| Viewing Area Dimension D = Diagonal W = Width H = Height |
Outer Area Dimension D = Diagonal W = Width H = Height |
Controllers Available UC = USB SC = Serial |
Aspect Ratio | Cable Length inches (mm) |
Cable Exit | wher to Buy | |
| 3M ID: 98-0003-3621-8 - Alternate Product (Lead Times Apply) | |||||||
| D: 15.74" (399.76 mm) W: 12.51" (317.75 mm) H: 9.55" (242.57 mm) |
D: 16.46" (418.06 mm) W: 13.05" (331.47 mm) H: 10.03" (254.76 mm) |
Included (EXII-7760UC/98-0003-2814-0) | Standard | 4" (101.6 mm) | 10:00 | select a RegionCheck U.S. Distributor InventoryAfricaAmerica - CentralAmerica - NorthAmerica - SouthAsiaCaribbeanEuropeMiddle EastPacific | |
| 3M ID: 98-0003-3702-6 - Alternate Product (Lead Times Apply) | |||||||
| D: 20.27" (514.90 mm) W: 17.638" (448.01 mm) H: 9.992" (253.80 mm) |
D: 20.98" (532.86 mm) W: 18.178" (461.72 mm) H: 10.472" (265.99 mm) |
Included (EXII-7760UC/98-0003-2814-0) | Wide | 8" (203.20 mm) | 9:00 | select a RegionCheck U.S. Distributor InventoryAfricaAmerica - CentralAmerica - NorthAmerica - SouthAsiaCaribbeanEuropeMiddle EastPacific | |
| 3M ID: 98-0003-3133-4 | |||||||
| D: 10.84" (275.08 mm) W: 8.58" (217.93 mm) H: 6.61" (167.89 mm) |
D: 11.62" (295.15 mm) W: 9.2" (233.68 mm) H: 7.1" (180.34 mm) |
EXII-7710UC USB/98-0003-2216-8, EXII-7720SC Serial/98-0003-2217-6 | Standard | 8" (203.2 mm) | 9:00 | select a RegionCheck U.S. Distributor InventoryAfricaAmerica - CentralAmerica - NorthAmerica - SouthAsiaCaribbeanEuropeMiddle EastPacific | |
| 3M ID: 98-0003-3136-7 (with 3M Vikuiti ALCF for viewer privacy) | |||||||
Included (EXII-7720SC/98-0003-2217-6) | Standard | 8" (203.2 mm) | 9:00 | select a RegionCheck U.S. Distributor InventoryAfricaAmerica - CentralAmerica - NorthAmerica - SouthAsiaCaribbeanEuropeMiddle EastPacific | |
| 3M ID: 98-0003-3134-2 | |||||||
Included (EXII-7760UC/98-0003-2814-0) | Standard | 8" (203.2 mm) | 9:00 | select a RegionCheck U.S. Distributor InventoryAfricaAmerica - CentralAmerica - NorthAmerica - SouthAsiaCaribbeanEuropeMiddle EastPacific | |
| 3M ID: 98-0003-3137-5 (with 3M Vikuiti ALCF for viewer privacy) | |||||||
| D: 10.84" (275.08 mm) W: 12.46" (316.48 mm) H: 9.52" (241.81 mm) |
| 3M ID: 98-0003-3139-1 | |||||||
| D: 12.39" (314.63 mm) W: 9.84" (249.94 mm) H: 7.52" (191.01 mm) |
D: 13.16" (334.26 mm) W: 10.45" (265.43 mm) H: 8" (203.2 mm) |
| 3M ID: 98-0003-3142-5 (with 3M Vikuiti ALCF for viewer privacy) | |||||||
| 3M ID: 98-0003-3140-9 | |||||||
| 3M ID: 98-0003-3170-6 (with 3M Vikuiti ALCF for viewer privacy) | |||||||
| 3M ID: 98-0003-3172-2 | |||||||
| D: 15.68" (398.27 mm) W: 12.46" (316.48 mm) H: 9.52" (241.81 mm) |
D: 16.4" (416.56 mm) W: 13" (330.2 mm) H: 10" (254.25 mm) |
| 3M ID: 98-0003-3175-5 (with 3M Vikuiti ALCF for viewer privacy) | |||||||
| 3M ID: 98-0003-3173-0 | |||||||
D: 16.4" (416.56 mm) W: 13" (330.2 mm) H: 10.01" (254.25 mm) |
| 3M ID: 98-0003-3176-3 (with 3M Vikuiti ALCF for viewer privacy) | |||||||
| 3M ID: 98-0003-3178-9 | |||||||
| D: 17.54" (445.52 mm) W: 13.6" (345.44 mm) H: 11.08" (281.43 mm) |
D: 18.26" (463.80 mm) W: 14.08" (357.63 mm) H: 11.62" (295.15 mm) |
Included (EXII-7720SC/98-0003-2217-6) | Standard | 8" (203.2 mm) | 11:00 | select a RegionCheck U.S. Distributor InventoryAfricaAmerica - CentralAmerica - NorthAmerica - SouthAsiaCaribbeanEuropeMiddle EastPacific | |
| 3M ID: 98-0003-3181-3 (with 3M Vikuiti ALCF for viewer privacy) | |||||||
| 3M ID: 98-0003-3179-7 | |||||||
Included (EXII-7760UC/98-0003-2814-0) | Standard | 8" (203.2 mm) | 11:00 | select a RegionCheck U.S. Distributor InventoryAfricaAmerica - CentralAmerica - NorthAmerica - SouthAsiaCaribbeanEuropeMiddle EastPacific | |
| 3M ID: 98-0003-3182-1 (with 3M Vikuiti ALCF for viewer privacy) | |||||||
D: 18.26" (463.80 mm) W: 13.53" (343.66 mm) H: 10.4" (264.16 mm) |
| 3M ID: 98-0003-3184-7 | |||||||
| D: 19.71" (500.63 mm) W: 15.31" (388.87 mm) H: 12.42" (315.47 mm) |
D: 20.44" (519.18 mm) W: 15.85" (402.59 mm) H: 12.9" (327.66 mm) |
| 3M ID: 98-0003-3185-4 | |||||||
| D: 19.71" (500.63 mm) W: 15.31" (388.87 mm) H: 12.45" (316.23 mm) |
