本司生產電動油墨攪拌機是積累生產製造經驗,廣泛吸取用戶意見,經過多次技術改進之優良產品!
選用之部件皆可靠性高,質量優良,以保證各攪拌均勻,質優耐用!
外觀輕巧優美、外殼有多種材質的製作,操作方便簡單!
本機亦有時間控制及調速之裝置,使用者可依油墨之粘度自由選擇控制攪拌時間!
攪拌容量:1L--5L
時間控制:0---60分锺
轉 速:0--150转/分
電 源:220V 50HZ
電機功率:60W
重 量:21kg
機械尺寸:L320*W230*H600mm
配置搅拌刀:2把(分别:大刀宽8CM,小刀宽5CM 各一把) , 可夹油墨桶尺寸:直径9-18CM,高度:8-20CM。
材质: 烤漆外壳,配送搅拌刀是铁材质有做过表面电镀处理。
**本机严禁搅拌易燃易炮油墨**
Electric Ink Mixer SU-208YB
The manufacture of company's electric mixer is the accumulation of many years of manufacturing experience, draw extensively on the views of users, and many technological improvements!
Selection of the components are high reliability, high quality and to ensure the high quality of mixing are durable!
Appearance is light and elegant、the manufacture of shell has many materials、Simple and convenient operation!
The machine also has the device of time and speed control, The users can choice freely to control the mixing time according to viscosity of ink!
Mixing capacity:1L—5L
Time control:0---60 min
Rotational speed:0--150 r/min
Power supply:220V 50HZ
Power:60W
Weight:21kg
Machine size:L320*W230*H600mm
