大家好!无锡施罗森科技有限公司提供各种通用零部件,如:漏液感应器、除静电器、超声波、兆声波发生器等,专业代理韩国DIT各类产品。除静电器的喷嘴、离子风机、静电电压表Lon Bar、Lon Blower、Lon Nozzle 、Hand-Held Electrostatic、Electrostatic Voltmeter 、Ion Blower等。主要客户有SAMSUNG ELECTRONICS三星电子,SAMSUNG THALES三星泰雷兹公司, LG Electronics LG电子, DONG YANG E& P, HYUNDAI WIA现代威亚, DOOSAN, LS IS ,LIG
Nex1, Hansol韩松, TI Automotive TI汽车, MITSUBISHI
ELECTRIC三菱电机, MOTONIC, SAMSUNG DISPLAY三星显示器, SAMSUNG
ELECTRO-MECHANICS三星机电公司, LG Display
LG显示, LG Innotek LG伊诺特, FAIRCHILD, Amkor
Technology, SK hynix SK海力士。
销售部电话: +86-510-81880058
ION-BAR
MB-AW Series:
ION BAR
MB-GW/PW Series:
ION BAR
MB-L Series:
ION-BLOWER
SF-40A:
ION BLOWER
MF-90 Series:
ION BLOWER
MF-A90 Series:
ION NOZZLE
ZM-G11, ZM-G12:
ION GUN
ZM-GIG:
ION
ConTROLLER ZM-G1C:
ELECTROSTATIC
FIELDMETER SS-M:
ION-BAR
MB-AW Series:
1.主体尺寸(Dimensions):35mm
(D) ×69.4mm (H), Customizer Specified Length
2.输入电压(Input Voltage):
+24VDC
5.放电针(Emitter
Pins): Tungsten
ION
BAR MB-GW/PW Series:
+24VDC
5.放电针(Emitter
Pins): Tungsten
ION
BAR MB-L Series:
+24VDC±10%
5.放电针(Emitter
Pins): Titanium
ION-BLOWER
SF-40A:
1.主体尺寸(Dimensions):
46W×68.5H ×36mm(D)
2.输入电流(Input Current):
DC24V,0.15A
4.放电针(Emitter
Pins): Titanium
6.消除静电时间(Decay
Time):1.5sec
at 15cm
7.风量(Air Flow): 0.27m2/min
(Max)
9.显示功能(Displays): High Voltage LED (G/R), Fan LED(G/R), G/R:
Normal/ Abnormal
10.手动调节功能(Adjustable Controls):
Fan Speed/Ion Balance (Manual Adjustment),
ION
BLOWER MF-90 Series:
1.电源(Power): AC
100-22-V (60Hz) or DC 24V
DC24V, 0.15A
4.放电针(Emitter
Pins): Titanium
6.消除静电时间(Decay
Time):Better
than 2 seconds at 30cm
7.风量(Air Flow): Max.
1.75m2/min pre Fan
9.显示功能(Displays):
High Voltage Alarm LED (G/R), Fan Alarm LED (G/R),
12.重量(Weight): 按规格依次为:1kg, 1.9kg,
2.8kg, 3.7kg, 4.6kg
ION
BLOWER MF-A90 Series:
1.电源(Power): AC
按规格其最大输入电流依次为:0.4A,
0.4A, 0.6A, 0.8A, 1.2A
4.放电针(Emitter
Pins): Titanium
6.消除静电时间(Decay
Time):Better
1.75m2/min pre Fan
9.显示功能(Displays):
12.重量(Weight):按规格依次为 1kg,
1.9kg, 2.8kg, 3.7kg, 4.6kg
ION
NOZZLE ZM-G11, ZM-G12:
1.输入电压(Input Voltage):
+24VDC
5.离子平衡调节(Ion
Balance Adjustment): Auto
6.消除静电时间(Decay
Time):1.0
seconds at 15cm (air 3kgf/ cm2)
8.放电针(Emitter
Pins): Titanium
11.喷出力(Blow-off
Force):128l/ cm2 (air 3kg/cm2)
ION
GUN ZM-GIG:
+24VDC
5.离子平衡调节(Ion
6.消除静电时间(Decay
Time):1.0
8.放电针(Emitter
Pins): Titanium
11.喷出力(Blow-off
ION
ConTROLLER ZM-G1C:
AC100V~220V, 50~60Hz
2.输出电压(Output Voltage(Typical)):
+24VDC
3.额定功率(Regularity Power):
12W
5.气体调节(Air Control):
Typically lower than 5 kgf/ cm2 (Mix.7kgf/ cm2)
ELECTROSTATIC
FIELDMETER SS-M:
1. 主体尺寸(Dimensions):55.5mm
(W) ×40.2mm (H) ×70.1mm (D)
+24VDC
3.耗电量(Power Consumption):
3W以下
4.传感器(Sensor):
DIT Electrostatic Voltage Sensor
6.测定范围(Range): 精密模式:±2kV(±5%), 扩张模式:±20Kv
(±10%)
7.分辨率(Resolution):
精密模式:1V,扩张模式:10V
8.线性度(Linearity):
±5%F.S
11.通讯(Communication):
RS-485
