General |
Model |
COT170E-IWF02 |
Series |
Waterproof and Compact |
Monitor Dimensions |
Width: 368mm Height: 306mm Depth: 49.5mm |
LCD Type |
17”SXGA Color TFT-LCD |
Video Input |
VGA and DVI |
OSD controls |
Allow on-screen adjustments of Brightness, Contrast Ratio, Auto-adjust, Phase, Clock, H/V Location, Languages, Function, Reset |
Power Supply |
Type: External brick |
Mount Interface |
1)VESA 75mm and 100mm 2)Mount bracket, horizontal or vertical |
LCD Specification |
Active Area(mm) |
337.920(H)×270.336(V) |
Resolution |
1280×1024@75Hz |
Dot Pitch(mm) |
0.264×0.264 |
Nominal Input Voltage VDD |
+5.0V(Typ) |
Viewing angle (v/h) |
85°/80° |
Contrast |
1000:1 |
Luminance(cd/m2) |
250 |
Response Time(Rising/Falling) |
5s/5s |
Support Color |
16.7M colors |
Backlight MTBF(hr) |
30000 |
Touchscreen Specification |
Type |
Cjtouch Infrared IR touch screen Dual touch |
Resolution |
4096*4096 |
Light Transmission |
92% |
Touch Life Cycle |
50 millions |
Touch Response time |
16ms |
Touch System Interface |
USB interface |
Power consumption |
+5V@80mA |
External AC Power Adapter |
Output |
DC 12V /4A |
Input |
100-240 VAC, 50-60 Hz |
MTBF |
50000 hr at 25°C |
Environment |
Operating Temp. |
0~50°C |
Storage Temp. |
-20~60°C |
Operating RH: |
20%~80% |
Storage RH: |
10%~90% |
QQ:610170001
