过电压报警一般是出现在停机的时候,其主要原因是减速时间太短或制动电阻及制动单元有问题。
实例
一台台安N2系列3.7kW变频器在停机时跳“OU”。
分析与维修:在修这台机器之前,首先要搞清楚“OU”报警的原因何在,这是因为变频器在减速时,电动机转子绕组切割旋转磁场的速度加快,转子的电动势和电流增大,使电机处于发电状态,回馈的能量通过逆变环节中与大功率开关管并联的二极管流向直流环节,使直流母线电压升高所致,所以我们应该着重检查制动回路,测量放电电阻没有问题,在测量制动管(ET191)时发现已击穿,更换后上电运行,且快速停车都没有问题。
3 欠压(Uu)
欠压也是我们在使用中经常碰到的问题。主要是因为主回路电压太低(220V系列低于200V,380V系列低于400V),主要原因:整流桥某一路损坏或可控硅三路中有工作不正常的都有可能导致欠压故障的出现,其次主回路接触器损坏,导致直流母线电压损耗在充电电阻上面有可能导致欠压.还有就是电压检测电路发生故障而出现欠压问题。
Hagiwara C-7704-1670-CD1?02280 PC Board C-7704-1670-CD1?02280B
EI Hagiwara C-7704-1670-CDI?O2280 I/O Card 160030
Fireye, E1R1, Infrared Auto-Check Flame Amplifier Module
Honeywell, M4185B 1009, Modutrol IV Motor Actuator
Faraday XHFA-33N4 Adalet PM3823 explosionproof Firealarm fire glass break
Sick Stegmann HD32 2 5E.0010 Rotary Encoder 6-111514-0010
Bodine Electric 0818 DC Motor Control Drive VFD DC Adjustable Speed 818 GY
Bosch A24/0,5-e C1 400/500 1070077583-102 output module
Mitsubishi A61P-UL Melsec PLC Programmable Controller Power Supply
Murr, 56662, Elektronik Extension Module Cube67 Valve and Cable DIO16 E
Fireye EPD 380 EPD380 Programmer Module Burner monitor
Balluff Micropulse BTL5-A11-M0508 linear transducer
AC Tech SF405 .5hp 1/2hp .5 hp Variable Speed Motor Drive VFD SCF
3M GVP-111 Battery Pack Belt-Mounted PAPR System
AEG Modicon DAP 216/AS-BDAP-216 Output Module
Honeywell M4185B 1058 Modutrol IV Motor
Honeywell M9164A 1005 Modutrol IV Motor 120V
Square D 1S1F Transformer Single Phase 120/240/480 1kva
Cutler Hammer, E58-30TD250-HDP?, Proximity Sensor Switch 250m Detector Thru Beam
Cutler Hammer HMCP070M2C Circuit Breaker motor protect
Siemens OPM2 6SE3290-0XX87-8?BF0 Keypad Clear Text Display
Mitsubishi A1SH42 input/output Unit Card Module PLC
Allen Bradley 1201-HAS1 Drive VFD Programming Terminal Keypad Ser.A
IFM Efector LK8124 Lever Sensor
MSC BK Mikro 4 Control Unit 6304200 Rev.1.07
Cutler-Hammer, 1161A-100, 110680-104,Sour?ce Head Photoelectric Sensor Eaton
Fireye, EP380, Programmer Module Recycle
Phoenix Contact, IB ST 24 DI32/2, 2754927, Interbus Input Module
Sick, WL12L-2B520, Photoelectric Reflex Sensor
GE Fanuc IC693CMM302D Communications Module Comm Enhanced Genius
Designtech 09-0113-0002 REV A Graphic Operator Interface 00278118
Denso 410010-2050 RP277 SSE Servo Axis PC Board 4000102050 Motoman Yaskawa
Yokogawa UT550 Temperature Controller 100-240VAC
Vickers 297238 DG4S4-012A-50 Solenoid Pilot Valve
Siemens ED63B080L Circuit Breaker 600VAC 80A 3P
Fisher Rosemount 400-13-60 Endurance Conductivity Sensor Rev J 250psig WER
CCS PD2-3012 Digital Power Supply LED Light Lamp Machine Vision Camera
Danfoss Starting Torque Limiter TCI 25 037N0048
Allen Bradley 1494F-N30 Flanged Mounted Disconnect Switch Handle Enclosure
Mac, SM32DNA-BCBAAM2?A92, Devicenet Controller Interface 24VDC
Rexroth, 4WE10D40/CG24N9?DK23L, R978908692, Hydraulic Valve Bosch
General Electric LAR00AJ Magnetic Reverser 5HP CL00A310T Starter Reversing
Converter Concepts VT50-349-10/AA Power Supply 10-40 VDC 6A
