| 镭射系统 | ||||
| 1 | 镭射头laser head | newwave 镭射系统 | ||
| 2 | 镭射种类laser type | YAG Laser | ||
| 3 | 镭射波长laser wavelength | 1064nm | ||
| 4 | 镭射功率laser power | 0.6mj/purse | ||
| 5 | 发振频率vibration frequency | 1-20HZ | ||
| 6 | 冷却方法cooling method | 气冷式 | ||
| 7 | flash lamp life time | 一年或大于1000000shots | ||
| 8 | 输出能量控制output power control | 512 steps for 0-100% Hi/Low switch-able | ||
| 9 | 镭射发振器保固期warranty period | 一年 | ||
| 10 | 介面interface | RS-232 | ||
| 光学影像系统Optical imaging system | ||||
| 1 | 显微镜microscope | 观测/镭射加工专用型 | ||
| 2 | CCD | 1/2" Color CCD | ||
| 3 | 落射光源Catoptric light source | 高亮度卤素光源系统(100W) | ||
| 4 | 物镜切换系统Objective switched systems | 4孔/手动切换式 | ||
| 5 | 精密物镜组Precision optical lens group | 5倍、10倍、20倍、50倍 | ||
| XYZ轴驱动系统XYZ axis drive system | ||||
| 1 | XY轴有效行程XY axis effective travel | 570mm*330mm | ||
| 2 | XY轴驱动形式XY axis driving types | 手动 | ||
| 3 | XY轴最小解析度XY axis resolution | 1um/pulse | ||
| 4 | 重现性reproducibility | 小于等于5um | ||
| 5 | Z轴最大行程Z axis largest travel | 90mm | ||
| 6 | Z轴驱动形式Z axis driving types | 手动 | ||
| 7 | Z轴最小解析度Z axis resolution | 0.1um/pulse | ||
| 操作模式Operating mode | ||||
| 1 | 面板尺寸Panel size | 24寸 | ||
| 2 | 操作方式operating mode | 镭射手动操作击发 | ||
| 载台及避震系统plat and suspension | ||||
| 1 | 材质material | 精密研磨光学玻璃平台 | ||
| 2 | 尺寸size | 570mm*330mm | ||
| 3 | 底座bottom support | 精密钢构底座 | ||
| 4 | 避震形式Suspension form | 气压式避震 | ||
| 5 | 自然频率natural frequency | 2-2.3Hz | ||
| 6 | 厂家供气规格factory supply specifications | 4-6kg/c㎡ | ||
