| Diagonal | Format | Part Number |
| 15" (15.08") | Standard | 98-0003-3751-3 |
| 15" (15.65") | Wide | 98-0003-3850-3 |
| 17" (17.15") | Standard | 98-0003-3745-5 |
| 18.5" (18.61") | Wide | 98-0003-3763-8 |
| 19" (19.09") | Standard | 98-0003-3800-8 |
| 20" (20.11") | Wide | 98-0003-3802-4 |
| 21.5" (21.5") | Wide | 98-0003-3781-0 |
| 22" (22.10") | Wide | 98-0003-3771-1 |
| 23" (23.13") | Wide | 98-0003-3805-7 |
| 24" (24.00") | Wide | 98-0003-3775-2 |
| 26" (26.00") | Wide | 98-0003-3832-1 |
| 27" (27.00") | Wide | 98-0003-3779-4 |
| 32" (31.69") | Wide | 98-0003-3783-6 |
- Number of Inputs:
Touch Inputs 15” to 26”: 20 touches with palm rejection
Touch Inputs 27” to 32”: 40 touches with palm rejection - Input Method : Finger, thin gloves
- Accuracy: >99% of true position
- Resolution: 4K x 4K
- Linearization: Inherently Linear (only video alignment needed)
- Tail Connection : Solder-less design
- Light Transmission: > 87%
- Communication: USB HID Digitizer, Serial RS-232
- Dimensions (15"): 2.75" x 2.75” (69.85 mm x 69.85 mm) REF
- Dimensions (16” to 26”): 3.25" x 2.75” (82.55 mm x 69.85 mm) REF
- Dimensions (27” to 32”): 3.45" x 3.33” (87.63 mm x 84.46 mm) REF
- Operating (15"): 236mA
- Operating (16" to 26"): 360 mA
- Operating (27” to 32”): 380 mA
- Sleep Current (15"): 850 uA
- Sleep Current (16" to 26"): 850 uA
- Sleep Current (27” to 32”): 750 uA
- Power Connection: Self-powered 5 V @ 2 A max
- Connectors: ZIF (touchscreen side)
Molex (USB/Serial COM side) - Touch Refresh Rate: Greater than 100 Hz (<10 ms)
- Surface Obstruction: Withstands most surface contaminants
- Chemical Resistance: ASTM-D-1308 and ASTM-F-1598-95
- Operating Temperature: 0°C to +50°C (up to 90% RH from 0°C to +35°C (above +35°C see specification))
- Storage Temperature: -10°C to +70°C (up to 90% RH from 0°C to +35°C (above +35°C see specification))
- Humidity: Up to 90% RH from 0°C to +35°C, non-condensing (above +35°C, see specification)
- Total Thickness: 15” to 27”: 2.1 mm
- Total Thickness: 32”: 2.4 mm
- Cover Glass: 15” to 27”: 1.6 mm Thickness
- Cover Glass: 32”: 1.9 mm
- Graphics: Black border (standard design)
- Display Size Supported: 15” to 32” (standard sizes available)
- Durability: Non-active cover glass, no wear mechanism
- Sealing: NEMA 4X/IP66, complete water-resistant seal compatible
- Cleaning: Water, isopropyl alcohol, or similar non-abrasive cleaners
- RoHS Compliant: Yes
- Regulatory: FCC-B, CE, IEC 60950 (Agency Approvals)
- One year on touch system
- Unlimited touch warranty
- Windows 8, 7, Vista, XP (32- and 64-bit)
- Windows CE 3.0, 3.2, 4.0, 5.0, 6.0
- Linux Kernel 2.6, Kernel 2.4 (serial only)
- Mac OS (Intel)**
