHER ROSEMOUNT DH6011X1-GA2 NSPP DH6011X1GA2
FISHER ROSEMOUNT 8701TSA010S1B1N6/8712TA12N6 USPP 8701TSA010S1B1N6
FISHER ROSEMOUNT 1725-4000 USPP 17254000
FISHER ROSEMOUNT 36A7633X022 USPP 36A7633X022
FISHER ROSEMOUNT CL6821 NSPP CL6821
FISHER ROSEMOUNT 657-ES USPP 657ES
FISHER ROSEMOUNT 3051S-2CG4A2E12A1AB4M5 NSFP 3051S2CG4A2E12A2
FISHER ROSEMOUNT 1151-DP3S-22B1 USPP 1151DP3S22B1
FISHER ROSEMOUNT 3051-CD2A02A1AS5M5E5 USPP 3051CD2A02A1AS5M
FISHER ROSEMOUNT ACM-617401 USPP ACM617401
FISHER ROSEMOUNT DCM-617601 USPP DCM617601
FISHER ROSEMOUNT SCL-1054-T-2120-M2 USPP SCL1054T2120M2
Fisher Rosemount 10P52790001 Peerway Tapbox B Assembly
FISHER ROSEMOUNT 1151DP8E22B1M1 NSPP 1151DP8E22B1M1
FISHER ROSEMOUNT 3051-CD1A02A1AC1B3H2 NSFP 3051CD1A02A1AC1B
FISHER ROSEMOUNT 1151GP6S22S1B1C6 USPP 1151GP6S22S1B1C6
FISHER ROSEMOUNT 37A0346X012 USPP 37A0346X012
FISHER ROSEMOUNT 1151AP5S22B1M1 NSFP 1151AP5S22B1M1
FISHER ROSEMOUNT 8732CT12N5M4 USPP 8732CT12N5M4
FISHER ROSEMOUNT 3051-CD1A22A1AK5 USPP 3051CD1A22A1AK5
Fisher Rosemount 09210-0410-1003 Power Supply 120v
FISHER ROSEMOUNT 602-156 USPP 602156
FISHER ROSEMOUNT 3051-CD1A22A1AB4 USPP 3051CD1A22A1AB4
FISHER ROSEMOUNT 275148-3 USPP 2751483
FISHER ROSEMOUNT DH6005X1-EA4 USPP DH6005X1EA4
FISHER ROSEMOUNT DH6003X1 USPP DH6003X1
FISHER ROSEMOUNT DH6003X1-GA1 USPP DH6003X1GA1
FISHER ROSEMOUNT DC6554X1-DA1 USPP DC6554X1DA1
FISHER ROSEMOUNT 1151DP5E33M1 NSPP 1151DP5E33M1
FISHER ROSEMOUNT 3051CD2A22A1AM5Q4DW NSPP 3051CD2A22A1AM5Q
FISHER ROSEMOUNT 1151-GP6E22B2 NSFP 1151GP6E22B2