Sanyo Denki P30B06020PXS00M AC Servo Motor
Watlow DIN-A-MITE DC81-24K2-0000 Solid State Power Control Supple
Ross 8077A3906 Pneumatic Pilot Valve
Honeywell Sensotec LFH-71/4771-01 060-4771-01 Load Cell 10000lbs
Asco Red Hat HV2748611 Solenoid Valve 24/DC 3/4"NPT 318973
Keyence N-400K 400 Multi-Drop Controller
Extron M8102-11-0700 DC Motor Control Series 100
Monarch Hydraulic 43200001699 Hydraulic Pump 0634-74DF 43 2000
Sick Stegmann DFS60B-T5EK0000?9 Rotary Encoder
Parker D1VW1CVY 70 Directional Hydraulic Valve
Allen Bradley, 836T-T300J, Pressure Control Switch Sensor
Honeywell M9164D 1009 Modutrol IV Motor Valve Actuator 24V
AEG Multipuls IC ISIC 6D.1 Controller 763-612-750.00
Allen Bradley 836T-T253JX19 Pressure Switch Ser.A
Sensotec Honeywell Load Cell Sensor 2k 2000 lbs 31/C643-01 Transducer 2000lbs
Valcom C34GI-S Digital Color Panel Meter
Motoman HE9300834 Cable Teach Pendant HE9300834 RTC8TY010 wire Connector
Dickinson Legg 0031611 Gearbox for S400 Cutter cpl70-64 Centa Transmission
Square D 8502SB02V02S AC Magnetic Starter Contactor
Measurement Computing CIO-DAS08 8 12 bit analog input
9210-070 800938 PCI Card KP-9210-070-700 KP9210070700 P62179 800938 board
Sony SR33-017AM Scale Unit Linear magnescale
ABB Circuit Breaker 3Pole 600VAC 400a 400 amp Type JS
Sansho PFC-71 Parts Feeder Controller Vibratory Bowl Vibrator Control Motor
PepperL+Fuchs, PB1-008-6, Capacitive Palm Button Switch Touch Safety
Sick, C20S-030102A11, Safety Light Curtain 1016448
Sola, SDN 20-24-200, Power Supply 24V 20A
Hycon 0160D010V Hydraulic Filter S10005994 DS 024050-3B63 RxH10AN44-S5-10?SSV NIB
Eaton Kenway, D0057366-001A, 57366, PC Board Master Control 0057371
Phoenix Contact, QUINT-PS/1AC/12?DC/15, 2866718, Power Supply
Teledyne Hastings, 760S , Vacuum Sensor Gauge HPM-760S 760
Honeywell DC230L UDC2300 temperature digital controller
Allen Bradley, 700-N400A1, Industrial Comtrol AC Relay Contactor 120v
Eupec BISCR 15001850 4L8 Thyristor Benshaw SCR BISCR 15001850 4L8 Rectifier 880a
Tokinarc TK-308RR-N-1.3 Torch Assy Air Cooled w/Cable 1.3m welding weld Mig
Sargent Mortise Lock 8271 Door Knob Handle R LNJ 26D electromechanic?al 26D RH
Namco, EE230-11320, Cylindicator Cylinder Position Sensor
Fireye, ED510, Burner Control Display Module
Danaher Dynapar MTJR1S00 Tachometer W/Alarms Max Jr Tach Digital Display
Intermec bar code scanner 1552 VT Scanner Kit barcode sabre (Needs Battery)
National Instruments ASSY 191329B-04 Analog Input DAQ Card NI PCI-6220
Norgren EC63D-A-1-X42M-?90A-R-15-10-0 Power Clamp EC63DA1X42M90A
Norgren FU106 A LRE 2A S4 2.5 Pneumatic Power Clamp 0174 8DJG
Norgren SC63 A 91A 180 R S2 1 Pneumatic Power Clamp 0174-8DM0
Norgren SC63-A-41A-90A-?R-S3-1.5 Pneumatic Power Clamp
Norgren W63 A 61M 90 R S3 2.5 Pneumatic Power Clamp 0174 8DK2
Reliance Electric O-51820-2 0 PC Pulse Transmitter
Tesa, 03210923, LVDT Linear Palpeur Axial Probe Sensor
Allen Bradley 700-N800A1 Industrial Control Relay
port Q2040-AVR1 Controller DCV Panel Meter Digital 120V 7W
