型号:MDP-40B
适用范围:0.5升-5升桶装涂料 5L×2桶/次
适用混合桶的高度范围:80mm-240mm
振动频率:550次/分
工作电压:220V 50/60Hz
功率:250W
净重:68Kg 毛重:95Kg
机器尺寸:500(高)×820(宽)×550(深)mm
包装尺寸:530(高)×910(宽)×620(深)mm
优越性能:
操作简便快捷,故障率低。
经喷砂处理加厚的压铸夹板,外形美观,性能可靠
定时开关,使您可以根据需要随时设定混合时间
全方位摇摆振动,保证充分混合。
Technical date:
capable range:0.5-5L(paint in drum),2drums per time
Height of the drun:80mm-240mm
Shaking frequency:550t/min
Working power:220v 50/60 Hz
Power:250w
Net weight:68kg Gross weight:95kg
Case size:500(H)×820(W)×550(D)mm
Packing size:530(H)×910(W)×620(D)mm
Easy and fast operation,low malfunction.
The sandblasted die-casting shims are nice to look at,reliable in function.
You can fix the shaking time according to your need by the fix time button.
Full direction`s shaking guarantees the thorough paint mixing
