COMMUNICATION PROCESSOR CP 5613 A2 PCI CARD (32 BIT; 3.3/5 V; 33/66 MHZ); FOR ConNECTION TO PROFIBUS; INCL.DP-base SW, NCM PC: DP RAM INTERF.F.DP MASTER INCL. PG AND FDL PROTOCOL, SINGLE LICENSE F.1 INSTALLATION,R-SW, CLASS A;SW+ELECTR. MANUAL ON CD 2 LANG. (GER, EN); SUPPORT FOR OPERATING SYSTEM SEE SIMATIC NET SW
本公司优势产品
产品 ID
nly="" value="U" />
6GK1905-0EA10
SIMATIC NET,PB FC M12 PLUG PRO M12 插头式连接器,带有坚固金属外壳和 FC 连接方法,带轴向电缆出口,和 ET200PRO 共用,插针连接器(B 编码),每包 5 件
nly="" value="U" />
6GK1905-0EB10
SIMATIC NET, PROFIBUS 标准总线电缆, 2 芯, 屏蔽, 为快速安装而特殊设计, 20 m
nly="" value="U" />
6XV1830-0EN50
SIMATIC NET, PROFIBUS 标准总线电缆, 2 芯, 屏蔽, 为快速安装而特殊设计, 50 m
nly="" value="U" />
6XV1830-0ET10
SIMATIC NET, PROFIBUS 标准总线电缆, 2 芯, 屏蔽, 为快速安装而特殊设计, 100m
nly="" value="U" />
6XV1830-0ET20
SIMATIC NET, PROFIBUS 标准总线电缆, 2 芯, 屏蔽, 为快速安装而特殊设计, 200 m
nly="" value="U" />
6XV1830-0ET50
SIMATIC NET, PROFIBUS 标准总线电缆, 2 芯, 屏蔽, 为快速安装而特殊设计, 500 m
nly="" value="U" />
6AG1500-0EA02-2AA0
SIPLUS NET PB ConNECTOR FOR -25 ... +60 DGR C AND MED baseD ON 6GK1500-0EA02
nly="" value="U" />
6AG1972-0BA12-2XA0
SIPLUS DP PB ConNECTOR W R - 90 DEGREES CABLE OUTLET -25 ... +70 DEGREES C WITH ConFORMAL COATING baseD ON 6ES7972-0BA12-0A0
nly="" value="U" />
6AG1972-0BB12-2XA0
SIPLUS DP PB-ConNECTOR M R - M PG - 90 DGR CABLE OUTLET -25 ... +70 DEGREES C WITH ConFORMAL COATING baseD ON 6ES7972-0BB12-0A0
nly="" value="U" />
6ES7972-0BA12-0A0
SIMATIC DP,总线连接器,用于PROFIBUS,高达12 MBIT/S,90度出线电缆(W X H X D):15,8 X 54 X 34 MM,端接电阻,带隔离
nly="" value="U" />
6ES7972-0BA30-0A0
BUSANSCHLUSS-SIMATIC DP,总线连接器,用于PROFIBUS,带斜出线电缆,绝缘刺破连接装置(W X H X D)15 X 58 X 34 MM,高达1.5 MBIT/S,无 LAN端接电阻
nly="" value="U" />
6ES7972-0BA42-0A0
SIMATIC DP,总线连接器,用于 PROFIBUS UP,传输速率达 12 Mbit/s,带弯式电缆引出口,15.8 X 54 X 39.5 mm(宽 x 高 x 深),端接电阻器,带隔离功能,无编程器插口
nly="" value="U" />
6ES7972-0BA52-0A0
SIMATIC DP, 连接 PROFIBUS(高达 12Mbit/s)的总线连接器,90 度电缆出线,15.8 X 59 X 35.6 mm(W X H X D),IPCD TECHOLOGY 快速连接,无 PG 插座
nly="" value="U" />
6ES7972-0BA60-0A0
SIMATIC DP,总线连接器,用于PROFIBUS,高达12 MBIT/S,35度出线电缆(WX H X D):16 X 72.7 X 34 MM,IPCD 快速连接技术,
nly="" value="U" />
6ES7972-0BA70-0A0
SIMATIC DP, BUS ConNECTOR FOR PROFIBUS UP TO 12 MBIT/S 90 DEGREE ANGLE CABLE OUTLET, 15.8 X 72.2 X 36.4 MM (WXHXD), IPCD TECHOLOGY FAST CONNECT, WITHOUT PG SOCKET
nly="" value="U" />
6ES7972-0BB12-0A0
SIMATIC DP,总线连接器,用于PROFIBUS,高达12 MBIT/S,90度出线电缆(W X H X D):15.8 X 54 X 34 MM,端接电阻,带隔离
