The UV-Integrator 140 is a high quality UV measuring instrument. It is used to measure UV energy of different light
sources, especially on printing machines. It was specially designed with a recess in the housing for better handling.
It is ideal to ensure quality control of printing and drying processes.
Big size, heavy duty pass-through Integrator with a diameter of 140 mm. It is reliable and simple to use.
The UV-Integrator 140 is available in six different measuring ranges*:
(Please state upon order)
Item 9.1 UV-Integrator 140, Type 1, Diazo 350 – 460 nm
Item 9.2 UV-Integrator 140, Type 2, UV-A 315 – 400 nm
Item 9.3 UV-Integrator 140, Type 3, UV 250 – 410 nm
Item 9.4 UV-Integrator 140, Type 4, UV-B 280 – 315 nm
Item 9.5 UV-Integrator 140, Type 5, UV-C 230 – 280 nm
Item 9.6 UV-Integrator 140, Type 6, UV-V 395 – 445 nm
*further spectral ranges available upon request
By addition of the incidence of the light quantities during the exposure cycle, relative values are calculated.
Because of uneven radiation distribution of the UV light source and different type of construction of the measuring
devices by different manufacturers, different readings may appear under the same measurement conditions.
Technical Data:
Spectral range: UV 250 – 410 nm
Measuring range: 0 to 5,000 mW/cm2
Display: 6-digit LCD
Display range: 0 to 999,999 mJ/cm2
Power source: long life 3.6 V Lithium Battery
Power consumption: 100 µA
Battery service life: 10,000 hrs
Dimensions: ∅ 5.5” (140 mm) height ½” (13 mm)
Weight: approx. 16 ounce (450 grs.)
Temperature range: 0 to 45° Celsius
Heat protection: Heat shield on back plate
Base Accuracy: ± 5 %
While on the conveyer belt, the UV-Integrator 140 can withstand max. 110° C / 230° F for up to 10 seconds. The
temperature of the housing should not exceed 45° C / 113° F.
Calibration:
In order to keep its full function and precision it is recommended to have re-calibration done once per year. Recalibration will also be necessary after change of battery. Ongoing, PTB traceable calibration with certificate
Warranty:
2 years from the date of purchase, For the German quality battery we guarantee one year
最新德国UV能量计 UV-Integrator140 UV能量计大陆总代 原装正品 谢绝讲价!!
德国UV能量计是用于测量曝光装置的UV能量的一种仪器,测量仪的主感器在测量仪的背面,测量范围为250~410纳米,测量时可直接显示于UV能量计正面的显示屏上读出(单位:毫焦耳/平方厘米),该UV能量计的电源为3.6伏特的锂电池,该电池由于使用了特别的能源节省线路,该电池可持续大约10000小时。
技术数据:
德国UV能量计(UV-integrator1401)
尺寸:直径140mm*高13mm
重量:约450g
适用设备:UV紫外线干燥机、曝光机
测量范围:0-5000mW/cm2
能量显示:LCD 0-999999mj/cm2
电源: 锂电池3.6V
测量范围: 250-410nm(光谱图波长)
耗电量: 约10000小时(Lithiwn锂电池)
工作温度(℃): 0~70℃
UV能量计在输送带上耐温110℃不超过10秒
使用/操作:
a. 打开ON开关,则LCD(显示屏)是显示为零。
b. 将UV能量计放置于曝光UV灯源附近,以其背面对准灯源(UV能量计的能量感受器在背面)。
c. 直到UV能量计的显示屏上有测量显示,例如800毫焦耳/平方厘米。(800mj/cm2)。
d. 将显示屏的值记录或作为品质控制与实验参数,关掉UV能量计开关(OFF)。
