3M MicroTouch SCT3250EX 15寸
品牌: 3M MicroTouch
型号: SCT3250EX 15
所在地: 上海
最后更新: 2019-05-22 15:06
  • System Performance
  • Light Transmission 91.5% (±1.5%)
  • Input Method Finger contact
  • Accuracy >99% of true position
  • Resolution 1024 x 1024, but capable of 16K x16K when used with EX controllers
  • Linearization Factory linearized
  • Tail Connection Solder-less design
  • Electronics (3M MicroTouch Controller EX)
  • Communication USB, Serial, USB HID Digitizer, Dual Mode (USB and Serial
  • Dimensions 1.30" x 2.55" x 0.45"
  • 33.0 x 65.0 x 11.4 mm
  • Operating Current USB: 75 mA (typical)
  • Serial: 85 mA (typical)
  • Sleep Current < 500 uA
  • Power Connection USB: 5Vdc ± 5% 75 mA
  • Serial: 5-12Vdc ± 5% 85 mA
  • Connectors 5-pin locking AMP (Touch side) 5-pin Molex (COM side)
  • ESD ±8KV Contact, ±27KV Air
  • Point Speed (PPS) 200 pps
  • Minimum Touch Time 5.4 ms
  • MTBF >700,000 hours
  • Reliability
  • Surface Obstructions Withstands most surface contaminants
  • Chemical Resistance ASTM-D-1308-02 and ASTM-F-1598-95
  • Liquid Resistance Liquids on screen do not impede touch performance
  • Operating Temperature -40° C to 70° C for the touch screen
  • Storage Temperature -50°C and 85°C
  • Humidity Up to 90% RH from 0o C to 35o C, non-condensing
  • Mechanical
  • Glass Thickness 0.125" (3.18 mm)
  • Display Size Supported 5.7" (144.78 mm) to 32" (812.80 mm) (standard and wide formats)
  • Surface Scratch Hardness MoHS 7 or higher to induce a functional failure
  • Scratch Resistance 3M™ ClearTek™ hard coat
  • Sealing NEMA 4X / IP66, complete water-resistant seal compatible
  • Cleaning Water, isopropyl alcohol, or similar non-abrasive cleaners
  • RoHS Directive Yes Compliant
  • System Warranty
  • 5 years on touch system
  • Unlimited touch warranty
  • Operating Systems Supported
  • Windows 7 (32-and 64-bit)*
  • Windows Vista (32-and 64-bit)
  • Windows XP (32-and 64-bit)
  • Windows 2000, Server 2003, Server 2008 (32-and 64-bit)
  • Windows 98, 95, ME, NT 4.0, NT 3.5, 3.1x (32-bit)
  • Windows CE, XPe, WePOS (32-bit)
  • Linux Kernel 2.6, Kernel 2.4 (serial only)**
  • Apple OSX (UPDD driver)**
  • * 3M MicroTouch System SCT3250EX HID is Windows 7 Logo Compatible
  • ** Limited MT7 features supported
电容屏物体识别应用解决方案 3M防爆触摸屏15寸 3M MicroTouch SCT3250EX 15寸 3M MicroTouch SCT3250EX 17寸 3MTouch Display C3266PW 20.1寸电容触摸屏 20寸多点电容屏,21寸多点电容屏,22寸多点电容屏 17寸多点电容屏,17寸20点电容屏
