美国EIT单通道 UV能量计
EIT UVICURE PLUS II
美国EIT UVICURE PLUS II单通道能量计 屏幕同时显示强度值,能量值,温度的多功能UV能量计。可以挑选UVA,UVB,UVC,UVV,UVA2任一单波段型号。
SPECIFICATIONS:
| UVICURE PLUS II and UV POWER PUCK II | |
| Display | Easy to Read, Yellow Text on Black Background |
| Suggested Dynamic Ranges | 10 Watt: UVA, UVB, UVV - 100mW/cm?to 10W/cm? UVC - 50mW/cm?to 1W/cm? Low Power Versions: UVA, UVB, UVC, UVV: 1mW/cm?to 100mW/cm? *Please note that units will urn onat irradiance values lower than the suggested operating ranges. |
| Accuracy | +/- 10%; +/- 5% typical |
| Spectral Ranges (UV Power Puck?II) | 4-channel simultaneous and continuous monitoring. 320-390nm (UVA), 280-320nm (UVB), 250-260nm (UVC), 395-445nm (UVV) |
| Spectral Ranges (UVICURE?Plus II) | 1-channel continuous monitoring. 320-390nm (UVA), 280-320nm (UVB), 250-260nm (UVC), 395-445nm (UVV) |
| Spatial Response | Approximately cosine |
| Operating Temperature | 0-75Internal temperature; tolerates high external temperatures for short periods (audible alarm indicates when temperature has exceeded tolerance) |
| Time-Out Period | 2 minutes DISPLAY mode (no key activity). |
| Battery | Two user-replaceable AAA Alkaline Cells |
| Battery Life | Approx. 20 hours with display on |
| Dimensions | 4.60 x 0.50 inches; 117 mm x 12.7 mm (D x H) |
| Weight | 10.1 ounces (289 grams) |
| Package Material | Aluminum, stainless steel |
| Carrying Case Material | Cut polyurethane interior, scuff resistant nylon exterior cover |
| Carrying Case Weight | 9 ounces (260 grams) |
| Carrying Case Dimensions | 10.75 x 3.5 x 7.75 inches; 274 x 89 x 197 mm (W x H x D). |
