General |
Model |
COT101-CFK02 |
Series |
Water-proof and Flat screen |
Monitor Dimensions |
Width: 254.8mm Height: 177.5mm Depth: 40mm |
LCD Type |
10.1” Active matrix TFT-LCD |
Video Input |
VGA and DVI |
OSD controls |
Allow on-screen adjustments of Brightness, Contrast Ratio, Auto-adjust, Phase, Clock, H/V Location, Languages, Function, Reset |
Power Supply |
Type: External brick |
Mount Interface |
1)VESA 75mm and 100mm 2)Mount bracket, horizontal or vertical |
LCD Specification |
Active Area(mm) |
216.96 (H) x 135.6(V) |
Resolution |
1280×800 @60Hz |
Dot Pitch(mm) |
0.1695(H) x 0.1695(V) |
Nominal Input Voltage VDD |
+4V(Max) |
Viewing angle (v/h) |
80°/89°(CR>10) |
Contrast |
800:1 |
Luminance(cd/m2) |
450 |
Response Time(Rising) |
25msec |
Support Color |
16.7M colors |
Backlight MTBF(hr) |
10000(Min) |
Touchscreen Specification |
Type |
Cjtouch Projected Capacitive touch screen |
Multi touch |
5points touch |
Touch Life Cycle |
10 millions |
Touch Response time |
8ms |
Touch System Interface |
USB interface |
Power consumption |
+5V@80mA |
External AC Power Adapter |
Output |
DC 12V /4A |
Input |
100-240 VAC, 50-60 Hz |
MTBF |
50000 hr at 25°C |
Environment |
Operating Temp. |
0~50°C |
Storage Temp. |
-20~60°C |
Operating RH: |
20%~80% |
Storage RH: |
10%~90% |
联系电话:13410932779 陈先生
QQ:610170001
