- LCD Technology: TFT, Active Matrix
- Display Colors: 16.2 million
- Pixel Pitch: .264mm
- Brightness without touch screen: 300 cd/m2 (nit) typical
- Brightness with touch screen (max.)(1): 270 cd/m2 (nit)
- Contrast Ratio: 1000:1
- Video Response Time: 5 ms typical
- Touch Response Time: 5.4 ms typical
- Back Panel Buttons: Menu, Select, Adjust, Power
- Viewing Angle (from center)*: Horizontal and vertical: +/-80 degrees typical
- On-screen Display: Brightness, Contrast, H/V Position, Phase, Auto-configuration, Sharpness, OSD control, Frequency, Utilities
- Maximum Resolution: 1280 x 1024
- Operating Environment: 0 to +40 degrees C. Relative Humidity, non-condensing 90%
- Storage Environment: -25 to +60 degrees C
Physical Features
- Physical Dimensions (WxHxD)(Enclosure): 405.7 x 335.1 x 49 mm, 15.98 x 13.18 x 1.93 inches
- Display Area (WxH): 337.9 x 270.3 mm, 13.3 x 10.6 inches
- Video Cable Connector: 15-pin D-sub
- Power Supply: Internal 12V DC Power Supply
- Power Savings(2): DPMS, VESA Compliant
- Power Consumption: 30 watts normal operation
- Backlight Life: 50,000 hrs. typical
- Weight (Net): 4.6kg/10.1 lbs
- Agency Approvals: FCC B, CE, UL/cUL, RoHs
- Mounting Options: Brackets (2), 100mm VESA pattern
- Controller Option: Serial, USB
- Warranty: 3 years
(1) Brightness measured on a display with 3M™ MicroTouch™ Sensor SCT3250.
(2) DPMS: Display Power Management Signaling for reduced power consumption during non-use.
* Viewing angle measured with contrast ratio ≥1