PMC N-HC Electronic Pressure Transmitter 24VDC 4.20mA
PRX Powerex Eupec BISCR 15001850 22N6 Thyristor SCR 1709 1500a 1500 amp
GE Fanuc A16B-1600-0280/?02A PCB
Telemecanique Interlock Switch XCSL764F3DA --
Cosel, ADA750F-24, Power Supply
Omron, E5AX-VAA-F, Temperature Controller Multi Range
Euchner, RGBF-05R12-502-?C1708-4, 5 position Roller Precision Limit Switch
Masa, PLS-801, Programmable Limit Switch PLS-801-CU-08C
Heidenahain Rotary Encoder ROD 420.000B-600 295 281 56
Balluff BRGD 2-WCD 08-EP-P-R-K-SA1?-01 Rotary Encoder WCD08 783685
Sensotec Honeywell 7500lb Compression 53/F624-01 Load Cell 060-F624-01 7500 lbs
Tweco Robotics QRWA Welding Torch Mig QRWA608-030304-?494290 Robot Motoman Welder
Yaskawa, YWP-AH, Circuit Board JANCD-NTU30B-2
Jola EHW 1-Z10 Suspension Electrode 100010606 Leckstar 101 Leak Detector Probe
Welding Technologies 8113-2M0 WTC 100-5110-2 PCI Card Board Network
Opto 22 Brain Board brick G4A8L analog expansion I/O
Bailey Controls IIMRM02 OIS Reset Module 6642376A2
DVT Smartlink DVT-SL Display Driver RS232 Ethernet Video Adapter
UE Micro-Epsilon capaNCDT Series 600 PA601 1892 Capacitive Displacement System
Denso 410101-0490 Upper Case Teach Pendant JRC Motoman Yaskawa Robot
Allen Bradley 8000 IOAB 24VDC Puller Digital I/O Circuit Board 8000IOAB PC Board
Siko MSK320-0392 Position Sensor 24VDC
BEI Motors 924-01039-1179 Encoder H20DB-25-SS-200?-AB-24V/OC-SM14
Honeywell UDC2300 Temeperature Digital Controller DC230B-CE-11-10?-0000000-00-0
Balance Engineering BEBMIA-104 PCB board card
IMSl FHC-3 Heated Gate Cutter part blade fh2 fhc3
Motoman JANCD-2V02B servo control board 410890 479013-1
AAA, 391V, Air/Gas Solenoid Valve 250W 150psi SP6-3N Sub Plate Manifold
Teral Kyokuto LSW15TL0.18MTS Coolant Pump LSW 150.18MTS Repaired
Vickers DG4V-3S-OA-M-FP?M4WL-H5-60-EN65?4 0A Hydraulic Solenoid Valve
Heidenhain 295466-07 Rotary Encoder 2500 03S12-03 R
Murr, 56650, Elektronik Cube67 I/O Compact Module Valve Interface Digital
Tokyo Rikosha Rike Varitap VSCP-30-N servo drive amp
Siemens 6ES7 322-1HH00-0AA0 Simatic S7 Output Module
Data Translation DT2814 LVDT card
Asco Joucomatic E290A020 Solenoid Valve 2" water steam Brass
Chino DZ1000 Digital Controller DZ1030-000 DZ-1000
Deemstop DDU/CX Operator Interface Tool Changer
Electromotive SBPN-38-WA Pendant Push button Crane Button Hoist Control
Ono Sokki RP-442Z Rotary Encoder 100P/R
PC Communication Board C-8335-1731-2 , C-8335-4731-2 DOP680
Yaskawa TDBO-1P5LS Dynamic Braking Unit 7000H6GP
Unico 310-009 Dual 12 Bit Resolver Interface Transducer 4000 310009
Square D 8536 SCG4V02 Motor Starter nema 1 SCG 120v
Dart 523-300C DC Motor Drive
Leuze ODSL 8/D4-400-S12 Optical distance sensor
Allen Bradley 1756-L55 M14/A Cat.Rev-F01 Control Logix 5555 Processor
Allen Bradley 1756-M12/A Control Logix 5555 Processor W/ 1756-L55/A Rev-F01
Allen Bradley 1756-M14/A L55/A Cat.Rev-G03 Control Logix 5555 Processor PLC
BK Mikro 8 BK824-128 SB Control Scanner Object Monitor
