真空油墨搅拌机
*本产品搅拌油墨完毕后可立即进行生产,不需要将油墨停放、也不会发生在操作的时候混入灰尘而导致油墨产生气泡的情况,大大提高了生产的效率和产品质量。
*采用的电机,可正反转操作、速度均匀可调、搅拌刀可根据油墨桶的大小来调整位置.
*采用的无油真空泵,是一种高品质、高效率、长寿命、低噪音、运行平稳安全的真空泵。
*本真空油墨搅拌机操作容易、方便、搅拌均匀是用于油墨搅拌的最佳设备!
型号:TZ-C700H
搅拌容量:1-5L
转速:0-150转/分
时间控制:0-999分钟(内设可调整5-10分钟)
电源:AC 220-240V 50Hz
电机功率:60W 速度比:1:10(150r/min)
电流:2A
重量:32KG
机械尺寸:L400×W400×H910mm
2:无油真空泵参数:
电源是:AC220V 50Hz 180W
抽气速度:25L/min
转速:2200r/min
极限压力为:-12kpa(根据油墨的粘度设置)
真空设备体积:L400 mm×W400 mm ×H480mm
真空防护罩:直径400 mm×高480 mm
噪音为:50-60Db(A)
配置搅拌刀:2把(分别:大刀宽8CM 1把,小刀宽5CM 1把)
可夹油墨桶尺寸:直径9-18CM*高度8-20CM
可搅拌油墨:水性,油性。高中低粘油墨。
**严禁搅拌易燃易爆油墨!!**
Vacuum ink stirrer
*The ink can be used for production immediately after stirred completely by the stirrer without halt to save the ink; the stirrer can prevent air bulbs from occurring in the ink due to dirt mixed into the ink during operating, and it improves productivity and ink quality greatly.
*The motor used by the stirrer can be operated in clockwise direction and counter clockwise direction, the speed is even and can be adjusted, the stirring knife can be arranged in different positions according to the dimensions of ink drums.
*Oil-free vacuum pump used by the machine is a kind of high quality, high efficiency, long life, low noise, stable operation and safe vacuum pump.
*The vacuum ink stirrer is the best machine for ink stirring as it is easy and convenient for operation with even stirring result.
Model:TZ-C700H
Stirring volume:1-5L
Speed:0-150 rpm
Time control:0-999 minutes( inside set adjusted time is of 5-10 minutes)
Power supply:AC 220-240V 50Hz
Motor power:60W speed ratio:1:10(150r/min)
Current:2A
Weight:32KG
Mechanic dimensions:L400×W400×H910mm
2. Parameter of oil-free vacuum pump
Power supply:AC220V 50Hz 180W
Vacuuming speed:25L/min
Speed:2200r/min
Maximum pressure:10-20kpa(it can be set according to the ink viscosity)
Vacuum machine volume:L400 mm×W400 mm ×H480mm
Vacuum protection cover: diameter 400 mm×height 480 mm
Noise:50-60Db(A)
