- Input Method: Finger input
- Accuracy*: Reported touch coordinates are within 1.0% of true position (based on viewing area dimensions) when linearized and used with a MicroTouch™ EX II Series touch controller
- Touch System Resolution: Touch screen resolution defaults to settings in the electronics and software, generally 1024 x 1024, but capable of 16K x16K when used with EX II.
- Linearization: Factory-linearized values are stored in the attached controller.
- Impact Resistance: Passes the UL-60950-1
Optics
- Light Transmission**: 86.5 % (±1.5%) light transmission (tested on the BYK Gardner Haze Gard Plus)
- Surface Finish: ClearTek™ II hard coat with optimal anti-glare properties. Scratch resistant top coat provides smooth, easy glide, easy to clean touch surface
Mechanical
- Minimum Contact Requirement: 5.4 ms for finger input with an EX II Series controller
- Glass Thickness: 7.57mm (±0.58mm), with 3M Vikuiti™ Light Control Film (privacy): 8.51mm (±0.58mm)
- Display Size Supported: Standard products ranging from 10.4" to 19" diagonal (Light Control Film: 10.4" to 17" diagonal). Custom products available ranging from 6.5" to 32".
- Surface Scratch Hardness: A Mohs pick with a hardness rating of 7 or higher is required to induce a scratch which will cause a functional failure. Exceeds severe abrasion test per MIL-STD-675C
- Sealing Rating: Can be sealed to meet the IP 66 or NEMA 4 standard for resistance to infiltration of fluids into the enclosure.
- Gasketing: Complete water-resistant seal obtainable with a polyethylene gasket. Please consult the ToughTouch II Integration Guide for further details.
- Mounting: Please consult ToughTouch II Integration Guide for specific mounting instructions.
- Cleaning: Water, isopropyl alcohol, or similar non-abrasive cleaners.
Reliability
- Surface Obstructions: The touch screen continues to operate with surface contaminants such as, dirt, dust and grease.
- Chemical Resistance: ClearTek™ II is highly resistant to corrosives, in accordance with ASTM-D-1308-07 (1993) and ASTM - F- 1598-95.
- Liquid Resistance: Liquids on screen do not impede touch screen performance.
- Operating Temperature*: -40° C to 70° C for the touch screen.
- Storage Temperature: Always store the touch screen in its original shipping container between -50° C and 85° C (up to 90% RH from 0° C to + 35° C). Never store the touch screen in an environment where condensation may form.
- Humidity: Up to 90% RH from 0° C to +35° C, non-condensing.
- RoHS Compliance: ToughTouch II is compliant with the European union 2002/95/EC Directive on Restriction of Hazardous Substances (RoHS).
- Warranty: 5 years
