型号:MDP-40A
适用范围:0.5升-20升桶装涂料及油墨
定时:0~15min(亦可改为0-120分钟,10分钟为一格)
适用混合桶的高度范围:100mm-340mm
直径最大340mm
振动频率:710次/分
工作电压:220V 50Hz
功率:750W
净重:195Kg 毛重:240Kg
机器尺寸:1040(高)×860(宽)×710(深)mm
包装尺寸:1095(高)×905(宽)×805(深)mm
优越性能:
高速彻底的混合—最快时可在30秒内将涂料及油墨混合均匀。
可混合0.5—20升的桶装涂料及油墨。
操作时噪音小并带有安全栏。
具有较大的门并附有向前伸出的滚桶,有利于桶的装载。
安全互锁,以防止机器运转时门被打开。
可根据桶的外观和尺寸调整桶的高度。
**严禁振荡易燃易爆油墨!!**
Technical data:
Applicable range:0.5L-20L(paint in drum)
Time set:0-15min
Applicabie height of drum range:100mm-380mm
Shaking frepuency:710t/min
Working power:220v 50Hz
Power supply:750W
Net weight:210kg
Gross weight:240kg
Case size:1040(H)×860(W)×710(D)mm
Packing size:1095(H)×905(W)×805(D)mm
High speed thorough action---mixes most paints in at most 30 seconds.
Will accept0.5L-20L cases.
Fully enclosed for silent operation and added safety.
Large door with front roller for easy can load in.
Safety interlock---prevents the cabinet door from being opened while the machine is running.
Accommodates all can shapes and sizes from 0.5L---20L.
