This is a highend touch display developed by us independently perfect screen size (4:3),ABS+PC plastic shell, fashionable and elegant, scratch-proof, water-proof and dust-proof design. Active thermal-control heat dissipation shell is adopted to provide stable and safe running environment for users. The touch monitor converts complex menu operation into simple touch operation, improving work efficiency to some extent. It is applied to some daily consumer sites, Selt-service inquiry machine and book querier.
LCD
17inch CCFL
Pixel pitch
0.264*0.264mm
Resolution
1280*1024 (SXGA)
Contrast Ratio
1000:1
Brightness
250CD/m2
Response time
3.5/1.5
Display color
16.7
Effective display size
337.920*270.336mm
Viewing angle
85/85/80/80
Backlight
50000
Scan
60Hz
Operate temperation
0-50
Storage tempt.
-20--60
Input signal interface
MINI D~sub 15~PIN VGA type
Interface
VGA and DVI
RCA
Yes (Optional)
Touch screen
5 wire Resistive
Srface hardness
>3H
Light transmission
>80%
Haze
Clear surface <3%
Antiglare surface <4%
Anti-newton<10%
Waterproof
Not damaged by running water applied to the active area
Opetrationg tempt.
-10--70
Storage tempt
-40—80
DC
5V
Response
<15Ms
Interface
USB or RS232
For the TDS1701 touch monitor
Dimension size
400*330*69mm
Weight
7KG
Carton size
46*25.7*42cm
VESA
75*75
Certification
CE FCC, ROHS , IP65 , CCC
Adjustable base
90-180
Warranty
Three years
Power
AC 110-240V 50-60Hz
DC 12V 5A
Accessories
USB cable , VGA cable , Power adapter , power cable , CD driver
