SA 100D is a flexible silicon modified urethane acrylate, suitable for foil coating application. Due to the content of specialized silanol functionality, it could be cured by heat (150-170°C) as well. Meanwhile, it has two UV curing calculated functionality.
SA 100D是一只柔韧的硅改性的聚氨酯丙烯酸齐物,适用于箔涂料、LOCA胶水。由于其含有特别设计的硅醇结构,其亦可以通过加热固化。同时,其具有二官能度UV固化官能基 。
