本公司优势产品西门子6ES7-200/300/400/1200/6EP/6AV/6GK/ET200/6SE变频器/电缆/DP接头/触摸屏 /变频器/数控伺服备件全系列产品 !
上海翰粤是西门子工控及自动化产品授权分销商欢迎来电咨询!
联系人:郑辕鸿先生(销售工程师)
手机:13585754803 商务QQ:1620718203
电话(TEL):021-60531296 传真(FAX):021-57657276
邮箱:zx2013888@163.com 网站:www.hanyue.cc
24小时销售技术服务热线:13585754803
西门子电缆订货号
6XV1830-0EH10 PROFIBUS通讯电缆
6XV1830-0AH10 DP电缆
6XV1820-5AH10 光纤电缆(米)
6XV1820-5BH50 光纤电缆 含BFOC (5米)
6XV1830-3EH10 TP转接软线
6XV1820-5BT10 光纤电缆 含BFOC (100米)
6GK1901-0DA20-0AA0 BFOC接头(每包20只)
6ES7901-0BF00-0AA0 5米MPI电缆 9针插头 PLC通讯电缆
PROFIBUS通讯电缆
6XV1 830-0EH102SIMATIC NET, PB FC STANDARD CABLE GP, 2-WIRE, SHIELDED, SPECIAL DESIGN FOR RAPID INSTALLATION, MAX. CONSIGNMENT: 1000 M, MIN. ORDERINGQUANTITY: 20 M SOLD BY THE METER
DP电缆
6XV1830-0AH10 SIMATIC NET, LAN CABLE FOR PROFIBUS, TWO-CORE, SHIELDED, MAX. CONSIGNMENT: 1000M, MIN. ORDER QUANTITY: 20 M SOLD BY THE METER
光纤电缆(米)
6XV1 820-5AH10SIMATIC NET, FIBER OPTIC CABLE (62.5/125),STANDARD CABLE, SPLITTABLE, W/O CONNECTOR, SOLD BY THE METER MAX. LENGTH: 2000 M MIN. LENGTH ORDERED: 20 M
光纤电缆 含BFOC (5米)
6XV1 820-5BH50SIMATIC NET, FIBER OPTIC CABLE (62.5/125)STANDARD CABLE, SPLITTABLE, PREASSEMBLED WITH 4 BFOC CONNECTORS, LENGTH: 5 M
光纤电缆 含BFOC (100米)
6XV1 820-5BT10SIMATIC NET, FIBER OPTIC CABLE (62.5/125)STANDARD CABLE, SPLITTABLE, PREASSEMBLED WITH 4 BFOC CONNECTORS, LENGTH: 100 M
BFOC接头(每包20只)
6GK1 901-0DA20-0AA0MM FO SET OF 20 BFOC CONNECTORS FOR FIBER OPTIC CABLE, STANDARD AND TRAILING TYPE CABLE, INDOOR AND MARINE APPROVED CABLE. ATTENTION: MOUNTING BY SPECIALLY TRAINED PERSONNEL AND WITH SPECIAL TOOLS ONLY! ADHESIVE BONDING- AND POLISHING TECHNOLOGY
5米MPI电缆
6ES7 901-0BF00-0AA0 SIMATIC S7,MPI电缆,用于连接 SIMATIC S7和PG,通过MPI5M
RS232电缆
6ES7 901-1BF00-0XA0 SIMATIC S7,连接电缆,用于HMI 适配器和PC/TS 适配器(RS232 / ZERO MODEM电缆)6M
西门子拖缆
6XV1830-3EH10 SIMATIC NET, PB FC TRAILING CABLE, PROFIBUS TRAILING CABLE MAX. ACCELERATION:4M/QS MIN. OF 3 MILL. BENDING CYCLES MIN. BENDING RADIUS: APPROX.120 MM 2-WIRE, SHIELDED, SOLD BY METER MAX. CONSEIGNMENT: 1000 M MIN. ORDERING QUANTITY: 20 M