Boston Gear F713-30-B5-G Gear Speed Reducer
Telemecanique Square D LD1 LB030BD Starter Contactor Breaker 24VDC
Balluff BNS-816-B06-NA-?12-602-11 6 Multi Inductive Position Limit Switch
Honeywell RM7823 A 1016 Primary Flame Switch Burner Control
Sick Stegmann Coreman DRS60-E4A01000 Rotary Encoder 10-32VDC
Square D 9037 EW-9 Float Switch 600VAC 10A
BEI M25E-X-HSS8192N?-XD3-CR-E-C14-X?-5 Encoder Systems
Nematron PCB-BBSRAM-01 PC Board BBSRAM IS w/ External Battery
Abicor Binzel R5A-C-35EC-BC Abirob A500 3.5' Cable Assembly Brns A50022 090908
Mitutoyo AT211-0200B1H-Q?1-AZZ Linear Scale LVDT SC0107012 15"
Keyence KV-300 Programmable Controller
Microscan 010-026900 Nerlite PCBA BL-50x200 ILED Light Machine Vision Backlight
Masa PLS-801 Programmable Limit Switch PLS801-PRG-1 Gleason Repaired
Cutler-Hammer E51CLT1 Inductive Proximity Switch
PCB Piezotronics J302B05 Accelerometer 302B05
Toyo Magiceye SOT-NP1601S4 Photswitch Sensor switch S0T-NP1601S4
Baldor GPP12547 Industrial DC Gear Reducer Geared Motor 90VDC 1.32A 1/8HP
Plitron 5486-B2-00 Torid Toroidal Transformer #2136 X5712 Stanley Air Tools
PPT Vision Light 661-0113-SB Machine Camera Cognex DVT strobe flash flood
Honeywell Sensotec 060-0708-18TJG-?04 Pressure Transducer Senor 500PSIG 500psi
Vickers Hydraulic Pump Cartridge 11 gallon 11gal 11g V11
GE Motors 5BPA56KAG20B DC Motor 1/2HP 1725rpm 90V 90vdc 5A
Electromotive SBP Can-D SBPN-8-WA Pendant Pushbutton Crane button Hoist
Barrett Electronics DF62011349 PC Board 80-7302 R7 Demag
Denso 410010-0231 Power Supply RP199C MEC-37AV-0 MEC-M1A drive inverter?
Denso 410010-0241 PC Board Power Supply RP198C w/ Fuji 6MBI15L-060 Module RP200C
Denso RP-196CF PC Board 410010-0260 RP199C 0AA0240 Drive motor amplifier
Heidenhain ROD 426.011 1250 Encoder 220 392 16
Leeson C4C17FZ35A Gear Motor .33hp 1PH 107011.00 C4C17FZ35
Ogden ETR-9300-412003 Temperature Controller
PepperL+Fuchs MLV11-8-LAS-150?/47/112 Visolux Photoelectric Sensor 421565S
SunX TSP-C Controller
Cutler-Hammer FD3030L Industrial Circuit Breaker FD 35k 30A 3Pole
Fuji Electric H53BA Circuit Breaker 40A 600VAC BB3BHC-040
Fuji Electric SA103RAUL Circuit Breaker 50A 240V 3P
Mitsubishi Electric DTYA30870 IGBT Transistor MW A300 CH400DU-12F Motoman
Mitsubishi A1SJ71UC24-R4 Communication Board
Schrader Bellows 712-3000 REED Switch 120VAC 1/2A
Square D 9050AO22EV02 Pneumatic Timer Relay Contactor Starter 9050AO22E 600V
Serno Valve Control Card 58548 MCI 4-04-5303 9-11-9902 Board 1277-501
Allen Bradley Photoswitch 22DJ4-4000 Ser B On-Off Control Module
Bachmann SER 232 Serial Interface Processor Board Card Module B-02842/00
Watlow 96A1-KDDA-00RR Temperature Controller Type 4X 12 Enclosure
Bircher Reglomat ESD3-04-24ACDC Safety Relay ESD3
Mitsubishi Melsec A0J2-E32D Input Module
Allen Bradley 1756-OA161 AC ISO Output Module 16Pt 240 120/240VAC 0A161
Allen Bradley 836-AL11NKC36 Pressure Switch
B&B Electronics 3PCIOSD2B RS-422 232 485 Serial Card 2p
Bailey Controls Infi 90 NTA105 Analog Input Module Termination Net90