总线系统
用于带有少数工作站且带有现场设备的蜂窝网络的过程和现场通信
以及用于符合 IEC 61 158/EN 50 170 规范的数据通信
确保和其他生产厂家的标准化元件之间的开放式互连
PROFIBUS –用于生产和过程自动化领域的现场总线标准:
物理层总线特性和接入方法标准的定义
用户层协议和用户接口的定义
概述:
用于不同应用区域的不同类型(例如,地下电缆、拖曳电缆、危险区域(Zone 1 和 Zone 2))
双层屏蔽,抗干扰性能好
阻燃总线连接电缆(不含卤素)。
由于电缆上印有以米表示的长度标记,因此易于确定长度
特点:
由于特殊的总线电缆,有很广的应用范围。
由于使用了双层屏蔽电缆和集成式接地技术,网络具有抗干扰功能。
采用 FastConnect (快速连接) 电缆,连接器连接简单又快速,从而节省了时间。
产品中不含硅硐,因此特别适用于汽车工业 (如上釉流水线)。
应用领域:
为了构建 PROFIBUS DP 网络,提供有不同类型的电缆,可满足不同类型应用的要求。一般地,应该使用所列出的电缆。有关网络组态的详细信息,请参见 PROFIBUS 网络手册。
UL 认证
用于网络电缆的 UL 列表(安全标准)对于美国和加拿大市场尤为必需。根据电缆敷设在建筑物中位置来决定适当的认证要求。这适用所有电缆,这些电缆从一个机器敷设到一远程控制柜,位于电缆架上并保护着建筑物。通过 UL 认证的电缆在其名称后面附加字母“GP”(通用)。
Ex认证
用于本质安全 PROFIBUS DP 应用的电缆在其名称后面附加字母“IS”(本质安全)
设计:
屏蔽的双绞电缆,圆形截面
所有 PROFIBUS 总线电缆的特点:
因为双屏蔽作用,这些电缆特别适合用于易受电磁干扰的工业环境中。
通过总线电缆外皮和总线端子上的接地端子,能实现系统范围内的接地方案。
印有以米表示的标记
电缆类型
全新的快速连接(FC)总线电缆为径向对称设计,可使用剥线工具。以此,可以快速、简便地安装总线接头。
PROFIBUS FC 标准电缆GP:
标准总线电缆专门为快速安装而设计的
PROFIBUS FC 标准电缆 IS GP:
具有特殊设计的标准总线电缆,用于快速安装本质安全分布式 I/O 系统
PROFIBUS FC 快速连接高强度电缆:
专门设计用于腐蚀环境和苛刻机械负荷条件
PROFIBUS FC 食用电缆:
该种电缆使用 PE 外套材料,因此适用于食品和烟草行业。
PROFIBUS FC 接地电缆:
专用于地下敷设。它不同于装备有附加外套的 PROFIBUS 总线电缆
PROFIBUS FC软电缆
柔性(绞合导线)、无卤素总线电缆,带聚氨酯护套,可偶然移动
PROFIBUS FC 拖缆:
专用于在拖缆中强制运动控制的总线电缆,例如在连续运动的机器部件中(绞合导线)
PROFIBUS FC FRNC 电缆:
双芯屏蔽,阻燃设计,无卤总线电缆,有一个共聚物外壳 FRNC(阻燃无腐蚀)
不采用快速连接技术的总线电缆(取决于结构类型)
PROFIBUS 彩色电缆:
软总线电缆(成束线),用于花彩线。
用于圆电缆,推荐用于电缆运输车模式
PROFIBUS 扭转电缆
高度灵活用总线电缆:
用于移动机器部件的拖缆(绞线)
(在长 1 m电缆上能至少扭转 500 万次,± 180o)
PROFIBUS 混合电缆 GP:
适合拖曳的坚固混合电缆,带有两条用于数据传输的铜导线和两条用于 ET 200pro 的电源的铜导线
SIENOPYR FR 船用电缆
无卤素、抗踩压、阻燃、经过船级社认证的光纤电缆,可安装在船甲板及船舱内。按米销售
安装说明
总线电缆按米销售。 如果总线段必须由两部分装配(例如 >1000 m 段长),可使用外套(低电阻连接导线,在更广泛的区域内连接屏蔽)。
快速连接
使用 FastConnect 剥线工具,可以一下剥去新的快速连接电缆外皮并获得精确的长度。
用这种方法能快速、方便地将总线接头(除了 6ES7 972-0BA30-0XA0 外)连接到总线电缆。
电缆布线:
在贮存、运输和电缆敷设过程中,两端需用收缩帽密封两端。
符合允许的弯曲半径和张力负载!
如果是在户外敷设,例如在地下、沙子中或混凝土中敷设,或通过由钢制或塑料保护管在地上或地下敷设,则需要使用埋入电缆。
符合埋地敷设过电压保护规程。
